68 dart with a big block header help #2320124
06/12/17 08:02 PM
06/12/17 08:02 PM
south central nebraska
GI Moparman Offline OP
I'm in the process of building a 68 dart and wanting to run my Indy -1 headed 440 in it without using fender well headers. Called tti and they said they don't make a header. What are you guys doing for this combo?
Re: 68 dart with a big block header help [Re: GI Moparman] #2320141
06/12/17 08:30 PM
06/12/17 08:30 PM
Custom made set sounds like the only way now shruggy
I bought two pair of header flanges(one set of 2 1/8 and one set of 2 1/14)with the stubs welded on made by Hedman for the Indy 440-1 heads from Summit scope thumbs
IHTHs
Re: 68 dart with a big block header help [Re: GI Moparman] #2320156
06/12/17 08:52 PM
06/12/17 08:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't know how different the 68's are from say a Duster..... But I know of a few who run those heads on rb blocks with the pro-parts(mazzolini) headers.
Those are semi-fender well....... 2 tubes each side go out around the frame rail, but are under chassis exit.
If you use a low deck block, then the std TTi's are supposed to fit.
Re: 68 dart with a big block header help [Re: fast68plymouth] #2320191
06/12/17 09:51 PM
06/12/17 09:51 PM
Thanks for the input! I'll check out the proparts (mazolini) headers. I've done it before but really don't wanna build headers
Re: 68 dart with a big block header help [Re: GI Moparman] #2320210
06/12/17 10:35 PM
06/12/17 10:35 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Sounds like a good candidate for a tube K, coil overs, and rack steering.
Re: 68 dart with a big block header help [Re: GI Moparman] #2320213
06/12/17 10:41 PM
06/12/17 10:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I do not have the raised exhaust port 440-1's, but I do run EZ1 heads in my RB Duster, I love the fender well headers. Mine are an old set...Going to upgrade to Headman headers.
Tons of room around the engine, and easily take the diaper on and off.
I do run a Magnum Force front end though...
Re: 68 dart with a big block header help [Re: Dragula] #2321241
06/14/17 07:20 PM
06/14/17 07:20 PM
N.Y.
sixpacksteve Offline
N.Y.
if you have the stomach for it. go with fenderwell headers.
you'll never look back. also hedman headers would be the ones.
Hell Hath No Fury Like Mine
Re: 68 dart with a big block header help [Re: GI Moparman] #2321263
06/14/17 08:29 PM
06/14/17 08:29 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Just had custom headers made for my 68 Cuda....
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: 68 dart with a big block header help [Re: GI Moparman] #2321265
06/14/17 08:33 PM
06/14/17 08:33 PM
Virginia Beach, VA
O
Old School Offline
Old School  Offline
O
Virginia Beach, VA
Plenty of room especially around the plugs
Re: 68 dart with a big block header help [Re: GI Moparman] #2321446
06/15/17 02:24 AM
06/15/17 02:24 AM
fresno ca
mikeysmopars Offline
fresno ca
This one of those "if you can solve this, the rest of your life will be easy" kind of challenges. Personally hate in chassis headers. Had some made for mine but not a street car.easy to work on everything!
Founder and CEO of the Central Valley Mopar Drag Pack
Re: 68 dart with a big block header help [Re: GI Moparman] #2321481
06/15/17 05:16 AM
06/15/17 05:16 AM
You have a Pm on this thumbs
