Need some advice on on heads and cam #232088
02/21/09 10:54 PM
02/21/09 10:54 PM
New Hampshire
n_bogie1984 Offline OP
New Hampshire
ok so here is my build any advice would be great
this motor goes in a "stock" pulling truck
440 bored to 4.383 cut to just about zero deck
4.15 forged crank
6.76 eagle rods
srp dual valve releif pistons 12 to 1 comp
motor is fully balanced
curently running 915 heads with minor work.
mp .484 hyd grind at the time being.
67 hp intake, with a holley 850 that has been worked to 1000 cfm
my classes rules are:
no alum intakes, single 4 barrell only with max 1 inch carb spacer.
no domed or quench pistons
max .490 lift at the valve
alum. heads allowed
no power adders
max of 95 oct fuel.
and thats all the rules as far as motor.
now here is the problem 3 of the top 5 guys myself included are all running 440's lol
1 is running a stock stroke 440 with flat tops and stealth heads. im blowing him away.
the other on the other hand is running a 496 stroker, zero deck, indy ez heads, full msd ign. system, custom ground cam, and is blowing me away.
so i need to step it up and your here to help me.
working on a budget of about 3000
route i am thinking is full roller with victor heads. people claim the heads are over kill for the cam, yet most dont realize this big block is turning 7500-8500 rpms
his a video for a guide (BTW the red dodge behind me is the one with the indy ez's)
http://www.youtube.com/watch?v=5OqrBKRsYaU
Re: Need some advice on on heads and cam [Re: n_bogie1984] #232089
02/21/09 11:08 PM
02/21/09 11:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Ya found the right forum .
My first question is, are all you 440 guys running the same intake?
The second thing is you need a SS cheater cam...I don't know anything about them.
Re: Need some advice on on heads and cam [Re: RemCharger] #232090
02/21/09 11:10 PM
02/21/09 11:10 PM
New Hampshire
New Hampshire
i have read some on the ole stock cheater camd cd used to make idk how it performed with over 340 duration. the guy with the stealths i think is running a thermoquad, and the guy with the indys had 5 intakes sent out and flowed and then had the best one ported, he wont give me numbers, but he claims it to be a early 70's smog intake
Re: Need some advice on on heads and cam [Re: n_bogie1984] #232091
02/21/09 11:18 PM
02/21/09 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Well go at least ez's ported and 490 lift with about
280+ duration maybe on a 110 lsa installed about 106
Re: Need some advice on on heads and cam [Re: MR_P_BODY] #232092
02/21/09 11:59 PM
02/21/09 11:59 PM
Colorado
506RR Offline
506RR  Offline
Colorado
Fully ported set of Indy SR Heads! Contact Dwayne Porter (fast68plymouth). He will set you up!
Re: Need some advice on on heads and cam [Re: 506RR] #232093
02/22/09 12:30 AM
02/22/09 12:30 AM
New Hampshire
New Hampshire
the flow numbers of the victors seem better with no work to them yet, and idk about the whole oiling lines, i would like to keep it somewhat stock appearing, plus the price tag those srs seem little high
Re: Need some advice on on heads and cam [Re: n_bogie1984] #232094
02/22/09 12:36 AM
02/22/09 12:36 AM
New Hampshire
New Hampshire
now that i look the guy is like a hr from me lol, thanks for the hook up ill see what he thinks
Re: Need some advice on on heads and cam [Re: n_bogie1984] #232095
02/22/09 12:40 AM
02/22/09 12:40 AM
Central NC
gch Offline
gch  Offline
Central NC
You need a custom ground cam for your motor.Decide on your heads first.Have porting maximized for .200 thru .500 since you have a cam rule.
Hughes engines has done a fair amount of intake research and porting.They do cast iron units as well.Check with Dave and see what he thinks.
Indy EZ'S might be the way to go if you don't want oil lines.
Dwayne(fast 68) is pretty darn good(as are several other members).
Re: Need some advice on on heads and cam [Re: n_bogie1984] #232096
02/22/09 12:48 AM
02/22/09 12:48 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can get a set of EZ'z for under $2000.00 from a few places and that leaves some money left over for the good flat cam and and some iron adjustable rockers.
Gus
64 Plymouth Savoy
Dana 60
