Refinishing gas filler and ECS tubes #2321176
06/14/17 04:49 PM
06/14/17 04:49 PM
Eagle, Idaho
Neil Online content OP
The Doctor is in.
Neil  Online Content OP
The Doctor is in.
Eagle, Idaho
What are the options for refinishing the gas tank fill tube and 1970 ecs vent tube in the trunk? Looks like they have some sort of lead coating on them? Mine are still somewhat shiny, but full of scratches.
Once upon a time a swear I saw repos on Ebay, but I can't find any for an A-Body.
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2321205
06/14/17 05:56 PM
06/14/17 05:56 PM
MA
steve70 Offline
steve70  Offline
MA
The only repros I've seen were from Megaparts but they looks like new stainless steel. I ended up using scotch brite on the scratches and then put them in a vibratory tumbler to give them a finish that looked original. I sprayed them with a satin clear before installation.
1970 Challenger T/A 4 speed
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2321237
06/14/17 07:16 PM
06/14/17 07:16 PM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
If you want restoration, contact Allen Wilson:
http://www.n96airgrabber.com/fillertube.htm
He did an excellent job for me on my filler tube that had lots of internal rust and some external.
Photo is Before. Sorry, don't have an After, but it looks nearly new now.
Re: Refinishing gas filler and ECS tubes [Re: kentj340] #2321254
06/14/17 08:02 PM
06/14/17 08:02 PM
MD
floyd Offline
floyd  Offline
MD
Wilson does a great job!
Re: Refinishing gas filler and ECS tubes [Re: floyd] #2321408
06/15/17 01:21 AM
06/15/17 01:21 AM
Eagle, Idaho
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Thanks for the advice.
The fill tube has a couple pretty deep scratches that would be pretty hard to eliminate 100%. The ECS tube, which is behind the gas fill tube and better protected, is in nicer shape.
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2321470
06/15/17 03:44 AM
06/15/17 03:44 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
This is good to know.
Re: Refinishing gas filler and ECS tubes [Re: floyd] #2321535
06/15/17 10:22 AM
06/15/17 10:22 AM
blewbyu Offline
blewbyu  Offline
So he has a process to put lead over it and make it look original? I know some polish it which is not correct.
Re: Refinishing gas filler and ECS tubes [Re: blewbyu] #2321595
06/15/17 12:48 PM
06/15/17 12:48 PM
Crook County, ILL
Mastershake340 Offline
Crook County, ILL
A couple years ago when we wanted to get the filler tube restored for my restoration, we found the guy who did the lead replating of the filler tubes wasn't doing it anymore.
I don't recall now who it was that was doing them then, though the restoration shop didn't know of anyone else who did this process other than the guy who stopped doing them.
Is Wilson still doing these?
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2322594
06/17/17 12:34 PM
06/17/17 12:34 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
I had Wilson do the one in my GTX last year. Came out great.
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2322629
06/17/17 02:17 PM
06/17/17 02:17 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You could do your own if you have a good torch set up?, if the original is in good shape just heat the entire tube until the lead solder is wet, then wipe it with a folded rag dampened with water, you have to work quickly! long strokes in an orderly fashion
If the tube's original finish needs to be removed along with rust/etc, sandblast the tube clean, then polish the tube with sandpaper to about a 400 grit finish, to re-coat it in lead solder, you'll need to dip the tube in Stainless Steel flux (hydrochloric acid)prior to tinning it with lead solder
Re: Refinishing gas filler and ECS tubes [Re: Neil] #2323239
06/18/17 08:01 PM
06/18/17 08:01 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
I bead blasted mine and used Tinning butter on it.Came out pretty nice.
