Page 2 of 4 1 2 3 4
Re: 1970 440 HP Vs HP2 ?? [Re: cyphre666] #23227
01/26/06 01:40 PM
01/26/06 01:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The 500 wedges are 4 bolt mains
but 500 wedges are built in NEW MEGABLOCKS ....
Re: 1970 440 HP Vs HP2 ?? [Re: JohnRR] #23228
01/26/06 01:40 PM
01/26/06 01:40 PM
Ohio
john55 Offline
john55  Offline
Ohio
, second is a cam that takes a 3 bolt timing gear , it MUST HAVE BOTH
......forgot that one
Re: 1970 440 HP Vs HP2 ?? #23229
01/26/06 01:41 PM
01/26/06 01:41 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
Now I am more mixed up. I hear something about a 6 stamped on the block itself down below pad. Is this true
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23230
01/26/06 01:42 PM
01/26/06 01:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
NO .... there is alot of MISINFORMATION that has been spread around over the years ...
Re: 1970 440 HP Vs HP2 ?? [Re: JohnRR] #23231
01/26/06 01:44 PM
01/26/06 01:44 PM
Kenmore, New York
InViolent Offline
InViolent  Offline
Kenmore, New York
...And it must have the correct balancer and rods to boot, right?
Re: 1970 440 HP Vs HP2 ?? [Re: JohnRR] #23232
01/26/06 01:45 PM
01/26/06 01:45 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
the only way to tell an original 6pk shortblock is to find an unmolested block , it MUST have these 2 items , first is pistons with 4 valve reliefs , second is a cam that takes a 3 bolt timing gear , it MUST HAVE BOTH
third way to tell is is you can match the #s stamped on the block to a KNOWN SIX PACK CAR VIN
My original 69 440-6 block is stamped HP not HP2
69.5 A12 Bee, first purchased in 1976, car 169 on registry 69 Coronet R/T 440/4 spd 69 Coronet 500 Conv H code 383 4bbl/auto 37 Plymouth PU Find your spot on earth and ride it.
Re: 1970 440 HP Vs HP2 ?? [Re: InViolent] #23233
01/26/06 01:46 PM
01/26/06 01:46 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thats a given since BOTH the 440-4 and the 6 pk have the same rods and balancer .
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23234
01/26/06 01:47 PM
01/26/06 01:47 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
No it's not true. Don't be mixed up. Like John said there are NO MARKINGS to determine it's a 440-6 except if you can match the partial VIN to a V-code VIN car. You can tell by the pistons and cam, but what are the odds that it still has the original pistons and cam after 36 years?
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: 1970 440 HP Vs HP2 ?? [Re: DPelletier] #23235
01/26/06 01:48 PM
01/26/06 01:48 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
exactly , thats why the myth is still thriving , spread by those looking to make a buck
Re: 1970 440 HP Vs HP2 ?? [Re: DPelletier] #23236
01/26/06 01:51 PM
01/26/06 01:51 PM
Dreaming of the 808
AZ_A12_BEE Offline
AZ_A12_BEE  Offline
Dreaming of the 808
I fixed it for you
No it's not true. Don't be mixed up. Like John said there are NO MARKINGS to determine it's a 440-6 except if you can match the partial VIN to a V-code VIN car OR 69 M CODE A12 CAR. You can tell by the pistons and cam, but what are the odds that it still has the original pistons and cam after 36 years?
Re: 1970 440 HP Vs HP2 ?? [Re: AZ_A12_BEE] #23237
01/26/06 02:16 PM
01/26/06 02:16 PM
New Jersey
U_Code_Cuda Offline
U_Code_Cuda  Offline
New Jersey
My 1970 U-code Cuda is stamped HP2 and is original #'s motor(partial vin on motor). Car has a harmonic balancer that resembles a cast crank. All 440-4 and 440-6 used the heavy six pack rods and in turn used a externally balanced crank....
1970 R/T Challenger 4-speed
1971 Demon 340 3-speed
Re: 1970 440 HP Vs HP2 ?? [Re: U_Code_Cuda] #23238
01/26/06 02:23 PM
01/26/06 02:23 PM
AndyF Offline
AndyF  Offline
I have an old block that is stamped HP2. I think it is a 1968 383 if I recall correctly. That was how I finally figured out that the HP2 stuff was mostly just mis-information spread around by guys trying to scalp a few extra bucks.
Re: 1970 440 HP Vs HP2 ?? [Re: JohnRR] #23239
01/26/06 02:26 PM
01/26/06 02:26 PM
DPelletier Offline
DPelletier  Offline
........which means you can't use the rods and balancer to determine if a motor is a 6-Pack or not. All HP motors used "6-Pack" rods and balancers (which make you wonder why the heck they called them "6-Pack" rods).
Re: 1970 440 HP Vs HP2 ?? [Re: AZ_A12_BEE] #23240
01/26/06 02:31 PM
01/26/06 02:31 PM
DPelletier Offline
DPelletier  Offline
I fixed it for you
Thanks Dave!! No offence was intended to my A-12 brothers!!!
Re: 1970 440 HP Vs HP2 ?? [Re: AndyF] #23241
01/26/06 02:34 PM
01/26/06 02:34 PM
DPelletier Offline
DPelletier  Offline
Exactly! If I see one more supposed "440-6 Pack block" (with no real proof) on E-Bay, I'm gonna
Re: 1970 440 HP Vs HP2 ?? [Re: DPelletier] #23242
01/26/06 02:34 PM
01/26/06 02:34 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
So what does the B stamped on the top of my pad mean
Thanks Guys for all the help
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23243
01/26/06 02:39 PM
01/26/06 02:39 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Unless I'm mistaken, the "B" indicates the year of the engine.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: 1970 440 HP Vs HP2 ?? [Re: 68LAR] #23244
01/26/06 02:42 PM
01/26/06 02:42 PM
White Plains, NY
VCODE Online boogie
VCODE  Online Boogie
White Plains, NY
I am sorry, I should have said that it is a 70
stamped F440 with the HP and 11 111
and a B
Thanks again
Re: 1970 440 HP Vs HP2 ?? [Re: VCODE] #23245
01/26/06 02:43 PM
01/26/06 02:43 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I don't know what that means.
Re: 1970 440 HP Vs HP2 ?? [Re: AndyF] #23246
01/26/06 02:44 PM
01/26/06 02:44 PM
Kenmore, New York
InViolent Offline
InViolent  Offline
Kenmore, New York
Now wait a minute! I thought 70-71 only did the 440-4V HP use the same balancer as the 440+6. In 69, wasn't the 440+6 the only engine to use this configuaration? Did the Forged crank 440's in 72-74 use the same balancer?
I guess another wat to put it..."When did the 440-4 and 440+6 share the same rod/balancer part number?"
And finally...how can I identify a "Six-Pack" Rod?
Page 2 of 4 1 2 3 4
