lake wood scatter sheild #2319273
06/11/17 03:21 AM
06/11/17 03:21 AM
United states wisconsin
bigblockbryan Offline OP
okay i have a old lakewood scatter sheild here is my question i have a 130 tooth flywheel it appears that the starter wont work.Does anyone know if there is a aftermarket starter that will fit i really dont want to go to the the 143 because i have. a brand new clutch kit on this flywheel just wondering if theres any option aside buying a diffrent bell housing or diffrent ring gear thanks
Re: lake wood scatter sheild [Re: bigblockbryan] #2319279
06/11/17 03:57 AM
06/11/17 03:57 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I believe there is a bracket you bolt in that makes the starter fit that flywheel.
Re: lake wood scatter sheild [Re: bigblockbryan] #2319288
06/11/17 05:02 AM
06/11/17 05:02 AM
Does it have multiple starter mounting holes? If so and it has a hole for the starter nose adapter then you should be able to use both the 143 and 130 tooth flywheels, if it doesn't have the starter nose hole and only has one set of mounting holes it may be for a 170 tooth Hemi motor and flywheel shock scope
Re: lake wood scatter sheild [Re: bigblockbryan] #2319349
06/11/17 11:48 AM
06/11/17 11:48 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Lakewood 15905 starter adapter kit. Good luck finding one !! Maybe Brewers ??
Re: lake wood scatter sheild [Re: bigblockbryan] #2319377
06/11/17 12:58 PM
06/11/17 12:58 PM
yep googled the part number found one got it on its way i wonder why there so hard to find must not have sold enough of them i guess
Re: lake wood scatter sheild [Re: bigblockbryan] #2319906
06/12/17 02:34 PM
06/12/17 02:34 PM
dogdays Offline
dogdays  Offline
Here's another option - have the flywheel that works drilled for the pressure plate you want to use. Should be done long before you find the adapter, if what everyone says is an indication.
Cost me $35 when I did it for my $500 ford pickup.
R.
Re: lake wood scatter sheild [Re: dogdays] #2320567
06/13/17 02:44 PM
06/13/17 02:44 PM
thanks i think thats what going to happen i just recieved a email they canncelled my order there out of stock summitt is un availble and so is brewers
Re: lake wood scatter sheild [Re: bigblockbryan] #2320587
06/13/17 03:15 PM
06/13/17 03:15 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I have same scatter shield and needed that kit too. I gave up and went back to a stock bell housing. I had already bought brand new flywheel, twin disc clutch setup. I had it for sale but can't in good conscience sell it someone and stick them with something they cant use. So now its a $600 paperweight until I figure out what to do with it. Maybe if I get ambitious I'll draw up the parts and see if I can get a machine shop to fabricate them.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: lake wood scatter sheild [Re: bigblockbryan] #2320608
06/13/17 03:44 PM
06/13/17 03:44 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Making those pieces would be a piece of cake for just about anyone with a lathe. The cup i.d. is the o.d. of the starter snout. The o.d. of the cup is already machined into the scattershield (look, you'll see it). The other part is lust a piece of rad welded to some flat bar - instead of turning down a larger piece of rod you could just put a sleeve over the thinner piece.
I'll take a look, the only piece I bought the kit for was the cup. If I can find it I'll measure up the other part. Hell, maybe I'll just make these kits up !!
Re: lake wood scatter sheild [Re: bigblockbryan] #2320670
06/13/17 06:07 PM
06/13/17 06:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
They do make 143 tooth wheels with multiple patterns on them. I have drilled my own flywheels before for custom plates.
Gus beer
64 Plymouth Savoy
Dana 60
Re: lake wood scatter sheild [Re: RoadRunner] #2321040
06/14/17 12:36 PM
06/14/17 12:36 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I have seen a few of these laying around my bolt buckets. I can look for one this weekend if you need it. Let me know. I'm talking about the little metal cup that holds the nose of the starter.
If you do run the scatter shield, make sure you not only check the runout on the alignment of the input opening in relation to the crankshaft centerline, but also that the face of the transmission mounting surface is parallel to the back of the block. I have to use both the offset dowels AND small thin washers to line my scatter shield up square too and centered too the crank.
Many people only check the opening runout and skip the later. It is just as important that it be correct.
Re: lake wood scatter sheild [Re: bigblockbryan] #2321488
06/15/17 06:21 AM
06/15/17 06:21 AM
can anyone tell me is there a diffrence in this bell housing
http://www.brewersperformance.com/proddetail.asp?prod=BH450
its listed as a 3 speed bell housing im thinking about buying it i have a 833 23 spline out of a 68 road runner
Re: lake wood scatter sheild [Re: bigblockbryan] #2321489
06/15/17 06:25 AM
06/15/17 06:25 AM
Re: lake wood scatter sheild [Re: bigblockbryan] #2321501
06/15/17 08:15 AM
06/15/17 08:15 AM
Ky
jt4406 Offline
jt4406  Offline
Ky
bellhousing would fit your engine, but your transmission will not fit it. you should have a 4.807 front bearing retainer. read here:
http://www.brewersperformance.com/products.asp?cat=82
jess
Yeah, it's hopped up to over 160...
Re: lake wood scatter sheild [Re: bigblockbryan] #2321506
06/15/17 08:36 AM
06/15/17 08:36 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
How can you determine if your scattershield needs this kit?
Re: lake wood scatter sheild [Re: bigblockbryan] #2321510
06/15/17 08:58 AM
06/15/17 08:58 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Three speeds and four speeds have different mounting bolt patterns on the bell to trans interface. So even if you had the proper diameter input bearing retainer you'd be up the crick.
Don't be the exception.
Re: lake wood scatter sheild [Re: bigblockbryan] #2321541
06/15/17 10:45 AM
06/15/17 10:45 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If you have a scattershield that can be used with either a 130 or 143 tooth flywheel AND you are using a 130, then you need the kit.
HOWEVER, it is really adsvisable that you use the starter snout support regardless as this goes a long way towards saving starter motors. Stock bells have a machined provision to support the starter snout, scattershields don't.
http://www.brewersperformance.com/proddetail.asp?prod=SAC-LW
Aren't all smallblocks 130 tooth? I suspect the smallblock scattershields are specific and are all 130 tooth.
Re: lake wood scatter sheild [Re: Stanton] #2321619
06/15/17 01:26 PM
06/15/17 01:26 PM
yea this has defently been a learning exprience for me really wish that bell kit was availble. So if i go back to a stock bell do i have to look for one that is a 10.5 or are the 11 inch ones diffrent? also anyone now if there if theres a video installing the lakewood starter kit on that bell? i may order a starter snout and try make my own id just like to watch a video see if i can get a idea how it works to do it
Re: lake wood scatter sheild [Re: bigblockbryan] #2321670
06/15/17 03:01 PM
06/15/17 03:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
no videos that I know of BUT if you install the snout support it pretty much aligns the starter enough that you could then get close measurements for the small bracket.
Re: lake wood scatter sheild [Re: bigblockbryan] #2321722
06/15/17 05:28 PM
06/15/17 05:28 PM
There are several different stock NP 833 bell housing sold on the cars from Mopar during the production runs from 1964 to the end of them being used in 1976 to 1979 confused scope
They made them in cast steel and cast aluminum, 130 tooth with 10.5 inch clutches and 143 tooth flywheels with 11.0 clutches. They also had several different front bearing retainer sizes, biggest for the O.D. tranny, regular size with the 307 bearings and bigger hole for the H.D tranny for the 440 and Hemi motors with the 308 front bearings scope
good luck, take your time to get it correct the first time thumbs
