Re: Ringing Sound? Any help?!
[Re: moparfury1970]
#2318446
06/09/17 12:49 PM
06/09/17 12:49 PM
Posts: 2,368 Wheatfield, NY
Cuda340
Wheatfield, NY
Used gears? Tough to set back up to the original pattern they were before... Very well could be that.
Did you set up a new chunk or just swap it out?
[Re: moparfury1970]
#2318554
06/09/17 05:19 PM
06/09/17 05:19 PM
RapidRobert
When I lift the gas, it stops. I'm thinking classic ring/pinion issue.
[Re: moparfury1970]
#2318628
06/09/17 08:29 PM
06/09/17 08:29 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
You are NOT providing enough info. Nobody knows what you actually did to the car. Did you take apart the center section? Meaning did you separate the ring gear FROM the pinion gear?
[Re: moparfury1970]
#2318631
06/09/17 08:35 PM
06/09/17 08:35 PM
Posts: 96,661 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
What rearend is it? 8 3/4? Dana 60? something else. Did you change the WHOLE thing? brake drum to brake drum? Or remove ONLY the ring gear and pinion gear, and reinstall the stock 2 gears? Sounds like you removed the RING GEAR and PINION GEAR and didn't re-set the backlash, and didn't re-torque the pinion nut.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: moparfury1970]
#2318680
06/09/17 10:07 PM
06/09/17 10:07 PM
amxautox
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all?
Tom
author unknown
[Re: moparfury1970]
#2318681
06/09/17 10:07 PM
06/09/17 10:07 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's like trying to pull teeth with some people, they want help but won't give out any useful info.
[Re: Supercuda]
#2318683
06/09/17 10:09 PM
06/09/17 10:09 PM
Posts: 96 NEW JERSEY
moparfury1970
NEW JERSEY
It's like trying to pull teeth with some people, they want help but won't give out any useful info. I'm sorry, I'm not an expert with rear ends. No need to be like that. I sincerely appreciate the help from everybody here.
[Re: amxautox]
#2318684
06/09/17 10:11 PM
06/09/17 10:11 PM
moparfury1970
NEW JERSEY
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all? No, I didn't touch the anything in the stock rear end. Didn't touch the ring gear. I literally bought a new 7290 axle yoke kit from Year One and a drive shaft and took the original rear end that came with the car when I bought it, the stock gears and assembled. I probably sound like an idiot, but I'm just trying to learn.
[Re: moparfury1970]
#2318686
06/09/17 10:22 PM
06/09/17 10:22 PM
amxautox
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all? No, I didn't touch the anything in the stock rear end. Didn't touch the ring gear. I literally bought a new 7290 axle yoke kit from Year One and a drive shaft and took the original rear end that came with the car when I bought it, the stock gears and assembled. I probably sound like an idiot, but I'm just trying to learn. That's how you learn, by doing it, and asking about it. So you installed the yoke kit, but didn't torque the pinion nut when you installed it. How tight did you get the pinion nut? Very tight, VERY tight, or sorta tight? And that axle yoke kit, is that a yoke and u-joint, or just the two sized u-joint?
Tom
author unknown
