Re: Mounting the Mopar orange box on a 70 b body
[Re: 70VcodeCoronetRT]
#2320862
06/13/17 11:26 PM
06/13/17 11:26 PM
Posts: 5,783 Corpus Christi, TX
shanker
Corpus Christi, TX
On my 70 Coronet, I put mine behind the Passenger side headlight, taped in the harness with the engine harness, firewall still look's OE
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
#2320919
06/14/17 01:27 AM
06/14/17 01:27 AM
Posts: 3,464 Back in NJ....
EWJ
Back in NJ....
Someone offers a bracket to mount it on the engine-using the rear intake turkey pan hold down bolts. Clean and out of sight.
Ed EastCoast Land Yacht Assoc. 1967 Newport Conv: 440/4 speed 1969 GTX: 440/4 speed, TX9/TX9, A34, N96 1970 Super Bee: 383/4 speed, B5/B7 1970 Coronet RT: 440/4 speed, A34, N96 1970 Coronet RT: 440/auto, A36, N96 1970 Road Runner convertible: 383/4 speed TX9/D6XW 1970 GTX: 440+6/727, A32, N96 2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed "The early bird may get the worm, but the 2nd mouse gets the cheese".
#2321926
06/16/17 12:27 AM
06/16/17 12:27 AM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I mounted mine behind the grill on the right side core support. 70 Beeper.
[Re: 469runner]
#2323430
06/19/17 02:44 AM
06/19/17 02:44 AM
Posts: 2,914 Calgary, Alberta Canada
a12rag
I put mine on the bottom of the battery tray. Had to lengthen the wiring of course. Clean looking and box is protected from heat. Drilling into the firewall risks damaging the heater/AC unit. X2 . . . did same thing on my 70 Sport Satellite !!
[Re: a12rag]
#2323446
06/19/17 04:40 AM
06/19/17 04:40 AM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
The best method is to ditch it and that crap distributor and go Firecore.
I’m listening.
[Re: Big Bad Bee]
#2323643
06/19/17 03:33 PM
06/19/17 03:33 PM
Posts: 74,948 U.S.S.A.
JohnRR
U.S.S.A.
The best method is to ditch it and that crap distributor and go Firecore. Agreed , I put mine in the dumpster at work , the orange box is an old outdated crap design .
[Re: EWJ]
#2323736
06/19/17 06:14 PM
06/19/17 06:14 PM
Posts: 1,672 Virginia
HemiStan
Virginia
Someone offers a bracket to mount it on the engine-using the rear intake turkey pan hold down bolts. Clean and out of sight. That is Rocket Restorations. Bracket I used one on my A12. Most folks don't even notice it back there, especially with the air cleaner on. I don't use the Mopar orange box any longer either. My "new" ignition of choice has been the Rev-n-nator with built in rev limiter. Stan
#2326024
06/24/17 08:09 AM
06/24/17 08:09 AM
HemiStan
Virginia
Thanks Hemistan, one coming my way I think you will like it! It is a nice product. Stan
[Re: 74RALLYE]
#2326079
06/24/17 12:36 PM
06/24/17 12:36 PM
RapidRobert
Mount 2 so you don't have to walk when one fails. Ding ding ding I (do) believe we have a winna
#2326174
06/24/17 06:24 PM
06/24/17 06:24 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have always carried an extra orange box , coil and electric fuel pump but have never needed any of them. But its best to be prepared in case. I dont run the ballast as I bypassed it 2 years ago and running my orange box and Acell supercoil it does not need it. The coil never gets hot and its worked good for two years so far. Ron
