Page 1 of 4 1 2 3 4
Front End Issues Continue to Haunt Me #232188
02/22/09 12:13 AM
02/22/09 12:13 AM
Riverside, California
Lil Demon Offline OP
I am getting so sick of this front end that I cannot stand it. To fix my previous bump steer issues, I spent money and bought new steering arms from LRT, adjustable tie rod ends, factory spindles, and put coil overs on it.
The car aligned great for the first time since I've owned with no issues going forward or backward - woohoo - problem solved and money well spent. Not so fast...........
Today - the car goes straight as an arrow down the track, I cross the stripe and let off and hit the brake - vicious - and I mean vicious front end shake. So bad that I couldn't see - I wanted to pull the parachute handle but was afraid to let go of steering wheel - it was that bad.
I went back to Les Schwab where we aligned it last night. The caster is at +8 (as much as it can get), the camber is at -1.8, and it was neutral on the toe.
Guys with fast(I know that is relative) back half-4 link cars - what are your front settings? Others - any recommendations?
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232189
02/22/09 12:23 AM
02/22/09 12:23 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I run about 10* caster, 0 camber and 0 toe in. It
sounds like you have something flexing.... were your
wheel bearings tight/snug
EDIT
Also Bill was the front alignment done with the body
up 1"... check your toe in at 1" up... it could be
going toe out and thats not good
Re: Front End Issues Continue to Haunt Me [Re: MR_P_BODY] #232190
02/22/09 12:33 AM
02/22/09 12:33 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Yeah, I'd have some toe in it. At least a 32nd, but I'd try a 1/16 to see if it helps. I've never had luck with neutral toe on anything, even tube cars.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232191
02/22/09 12:34 AM
02/22/09 12:34 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Got 8 caster, 0 camber, and less than .0625" toe in. Do you have an aftermarket front end ?
Re: Front End Issues Continue to Haunt Me [Re: dthemi] #232192
02/22/09 12:36 AM
02/22/09 12:36 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I agree..For me 1/16"+- has always worked well in a back half car. You might also just give the front a once over, always a good idea. Never checked that driver side bearing at the track.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232193
02/22/09 12:47 AM
02/22/09 12:47 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
If its running straight as a arrow down the track and going into shimmy on decell, you still have some Bump steer or some kind of flex issues or both going on.
Your numbers on the caster are fine but why the -1.5* on the camber. Id want that at 0*
Whats the rest of the front suspension steering setup. I take it that it has a R/P in it. mike
Re: Front End Issues Continue to Haunt Me [Re: Sport440] #232194
02/22/09 12:50 AM
02/22/09 12:50 AM
Farmington Hills, Mich
Chuck@Best_Machine Offline
I had the same problem, the LRT lower arms are flexing
Re: Front End Issues Continue to Haunt Me [Re: Chuck@Best_Machine] #232195
02/22/09 12:51 AM
02/22/09 12:51 AM
#2
Re: Front End Issues Continue to Haunt Me [Re: Chuck@Best_Machine] #232196
02/22/09 12:51 AM
02/22/09 12:51 AM
#3
Re: Front End Issues Continue to Haunt Me [Re: Chuck@Best_Machine] #232197
02/22/09 12:55 AM
02/22/09 12:55 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The flex would make it go into bump steer, some generous toe would make it better I think. I know it's a band aid, but it's always been a cure all for the brake watoosie.
Re: Front End Issues Continue to Haunt Me [Re: Chuck@Best_Machine] #232198
02/22/09 12:59 AM
02/22/09 12:59 AM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
Had the same problem with the LRT front end on the duster. Also found some cracks in the lower arm. Repaired arm and it is now acceptable.
76 Duster work in progress
Re: Front End Issues Continue to Haunt Me [Re: Edge] #232199
02/22/09 01:12 AM
02/22/09 01:12 AM
My front end is very bastardized. Stock front clip, DARE K-Frame (on it when I bought it - I didn't know), Magnum Force tubular uppers (non-adjustable), Stock LCAs, LRT steering arms, Flaming River Pinto R/P, Aldan coil overs.
Looking at the vids - the wheels are definitely toeing out when it lifts them in the air.
So - if I set the toe at ride height +1" - do I set it at 1/16" in?
The negative caster I think may be the best it can get - not sure. I may need adjustable UCAs
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232200
02/22/09 01:19 AM
02/22/09 01:19 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Yeah, make it pigeon toed, I'd get my fattest buddy to sit on the front end after you set it and roll it forward about 5 feet and check it there too. I know the brake load pulls the arms back and you can't really simulate that, but it will let you know about how it travels.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232201
02/22/09 01:22 AM
02/22/09 01:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Yes set the toe at 1/16 in at 1" up on the body. I
assume you just made a error in saying caster instead
of camber but you would be better off with adjustable
UCA's
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232202
02/22/09 01:35 AM
02/22/09 01:35 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Re: Front End Issues Continue to Haunt Me [Re: 540dust] #232203
02/22/09 01:37 AM
02/22/09 01:37 AM
Does it kinda do this:
http://videos.streetfire.net/video/145946.htm
That's what it feels like it is doing when I lift and hit the brake.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232204
02/22/09 01:44 AM
02/22/09 01:44 AM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Well, that wasnt mine but I did have a Dare and it would do that too. I fought it for a while and finally got rid of it. My conclusion was that it was just not strong enough and was flexing. I don't have the problem with the RMS that I have in it now. In my situation, anytime that you would load the suspension, by braking or hitting any bumps or rough spots, (my home track is kinda rough in the shutdown), it would do just this same kind of shake. I could get off the brakes and touch the throttle a little to unload it and it would go away, this would play hell with you stopping distance though, not a safe situation. You have a PM.
Re: Front End Issues Continue to Haunt Me [Re: 540dust] #232205
02/22/09 01:51 AM
02/22/09 01:51 AM
That's what I did on the last two runs - instead of hitting the brakes and lifting, I drug them a bit and slowly rolled off and would get back on it a little to bring it back up. Used all of the runout doing that. Anything shorter and I would have to pull the chute - which would just be embarrassing in a 9.30 car.
Re: Front End Issues Continue to Haunt Me [Re: Lil Demon] #232206
02/22/09 02:24 AM
02/22/09 02:24 AM
Boise
Moparteacher Offline
Boise
The length of the inner-to-outer tie rod must be equal to the length of the lower control arm (pivot to pivot). They must also rise and drop in a parallel plain. Anything different and you get a change in toe as the suspension goes through jounce and rebound, in other words "bump steer".
The outer tie rod can be shimmed toward or away from the knuckle to obtain the parallel travel, but a rack-n-pinion (inner/outer tie rod) that doesn't match the length of the lower control arms gets a little more complicated.
You can heat and bend the lower ball joint arm up and down or inward or outward to help achieve the equal length and parallel, but only so far.
The Mopar chassis book shows you how to graph changes in toe throughout jounce and rebound and how to correct it. It works for any LSA suspension, but with miss-matched parts there may be only one solution and that's to purchase parts that are engineered to work together.
When it's all said and done camber should be at or near zero regardless. Cross-camber and cross-caster should be less than .5 degree. Preferably zero for a flat track. Excessive positive caster will cause rapid wheel shimmy. You need only enough positive caster to maintain directional stability.
One last thing. Excessive positive scrub radius will put an excessive load on the suspension components and could be a cause for flexing and cracking.
Positive scrub radius occurs when the alignment of the upper and lower ball joints meets the road inside of the point at which the center of the tire meets the road.
Positive scrub radius results from using smaller diameter wheels and tires and/or using a wheel that has little or no offset (common with front runners).
Some positive scrub radius is OK; it's the excessive that causes problems.
Good luck
Re: Front End Issues Continue to Haunt Me [Re: Moparteacher] #232207
02/22/09 02:31 AM
02/22/09 02:31 AM
Good luck
You know your stuff - now - how close to Rocklin, CA are you?
Page 1 of 4 1 2 3 4
