The orange wire on this truck is there, but looks to have had it pulled out of the terminal. Need to trace it to see if it's hooked up, cause if it is, I can't believe it wasn't sparking/blowing fuses the way it was just up in the housing. I may grab some blue LED strip lights and solder them in and then box it in to keep it from shining down the column at the dash. Mopar show this weekend here locally, so I'll see if anything is there. Might call one salvage yard to see if they have anything, but the LED strip will work if needed. It's on a friend's truck, and he just needs to be able to see the indicator. Not an OEM restoration type of need, LOL. Thanks again.
