Re: Refinishing gas filler and ECS tubes
[Re: Neil]
#2321205
06/14/17 05:56 PM
06/14/17 05:56 PM
Posts: 892 MA
steve70
MA
The only repros I've seen were from Megaparts but they looks like new stainless steel. I ended up using scotch brite on the scratches and then put them in a vibratory tumbler to give them a finish that looked original. I sprayed them with a satin clear before installation.
1970 Challenger T/A 4 speed
[Re: Neil]
#2321237
06/14/17 07:16 PM
06/14/17 07:16 PM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
If you want restoration, contact Allen Wilson: http://www.n96airgrabber.com/fillertube.htmHe did an excellent job for me on my filler tube that had lots of internal rust and some external. Photo is Before. Sorry, don't have an After, but it looks nearly new now.
[Re: kentj340]
#2321254
06/14/17 08:02 PM
06/14/17 08:02 PM
Posts: 4,115 MD
floyd
MD
[Re: Neil]
#2322629
06/17/17 02:17 PM
06/17/17 02:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
What are the options for refinishing the gas tank fill tube and 1970 ecs vent tube in the trunk? Looks like they have some sort of lead coating on them? Mine are still somewhat shiny, but full of scratches.
Once upon a time a swear I saw repos on Ebay, but I can't find any for an A-Body. You could do your own if you have a good torch set up?, if the original is in good shape just heat the entire tube until the lead solder is wet, then wipe it with a folded rag dampened with water, you have to work quickly! long strokes in an orderly fashion If the tube's original finish needs to be removed along with rust/etc, sandblast the tube clean, then polish the tube with sandpaper to about a 400 grit finish, to re-coat it in lead solder, you'll need to dip the tube in Stainless Steel flux (hydrochloric acid)prior to tinning it with lead solder
