1978 D150 A/T column shift indicator light #2317631
06/07/17 01:48 PM
06/07/17 01:48 PM
near Kansas City
igozumn Offline OP
igozumn  Offline OP
near Kansas City
Anybody have a picture of the light that illuminates the shift indicator? This is all that was in the back side. Wire just left hanging.
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2317973
06/08/17 09:16 AM
06/08/17 09:16 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
Yours looks different?
This column is out of a 1977 D150 Warlock I believe.
Bulb appears to be a GE 158 with a blue rubber cover.
Hope this helps?
Red
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2317986
06/08/17 10:01 AM
06/08/17 10:01 AM
near Kansas City
igozumn Offline OP
igozumn  Offline OP
near Kansas City
Awesome! Yes! Thank you! Now I know what I'm looking for. Thanks again.
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2317987
06/08/17 10:15 AM
06/08/17 10:15 AM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
I went digging in the parts manual to compare 77 to 78
Was able to find wiring / lamp but could only find it for 77 as my other manual is 78-81 and laid out his differently.
Is it possible 78 up are not lighted?
My 78's are long gone.
BTW the "lamp" part # is 3635480 and points to where the wiring plugs into insulator and terminals. Lamp use w/Auto Trans.
Red
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2318067
06/08/17 12:53 PM
06/08/17 12:53 PM
near Kansas City
igozumn Offline OP
igozumn  Offline OP
near Kansas City
The orange wire on this truck is there, but looks to have had it pulled out of the terminal. Need to trace it to see if it's hooked up, cause if it is, I can't believe it wasn't sparking/blowing fuses the way it was just up in the housing. I may grab some blue LED strip lights and solder them in and then box it in to keep it from shining down the column at the dash. Mopar show this weekend here locally, so I'll see if anything is there. Might call one salvage yard to see if they have anything, but the LED strip will work if needed. It's on a friend's truck, and he just needs to be able to see the indicator. Not an OEM restoration type of need, LOL. Thanks again.
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2319194
06/11/17 12:15 AM
06/11/17 12:15 AM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
That lamp is the same from 72-80 non-tilt trucks
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2320582
06/13/17 03:08 PM
06/13/17 03:08 PM
near Kansas City
igozumn Offline OP
igozumn  Offline OP
near Kansas City
Thank you. I have a work-around figured out in my head, but now I can widen my search a bit.
Re: 1978 D150 A/T column shift indicator light [Re: igozumn] #2320680
06/13/17 06:20 PM
06/13/17 06:20 PM
near Kansas City
igozumn Offline OP
igozumn  Offline OP
near Kansas City
Just found one (several) on ebay. Thanks again for everyone's help!
