Re: lake wood scatter sheild [Re: bigblockbryan] #2321735
06/15/17 06:14 PM
06/15/17 06:14 PM
Ohio
lockjaw-express Offline
Ohio
BigBlockBryan,
I have the part that allows for use of a 130T flywheel, it is the part in your pic on the right.
If you want it, you can have it, just pay for the shipping...your call/
I do not have the nose cone piece, as I have that installed in my Lakewood bell. the nose locator is used for both the 130 and 143 flywheels.
Regards, Mark
Re: lake wood scatter sheild [Re: Cab_Burge] #2322624
06/17/17 02:02 PM
06/17/17 02:02 PM
United states wisconsin
bigblockbryan Offline OP
yea i just picked up a cast iron bell of ebay thats for a 10.5 clutch just gonna get this thing on the road sick of not driving my car
Re: lake wood scatter sheild [Re: bigblockbryan] #2323131
06/18/17 04:01 PM
06/18/17 04:01 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
is THIS it?
shruggy
were all smallblock flywheels 130 tooth?
If so I only need the nose cone piece.
If not I need this: Lakewood adapter kit
And PERFECT timing as I have had the Lakewood and Center force forever but just broke a clutch spring on the stock unit yesterday
Thanks for any help
Re: lake wood scatter sheild [Re: bigblockbryan] #2323158
06/18/17 05:19 PM
06/18/17 05:19 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
You'll be sicker and not driving longer if your right foot is missing... depending on how strong your engine is (and how many RPM you turn it), the scattershield is never a bad idea. twocents
Re: lake wood scatter sheild [Re: bigblockbryan] #2323652
06/19/17 03:44 PM
06/19/17 03:44 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
Bump bump
Re: lake wood scatter sheild [Re: bigblockbryan] #2323661
06/19/17 03:52 PM
06/19/17 03:52 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
can anyone tell me is there a diffrence in this bell housing
http://www.brewersperformance.com/proddetail.asp?prod=BH450
its listed as a 3 speed bell housing im thinking about buying it i have a 833 23 spline out of a 68 road runner
by the time you buy the other parts you need to install the 833 without all it's bolts you could just pony up for the right bellhousing
Re: lake wood scatter sheild [Re: UCUDANT] #2323663
06/19/17 03:55 PM
06/19/17 03:55 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By UCUDANT
is THIS it?
shruggy
Thanks for any help
Yes all smallblocks were only 130tooth.
If that is a smallblock bellhousing you shouldn't need that .
Re: lake wood scatter sheild [Re: bigblockbryan] #2323718
06/19/17 05:46 PM
06/19/17 05:46 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Running up your post count about sums it up. Late to the party as usual ... all his issues have been addressed.
Re: lake wood scatter sheild [Re: bigblockbryan] #2323730
06/19/17 06:09 PM
06/19/17 06:09 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
What exactly does that little tab with the stepped stud on it do?
We have one of the Lakewood bell housings we use on the dyno, and I thought the one starter bolt hole for the 130T flywheel was just drilled in the wrong place.
For the dyno, it's not really a big deal. The upper bolt fits okay, and on the bottom one I just use a c clamp.
Re: lake wood scatter sheild [Re: bigblockbryan] #2323791
06/19/17 08:22 PM
06/19/17 08:22 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
This will explain and show it:
http://www.jegs.com/InstallationInstructions/600/620/620-15905.pdf
Re: lake wood scatter sheild [Re: bigblockbryan] #2323972
06/20/17 01:34 AM
06/20/17 01:34 AM
So. Burlington, Vt.
So. Burlington, Vt.
Got it ........ Thanks.
Re: lake wood scatter sheild [Re: Stanton] #2324107
06/20/17 11:42 AM
06/20/17 11:42 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If you pull your head out of your backside long enough to see what was actually going on in the world around you you'd realize to whom I was responding to ...
UCUDANT asked twice about this part, and flywheel tooth count near the end of this thread and no one had responded to his 2 requests for info.
but thanks for playing ...
