Page 1 of 3 1 2 3
Dremel bit for aluminum? #2323883
06/19/17 11:05 PM
06/19/17 11:05 PM
middle Tennessee
mopower440 Offline OP
middle Tennessee
I bought an aluminum water pump housing from 440 source for my 440. It was a blemished model because one of the ports is slightly smaller than should be. They say its fine to use as is or if you like, you can dremel it out a hair, like porting heads. What is a good dremel bit to use for this? The 2 stones i have clog up with aluminum real quickly..
Re: Dremel bit for aluminum? [Re: mopower440] #2323886
06/19/17 11:10 PM
06/19/17 11:10 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have heard nothing but bad things about those "too small port" 440 Source housings, I would NOT use it even after opening it up... tsk
JB Rhinehart, Realist
A-Body's RULE!
Re: Dremel bit for aluminum? [Re: Rhinodart] #2323887
06/19/17 11:12 PM
06/19/17 11:12 PM
middle Tennessee
middle Tennessee
what have you heard?
Re: Dremel bit for aluminum? [Re: mopower440] #2323898
06/19/17 11:22 PM
06/19/17 11:22 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
bad things
Re: Dremel bit for aluminum? [Re: mopower440] #2323902
06/19/17 11:27 PM
06/19/17 11:27 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
use trans fluid on the cutter and it wont clog.
Re: Dremel bit for aluminum? [Re: mopower440] #2323914
06/19/17 11:50 PM
06/19/17 11:50 PM
Southwest USA
71muffin Offline
71muffin  Offline
Southwest USA
Probably yet another example of Chinese parts crap.
Re: Dremel bit for aluminum? [Re: 71muffin] #2323919
06/19/17 11:57 PM
06/19/17 11:57 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Blaster works even better than atf. Chalk also works wonders if you want to do it dry.
Re: Dremel bit for aluminum? [Re: John Brown] #2323956
06/20/17 01:08 AM
06/20/17 01:08 AM
blaster as in PB blaster? I too have one of those discounted housings & I'm for sure gonna hog it out/keep tabs on flow/temp to see if I got a smokin deal or not. EDIT been awhile since I eyeballed it but this thread reminded me that I was maybe gonna open an access hole in the side to get in there then cap it with an NPT plug.
Re: Dremel bit for aluminum? [Re: mopower440] #2323974
06/20/17 01:40 AM
06/20/17 01:40 AM
You should buy a course carbide aluminum bit and use candle wax to keep it clean when it starts to clog up scope
Be careful when you start cutting with one of them, they cut a lot in a hurry boogie shruggy
Re: Dremel bit for aluminum? [Re: mopower440] #2324004
06/20/17 03:08 AM
06/20/17 03:08 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Funny how things get twisted around...
440Source tried to clone the Mopar Performance water pump housing, unfortunately in their development tooling/sourcing process nobody checked the internal passages' dimensions.... eek
And the China factory went into full mass production, and 440Source received a full shipment of water pump houisings, once sales started the negative reports started pouring in the Mopar engines were overheating..
Next 440Source was well aware of the problem and gradually modified the tooling by enlarging the internal passages. Unfortunately 440Source was stuck with a pile of the original defective products...
Just my $0.02.. wink
Re: Dremel bit for aluminum? [Re: RapidRobert] #2324007
06/20/17 03:34 AM
06/20/17 03:34 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Yep, PB Blaster. I used to use it way back when on aluminum heads. Hopefully whatever comes in the spray cans hasn't changed too much in the last 45 to 50 years. Actually hadn't realized how long ago it was that I was working in New Paris. You might call that the good old days, or not.....
Re: Dremel bit for aluminum? [Re: mopower440] #2324010
06/20/17 03:51 AM
06/20/17 03:51 AM
Earth
Rob C Offline
Rob C  Offline
Earth
Can anybody show a picture of this too small port and what it should be like?
Re: Dremel bit for aluminum? [Re: Rob C] #2324044
06/20/17 09:59 AM
06/20/17 09:59 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The easiest way to check is to insert a finger into the lower hose opening, if it is tight then you know. I just sold an MP unit this week, I could almost put two fingers in the opening... work
A-Body's RULE!
Re: Dremel bit for aluminum? [Re: mopower440] #2324058
06/20/17 10:31 AM
06/20/17 10:31 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
1. Don't use stones on aluminum. Use carbide burrs.
2. A Dremel will take forever and I doubt that you can reach in far enough with any bit that will fit in a dremel. Borrow or buy a die grinder that accepts 1/4" shank bits. Either pneumatic or electric. You can get a cheap one at Harbor Frieght that will work.
3. Several posts have already mentioned what to use on the bits to keep them from loading up with aluminum. Pick one. They all help.
4. Don't use stones on aluminum.
5. Whoever you talked to at 440source is an idiot for suggesting that you could fix this with a dremel.
6. Did I mention, Don't use stones on aluminum.
Re: Dremel bit for aluminum? [Re: John Brown] #2324063
06/20/17 10:37 AM
06/20/17 10:37 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I buy it by now the gallon with a coupon from advance auto and add a little transmission fluid to it
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Dremel bit for aluminum? [Re: mopower440] #2324070
06/20/17 10:44 AM
06/20/17 10:44 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I "had" one of those pumps. You can open that up to at least double the current size but there is a turn in the port and you'll have a problem going much past it.
For what 440Source paid for those I think they should have scrapped the lot and saved themselves all the bad press.
Whether or not there were any "real life" issues due to the pump themselves is hard to say. You have to figure that someone putting on one of these pumps has done other mods too - which could cause overheating issues.
Re: Dremel bit for aluminum? [Re: GomangoCuda] #2324092
06/20/17 11:23 AM
06/20/17 11:23 AM
moparx Offline
moparx  Offline
DON"T use stones on aluminum ! this can't be emphasized enough ! i agree on all the above points.
beer
Re: Dremel bit for aluminum? [Re: mopower440] #2324121
06/20/17 12:01 PM
06/20/17 12:01 PM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The 120V AC wired Harbor Freight 1/4 Die Grinder has a flaw in that the plastic will crack near where the four mounting screws get their internal threaded purchase.
If you line up a drill bit correctly and hold it steady, drilling on through the plastic to the metal frame beneath and using a longer screw or all thread as a stud will strengthen the assembly enough to prevent the cracking.
Sugru moldable epoxy might possibly be used to strengthen the plastic in the weak section.
The formerly $100 Craftsman 1/4 die grinder is discontinued but is a worthwhile purchase at a yard sale if the price is low.
Re: Dremel bit for aluminum? [Re: 360view] #2324132
06/20/17 12:17 PM
06/20/17 12:17 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you look at a carbide burr for steel it has a crosscut cutter pattern. If you look at a carbide burr for aluminum it has a single cutter pattern. That's intended to keep the burr from clogging with aluminum. As to using stones? All of the comments are spot on, don't even try.
Re: Dremel bit for aluminum? [Re: 6PakBee] #2324160
06/20/17 12:58 PM
06/20/17 12:58 PM
GomangoCuda Offline
GomangoCuda  Offline
I should have pointed out the difference between single cut and double cut burrs. Single cut will cut faster and clog less in aluminum but it also makes long very sharp slivers that can ruin your day. Please at least wear good eye protection with either type of cutter. If you have to go to the emergency room with metal in your eye they will show you their grinder. Real close up!
Page 1 of 3 1 2 3
