Hemi Spark Plugs #2321248
06/14/17 07:34 PM
06/14/17 07:34 PM
Morristown Tn.
71birdJ68 Offline OP
Morristown Tn.
Question? How can oil work its way inside the spark plug tube? I have Stage V heads which have a o ring between the tube and the head. Stock tubes, and stock repo valve covers.
Re: Hemi Spark Plugs [Re: 71birdJ68] #2321365
06/14/17 11:56 PM
06/14/17 11:56 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
If your spark plugs still have the "compression washer" on them from the plug mfg, then that's your cause 9 out of 10 times, the tube is your "compression washer", on a HEMI you remove the plugs compression washer before installing them, if this is the case, you may be able to rework the tube ends, otherwise if they are badly drawn you need a new set of tubes
Re: Hemi Spark Plugs [Re: DAYCLONA] #2321417
06/15/17 01:47 AM
06/15/17 01:47 AM
Morristown Tn.
Morristown Tn.
Ok, makes sense. Thanks
Re: Hemi Spark Plugs [Re: 71birdJ68] #2321445
06/15/17 02:24 AM
06/15/17 02:24 AM
You probably need the Stage V spark plug tubes to make those seal seal shruggy
Do the stock tube press hard into those heads? If not and they push in easy there not sealing tight up against them scope
Re: Hemi Spark Plugs [Re: DAYCLONA] #2321519
06/15/17 09:32 AM
06/15/17 09:32 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
Why would they be ruined? What is leaving the washer on going to do to them, that a taking it off wouldn't do? If anything, I would expect taking the washers off to have a better chance of ruining the end of the tubes.
Not meant to be an aggressive response just genuinely curious. I'm Running RC12YC Champions with the washers in factory heads with a MP plug tube set. I have to take my covers off a couple times a year to lash valves and I see the tube ends every time. So far so good I guess.
I have a preset valve adjuster torque wrench that I also use to torque the plugs because its convenient. The 22ftlbs preset may be not enough to deform the tubes possibly...
Re: Hemi Spark Plugs [Re: Cab_Burge] #2321538
06/15/17 10:32 AM
06/15/17 10:32 AM
Morristown Tn.
Morristown Tn.
Let me call Stage V and ask about their tubes. I can feel a resistance when installing the tubes, but it's not very much.
Re: Hemi Spark Plugs [Re: 71birdJ68] #2321781
06/15/17 08:22 PM
06/15/17 08:22 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My stock tubes fit snug in my Stage V heads. On the spark plug rings, I contacted a well known Hemi builder named Bob George about that, he stated to leave them on, so I did.
Re: Hemi Spark Plugs [Re: rowin4] #2321896
06/15/17 11:38 PM
06/15/17 11:38 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
popcorn
Re: Hemi Spark Plugs [Re: Cab_Burge] #2321941
06/16/17 12:54 AM
06/16/17 12:54 AM
Morristown Tn.
Morristown Tn.
Stage V heads have a o ring to seal the tube, but like I said it is not real tight.
Re: Hemi Spark Plugs [Re: 73DAD] #2322033
06/16/17 10:08 AM
06/16/17 10:08 AM
an8sec70cuda Offline
Curious about this myself. I don't see how the "extra" compression washer on the plug will do any damage. I've been running NGK plugs w/ the compression washers on them in mine forever. Same set of plug tubes since 2006 and I've changed plugs a LOT.
CHIP
'06 GMC 2500HD LBZ Duramax
