Re: 68 dart with a big block header help
[Re: GI Moparman]
#2320141
06/12/17 08:30 PM
06/12/17 08:30 PM
Posts: 43,176 Bend,OR USA
Cab_Burge
Custom made set sounds like the only way now I bought two pair of header flanges(one set of 2 1/8 and one set of 2 1/14)with the stubs welded on made by Hedman for the Indy 440-1 heads from Summit IHTHs
[Re: GI Moparman]
#2320156
06/12/17 08:52 PM
06/12/17 08:52 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don't know how different the 68's are from say a Duster..... But I know of a few who run those heads on rb blocks with the pro-parts(mazzolini) headers. Those are semi-fender well....... 2 tubes each side go out around the frame rail, but are under chassis exit.
If you use a low deck block, then the std TTi's are supposed to fit.
[Re: GI Moparman]
#2320213
06/12/17 10:41 PM
06/12/17 10:41 PM
Posts: 12,388 Taxes & Virus's R-US, NY
Dragula
I do not have the raised exhaust port 440-1's, but I do run EZ1 heads in my RB Duster, I love the fender well headers. Mine are an old set...Going to upgrade to Headman headers. Tons of room around the engine, and easily take the diaper on and off. I do run a Magnum Force front end though...
[Re: Dragula]
#2321241
06/14/17 07:20 PM
06/14/17 07:20 PM
Posts: 1,468 N.Y.
sixpacksteve
N.Y.
if you have the stomach for it. go with fenderwell headers. you'll never look back. also hedman headers would be the ones.
Hell Hath No Fury Like Mine
[Re: GI Moparman]
#2321263
06/14/17 08:29 PM
06/14/17 08:29 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Just had custom headers made for my 68 Cuda....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: GI Moparman]
#2321265
06/14/17 08:33 PM
06/14/17 08:33 PM
Old School
Virginia Beach, VA
Plenty of room especially around the plugs
[Re: GI Moparman]
#2321446
06/15/17 02:24 AM
06/15/17 02:24 AM
Posts: 1,608 fresno ca
mikeysmopars
fresno ca
I'm in the process of building a 68 dart and wanting to run my Indy -1 headed 440 in it without using fender well headers. Called tti and they said they don't make a header. What are you guys doing for this combo? This one of those "if you can solve this, the rest of your life will be easy" kind of challenges. Personally hate in chassis headers. Had some made for mine but not a street car.easy to work on everything!
Founder and CEO of the Central Valley Mopar Drag Pack
