Mounting the Mopar orange box on a 70 b body #2320544
06/13/17 02:04 PM
06/13/17 02:04 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Does anyone have any pics of where they mounted their orange box on a b body. I want to put it on the back fire wall. But don't want to drill into anything important on the other side. realcrazy Thanks
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2320665
06/13/17 05:58 PM
06/13/17 05:58 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
I put mine on the bottom of the battery tray. Had to lengthen the wiring of course. Clean looking and box is protected from heat. Drilling into the firewall risks damaging the heater/AC unit.
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2320717
06/13/17 07:19 PM
06/13/17 07:19 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
I have installed the boxes on several late 60's and early 70's cars without a problem. Always installed them on the firewall. Make sure you drill just deep enough to go through the firewall and you should be fine. I mounted mine near the voltage regulator.
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2320862
06/13/17 11:26 PM
06/13/17 11:26 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
On my 70 Coronet, I put mine behind the Passenger side headlight, taped in the harness with the engine harness, firewall still look's OE
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2320906
06/14/17 01:03 AM
06/14/17 01:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On my 63 Sport Fury I mounted mine on the firewall. Ron
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2320919
06/14/17 01:27 AM
06/14/17 01:27 AM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Someone offers a bracket to mount it on the engine-using the rear intake turkey pan hold down bolts. Clean and out of sight.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2321926
06/16/17 12:27 AM
06/16/17 12:27 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I mounted mine behind the grill on the right side core support. 70 Beeper.
Nautilus Racing-
Re: Mounting the Mopar orange box on a 70 b body [Re: 469runner] #2323430
06/19/17 02:44 AM
06/19/17 02:44 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
X2 . . . did same thing on my 70 Sport Satellite !!
Re: Mounting the Mopar orange box on a 70 b body [Re: a12rag] #2323446
06/19/17 04:40 AM
06/19/17 04:40 AM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
The best method is to ditch it and that crap distributor and go Firecore.
I’m listening.
Re: Mounting the Mopar orange box on a 70 b body [Re: Big Bad Bee] #2323643
06/19/17 03:33 PM
06/19/17 03:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Agreed , I put mine in the dumpster at work , the orange box is an old outdated crap design .
Re: Mounting the Mopar orange box on a 70 b body [Re: EWJ] #2323736
06/19/17 06:14 PM
06/19/17 06:14 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
That is Rocket Restorations.
Bracket
I used one on my A12. Most folks don't even notice it back there, especially with the air cleaner on. I don't use the Mopar orange box any longer either. My "new" ignition of choice has been the Rev-n-nator with built in rev limiter.
Stan
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2324027
06/20/17 08:33 AM
06/20/17 08:33 AM
Nebraska
Nebraska
Thanks guys, I do have the Rev-n-ator. But I thought id get more replies with the more common orange box.
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2324198
06/20/17 02:07 PM
06/20/17 02:07 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
Mount 2 so you don't have to walk when one fails.
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2324521
06/21/17 02:21 AM
06/21/17 02:21 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I mounted mine down on the frame rail just below the alternator. I have run the Chrome box no problems for many years. Also I have an MSD box EZ to swap out with the Chrome box but my preference is to run the Chrome box vs. the MSD, engine starts easier and run smoother even with a big cam..
Just my $0.02... wink
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2325722
06/23/17 01:51 PM
06/23/17 01:51 PM
Nebraska
Nebraska
Thanks Hemistan, one coming my way
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2325747
06/23/17 02:46 PM
06/23/17 02:46 PM
dogdays Offline
dogdays  Offline
I mounted mine right on the firewall behind the distributor. It ran that way for years.
Here are two points about pointless ignition:
1. Keep the signal cable short. That's the cable from the distributor pickup. The longer the cable, the greater the chance of EMI.
2. Keep the signal cable twisted. That helps the linterference to cancel out. When I ran my box away from the engine I used a twisted pair cable for the connector. Even better would be a twisted shielded pair with one end of the shield grounded.
R.
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2326024
06/24/17 08:09 AM
06/24/17 08:09 AM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I think you will like it! It is a nice product.
Stan
Re: Mounting the Mopar orange box on a 70 b body [Re: 74RALLYE] #2326079
06/24/17 12:36 PM
06/24/17 12:36 PM
Ding ding ding I (do) believe we have a winna
Re: Mounting the Mopar orange box on a 70 b body [Re: 70VcodeCoronetRT] #2326174
06/24/17 06:24 PM
06/24/17 06:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have always carried an extra orange box , coil and electric fuel pump but have never needed any of them. But its best to be prepared in case. I dont run the ballast as I bypassed it 2 years ago and running my orange box and Acell supercoil it does not need it. The coil never gets hot and its worked good for two years so far. Ron
