Re: Dremel bit for aluminum?
[Re: 71muffin]
#2323919
06/19/17 11:57 PM
06/19/17 11:57 PM
Posts: 1,820 South Bend
John Brown
South Bend
Blaster works even better than atf. Chalk also works wonders if you want to do it dry.
[Re: John Brown]
#2323956
06/20/17 01:08 AM
06/20/17 01:08 AM
RapidRobert
blaster as in PB blaster? I too have one of those discounted housings & I'm for sure gonna hog it out/keep tabs on flow/temp to see if I got a smokin deal or not. EDIT been awhile since I eyeballed it but this thread reminded me that I was maybe gonna open an access hole in the side to get in there then cap it with an NPT plug.
[Re: mopower440]
#2324004
06/20/17 03:08 AM
06/20/17 03:08 AM
Posts: 5,439 So Cal
Sinitro
So Cal
I have heard nothing but bad things about those "too small port" 440 Source housings, I would NOT use it even after opening it up... what have you heard? Funny how things get twisted around... 440Source tried to clone the Mopar Performance water pump housing, unfortunately in their development tooling/sourcing process nobody checked the internal passages' dimensions.... And the China factory went into full mass production, and 440Source received a full shipment of water pump houisings, once sales started the negative reports started pouring in the Mopar engines were overheating.. Next 440Source was well aware of the problem and gradually modified the tooling by enlarging the internal passages. Unfortunately 440Source was stuck with a pile of the original defective products... Just my $0.02..
[Re: RapidRobert]
#2324007
06/20/17 03:34 AM
06/20/17 03:34 AM
John Brown
South Bend
blaster as in PB blaster? Yep, PB Blaster. I used to use it way back when on aluminum heads. Hopefully whatever comes in the spray cans hasn't changed too much in the last 45 to 50 years. Actually hadn't realized how long ago it was that I was working in New Paris. You might call that the good old days, or not.....
[Re: mopower440]
#2324058
06/20/17 10:31 AM
06/20/17 10:31 AM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
What is a good dremel bit to use for this? The 2 stones i have clog up with aluminum real quickly.. 1. Don't use stones on aluminum. Use carbide burrs. 2. A Dremel will take forever and I doubt that you can reach in far enough with any bit that will fit in a dremel. Borrow or buy a die grinder that accepts 1/4" shank bits. Either pneumatic or electric. You can get a cheap one at Harbor Frieght that will work. 3. Several posts have already mentioned what to use on the bits to keep them from loading up with aluminum. Pick one. They all help. 4. Don't use stones on aluminum. 5. Whoever you talked to at 440source is an idiot for suggesting that you could fix this with a dremel. 6. Did I mention, Don't use stones on aluminum.
[Re: John Brown]
#2324063
06/20/17 10:37 AM
06/20/17 10:37 AM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
blaster as in PB blaster? Yep, PB Blaster. I used to use it way back when on aluminum heads. Hopefully whatever comes in the spray cans hasn't changed too much in the last 45 to 50 years. Actually hadn't realized how long ago it was that I was working in New Paris. You might call that the good old days, or not..... I buy it by now the gallon with a coupon from advance auto and add a little transmission fluid to it
[Re: GomangoCuda]
#2324092
06/20/17 11:23 AM
06/20/17 11:23 AM
Posts: 19,355 north of coder
moparx
What is a good dremel bit to use for this? The 2 stones i have clog up with aluminum real quickly.. 1. Don't use stones on aluminum. Use carbide burrs. 2. A Dremel will take forever and I doubt that you can reach in far enough with any bit that will fit in a dremel. Borrow or buy a die grinder that accepts 1/4" shank bits. Either pneumatic or electric. You can get a cheap one at Harbor Frieght that will work. 3. Several posts have already mentioned what to use on the bits to keep them from loading up with aluminum. Pick one. They all help. 4. Don't use stones on aluminum. 5. Whoever you talked to at 440source is an idiot for suggesting that you could fix this with a dremel. 6. Did I mention, Don't use stones on aluminum. DON"T use stones on aluminum ! this can't be emphasized enough ! i agree on all the above points.
[Re: 360view]
#2324132
06/20/17 12:17 PM
06/20/17 12:17 PM
Posts: 10,704 North Dakota
6PakBee
North Dakota
If you look at a carbide burr for steel it has a crosscut cutter pattern. If you look at a carbide burr for aluminum it has a single cutter pattern. That's intended to keep the burr from clogging with aluminum. As to using stones? All of the comments are spot on, don't even try.
[Re: 6PakBee]
#2324160
06/20/17 12:58 PM
06/20/17 12:58 PM
GomangoCuda
If you look at a carbide burr for steel it has a crosscut cutter pattern. If you look at a carbide burr for aluminum it has a single cutter pattern. That's intended to keep the burr from clogging with aluminum. As to using stones? All of the comments are spot on, don't even try. I should have pointed out the difference between single cut and double cut burrs. Single cut will cut faster and clog less in aluminum but it also makes long very sharp slivers that can ruin your day. Please at least wear good eye protection with either type of cutter. If you have to go to the emergency room with metal in your eye they will show you their grinder. Real close up!
