Page 2 of 4 1 2 3 4
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232208
02/22/09 02:36 AM
02/22/09 02:36 AM
Boise
Moparteacher Online content
Moparteacher  Online Content
Boise
Vegas!...OK..North Las Vegas. Autotmotive Instructor for the College of Southern Nevada.
Re: Front End Issues Continue to Haunt Me [Re: Moparteacher] #232209
02/22/09 03:52 AM
02/22/09 03:52 AM
Riverside, California
Lil Demon Offline OP
Cool - I'll come to the MATS a day early and you can teach your students how to fix bumpsteer on the car of an idiot who has mismatched parts - LOL!!! It's a win-win.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232210
02/22/09 04:41 AM
02/22/09 04:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You need a bumpsteer gauge for that too.
There is a scrub radius gauge too. I think you could find one through the circle track suppliers like Longacre. SAI measurement on an alignment rack and some calcs should get you close too.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232211
02/22/09 06:17 AM
02/22/09 06:17 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Lil Demon will be your "visual aid"
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232212
02/22/09 09:38 AM
02/22/09 09:38 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I will be at the Mats on vacation. I have a pretty good understanding of front suspension geometry. I would be glad to look at the car and go over it with you. I can show you how to measure the components so you can get it right. I don't think we could repair it at the track but I can steer you in the right direction.
Doug
Re: Front End Issues Continue to Haunt Me [Re: dvw] #232213
02/22/09 09:53 AM
02/22/09 09:53 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
+8 caster...is too much. I run +4..and 0 on camber ...Just my 2 cents
Re: Front End Issues Continue to Haunt Me [Re: VernMotor] #232214
02/22/09 10:08 AM
02/22/09 10:08 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
My car does the same thing as the video, but it does it when i launch.
I have a vid if anyone wants to see.
I think I might have found the problem, if it's caused by flexing?.
My question is....Should i be looking for possible component flexing to cure this OR is it the way the front end is aligned?
todd
Re: Front End Issues Continue to Haunt Me [Re: toddd] #232215
02/22/09 11:02 AM
02/22/09 11:02 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Your front end alingment is not your prob
Like stated above its the length of tie rods and postion of the tie rod that will cause bump steer.
I would bet that you also have a K frame that is flexing as well.
The force of the spindle wanting to twist when the brakes are applied is greater than you might think.
Bondo and I went all thru this last summer in Perfecting his steering arms and tie rod ends.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232216
02/22/09 11:42 AM
02/22/09 11:42 AM
usa
hot67cuda Offline
hot67cuda  Offline
usa
While in enginneering school my team was given a problem to solve the 560 benz front end shimmy on decellthat was causing crashes.Thay had 10 deg of positive caster on them.1/16 toe in,0 caster.What we found was on decell when the front end went down was the driver side would drop before the pas side would creating 1.5 difference in caster,<the grocerey cart effect>to corect this we had 2 adjest the upper control arm mounting points for caster gain.The second part is with 10deg of caster setting toe is very hard to do it takes several sweeps on the tables too get it right.
Re: Front End Issues Continue to Haunt Me [Re: hot67cuda] #232217
02/22/09 11:56 AM
02/22/09 11:56 AM
Roseau, MN
1976 Aspen Offline
1976 Aspen  Offline
Roseau, MN
It shakes only whenyou're braking??? Sounds like warped brake rotors too me Simple fix
Re: Front End Issues Continue to Haunt Me [Re: 1976 Aspen] #232218
02/22/09 11:59 AM
02/22/09 11:59 AM
I'm pretty sure the rotors are not warped, but I'll add that to the list of things to check.
Re: Front End Issues Continue to Haunt Me [Re: hot67cuda] #232219
02/22/09 12:03 PM
02/22/09 12:03 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Some of the guys here think 8*-10* is too much caster,
what do you think all of the fastest drag cars run.
I have about 10* on my car and I can let go of the
wheel anytime after the torque of the engine is done
trying to twist the car.... even on decell on top end.
Granted its a strut. You have to look at the distance
between the ball joint centerline to the center of the tire...
thats a substantial leverage arm to apply a load
to ANY weak points/parts. In production we didnt
put a dished wheel on just to clear the fender, its
put on to align the loads
Re: Front End Issues Continue to Haunt Me [Re: 1976 Aspen] #232220
02/22/09 12:06 PM
02/22/09 12:06 PM
south central,Pa
mopar_to_ya Offline
mopar_to_ya  Offline
south central,Pa
My LRT does the same thing about midway through the shutdown. If I lift off the brakes and re apply then it usually stops. But if you all are cracking steering arms, that scares me. I thought I was the only one out there with this problem. I guess I'll have to do some more checking.
Rob told me that the new steering arm design would fix any issues, but I never got any to find out for sure.
Re: Front End Issues Continue to Haunt Me [Re: MR_P_BODY] #232221
02/22/09 12:07 PM
02/22/09 12:07 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Your situation may be different but when I had my Dare the more bumpsteer I took out of it made no difference at all on the shake.
Re: Front End Issues Continue to Haunt Me [Re: mopar_to_ya] #232222
02/22/09 12:11 PM
02/22/09 12:11 PM
I have the new arms and never had this issue before putting them on. I'm not blaming them, just pointing out they could be a contributing factor.
Re: Front End Issues Continue to Haunt Me [Re: 540dust] #232223
02/22/09 12:12 PM
02/22/09 12:12 PM
I'ver always had bumpsteer, but never the shakes like this.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232224
02/22/09 12:13 PM
02/22/09 12:13 PM
Sherwood park, Alberta.
go green Offline
go green  Offline
I had the same problem in my Coronet .
I would have to drag the brakes two times before I could lean on them .
The Wilwood brake pad compound is junk .
I changed to a drag race pad it it help out huge.
I think I got them from strange ?
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232225
02/22/09 12:25 PM
02/22/09 12:25 PM
MR_P_BODY Offline
MR_P_BODY  Offline
All thats really happened is that with changing some
parts trying to get lighter you have found some weak
points, weather its a control arm or what ever, as soon
as you apply load to the tire on braking its twisting
the front end at the weak point. The guys with the
big off road tires have the same issues but they
cover it up with the damper on the steering... they
just found the weak point also. We already know its
not your alignment(if things dont change or bend)
because its not doing it during your run... this is
induced when you apply the brakes
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232226
02/22/09 03:17 PM
02/22/09 03:17 PM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Hey Bill first off be careful. Do you have the old arms still, maybe you can take a step back to get the car stable under braking. Just a question, could the arms be flexing during the run causing resistance and you to scrub speed. Good luck.
Re: Front End Issues Continue to Haunt Me [Re: 68Fastback] #232227
02/22/09 04:05 PM
02/22/09 04:05 PM
Port Alberni, British Columbia
MoparDonny Offline
MoparDonny  Offline
Not that I know ANYTHING about front end geometry, but could some of this be avoided if the brake bias was a little more generous to the rear brakes? Within reason and safety of course.
Just thinking out loud.
Don.
Page 2 of 4 1 2 3 4
