Hemi Spark Plugs
#2321248
06/14/17 07:34 PM
06/14/17 07:34 PM
Posts: 4,456 Morristown Tn.
71birdJ68
Morristown Tn.
Question? How can oil work its way inside the spark plug tube? I have Stage V heads which have a o ring between the tube and the head. Stock tubes, and stock repo valve covers.
Re: Hemi Spark Plugs
[Re: DAYCLONA]
#2321519
06/15/17 09:32 AM
06/15/17 09:32 AM
Posts: 315 Northeast Indiana
73DAD
Northeast Indiana
If your spark plugs still have the "compression washer" on them from the plug mfg, then that's your cause 9 out of 10 times, the tube is your "compression washer", on a HEMI you remove the plugs compression washer before installing them, if this is the case, you may be able to rework the tube ends, otherwise if they are badly drawn you need a new set of tubes Why would they be ruined? What is leaving the washer on going to do to them, that a taking it off wouldn't do? If anything, I would expect taking the washers off to have a better chance of ruining the end of the tubes. Not meant to be an aggressive response just genuinely curious. I'm Running RC12YC Champions with the washers in factory heads with a MP plug tube set. I have to take my covers off a couple times a year to lash valves and I see the tube ends every time. So far so good I guess. I have a preset valve adjuster torque wrench that I also use to torque the plugs because its convenient. The 22ftlbs preset may be not enough to deform the tubes possibly...
[Re: Cab_Burge]
#2321538
06/15/17 10:32 AM
06/15/17 10:32 AM
71birdJ68
Morristown Tn.
Let me call Stage V and ask about their tubes. I can feel a resistance when installing the tubes, but it's not very much.
[Re: 71birdJ68]
#2321781
06/15/17 08:22 PM
06/15/17 08:22 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
My stock tubes fit snug in my Stage V heads. On the spark plug rings, I contacted a well known Hemi builder named Bob George about that, he stated to leave them on, so I did.
[Re: rowin4]
#2321896
06/15/17 11:38 PM
06/15/17 11:38 PM
Posts: 15,457 Omaha Ne
TJP
Omaha Ne
[Re: 73DAD]
#2322033
06/16/17 10:08 AM
06/16/17 10:08 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
If your spark plugs still have the "compression washer" on them from the plug mfg, then that's your cause 9 out of 10 times, the tube is your "compression washer", on a HEMI you remove the plugs compression washer before installing them, if this is the case, you may be able to rework the tube ends, otherwise if they are badly drawn you need a new set of tubes Why would they be ruined? What is leaving the washer on going to do to them, that a taking it off wouldn't do? If anything, I would expect taking the washers off to have a better chance of ruining the end of the tubes. Not meant to be an aggressive response just genuinely curious. I'm Running RC12YC Champions with the washers in factory heads with a MP plug tube set. I have to take my covers off a couple times a year to lash valves and I see the tube ends every time. So far so good I guess. I have a preset valve adjuster torque wrench that I also use to torque the plugs because its convenient. The 22ftlbs preset may be not enough to deform the tubes possibly... Curious about this myself. I don't see how the "extra" compression washer on the plug will do any damage. I've been running NGK plugs w/ the compression washers on them in mine forever. Same set of plug tubes since 2006 and I've changed plugs a LOT.
