Points will NOT open
#2318789
06/10/17 02:55 AM
06/10/17 02:55 AM
Posts: 93 Anacortes, WA
russ71satellite
Anacortes, WA
71 model 318 with points ignition. Attempting to install new points, and I cannot get the points to open at all when the rubbing block of the points is on the lobe of the distributor cam. Moving the points assembly as far as possible within the slot for the mounting screw does no good. Lobes of the dist cam do not seem worn down, and the distributor seems to work fine.
Has anyone ever dealt with this problem?
Thanks!
71 Satellite Sebring, all stock 1989 Dodge Daytona, daily driver 2008 PT Cruiser
Re: Points will NOT open
[Re: captaindodge]
#2318813
06/10/17 08:28 AM
06/10/17 08:28 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
A couple times over the years I've run into replacement point sets with a rubbing block shorter than the original set being replaced. Certainly enlarging the adjustment slot would address this.
Can't say I've had a distributor worn to the point where it wouldn't open points, but nothing much surprises me anymore.
Lead, follow or get the hell out of the way
[Re: russ71satellite]
#2318889
06/10/17 12:14 PM
06/10/17 12:14 PM
russ71satellite
Anacortes, WA
Thanks everyone....makes sense. Will enlarge the slot just a bit and this may solve the issue. I did compare the rubbing blocks on 3 sets I have, and no difference. I do feel just a bit of play on the end of the shaft.
#2318979
06/10/17 03:29 PM
06/10/17 03:29 PM
Posts: 74 California, United States and ...
Dibbons
I had this same problem. Purchased a 318 CID 1972 Plymouth Satellite Sebring Plus. The previous owner told me the transmission was slipping (drivetrain was out of car). I had the tranny rebuilt-no problem. The funny thing is the previous owner also told me the slipping transmission was causing the points to "burn up" and that while driving the vehicle with the slipping transmission he was replacing the points frequently. His ignition problem explanation made no sense to me at all.
Now when I re-installed the motor and transmission, I was sitting in the patio installing new points only to find they would not even open at any adjustment. I had to purchase a new (made in Taiwan) distributor at Pep Boys. This solved the problem for awhile. But then I noticed a missing problem on the highway and it seemed the problem was the points again. I changed them out during a road trip and then made it to a motel where a waiting for Summit to rush me overnight a Petronix billet pointless distributor. No problems so far with that.
The points problem remains a bit of a mystery. I assumed the factory distributor was just worn, but why the new (not rebuilt) Pep Boys distributor starting acting up I don't know. Could it be a problem with that bronze/brsss distributor shaft bushing in the block? Don't know.
#2319269
06/11/17 02:55 AM
06/11/17 02:55 AM
russ71satellite
Anacortes, WA
I got it running very well today. I drilled out the adjustment slot, allowing me to move the mounting plate for the points further toward the dist cam. Took about an hour or so, but got the points set at .017, reset timing and she is running very well. Nice strong, blue/white spark at the points.
Thanks for the tips!
