Ringing Sound? Any help?! #2318377
06/09/17 09:39 AM
06/09/17 09:39 AM
NEW JERSEY
moparfury1970 Offline OP
NEW JERSEY
Hey everyone, so I just swapped out my rear end and drive shaft and put the stock rear gears and a brand new drive shaft. (71RR 727 Auto, 7290). The car runs great put when I hit around 75 mph, I hear this faint then strong ringing sound. Nearly identical to the sound a finger makes when traced around a rim of a glass. When I lift the gas, it stops. I can't figure out where the noise is coming from. I'm thinking the rear. Any help would be appreciated.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318446
06/09/17 12:49 PM
06/09/17 12:49 PM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Used gears? Tough to set back up to the original pattern they were before... Very well could be that.
Did you set up a new chunk or just swap it out?
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318536
06/09/17 04:09 PM
06/09/17 04:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Check the pinion seal shield. If it has one it can get bent easily and rub the housing which will cause the drive shaft to amplify a ringing sound.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318554
06/09/17 05:19 PM
06/09/17 05:19 PM
I'm thinking classic ring/pinion issue.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318575
06/09/17 06:37 PM
06/09/17 06:37 PM
NEW JERSEY
NEW JERSEY
I think it might be the ring/pinion.
Re: Ringing Sound? Any help?! [Re: stumpy] #2318576
06/09/17 06:39 PM
06/09/17 06:39 PM
NEW JERSEY
NEW JERSEY
Is this something that is serious in nature if left not cared for?
Re: Ringing Sound? Any help?! [Re: Cuda340] #2318578
06/09/17 06:42 PM
06/09/17 06:42 PM
NEW JERSEY
NEW JERSEY
Its sounds dumb now, but I literally swapped out the drag end that was on the car and put the stock one that I had in a crate back on the car.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318596
06/09/17 07:12 PM
06/09/17 07:12 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
It sounds like you just swapped the center section, am I correct? Do you remember if the rear end made any noise when it was in the car before? I'm only asking because if you're like me, memory has a way of forgetting things! Is there any noise at all at lower speeds or is it only at freeway speed?
Re: Ringing Sound? Any help?! [Re: elmor353] #2318613
06/09/17 07:48 PM
06/09/17 07:48 PM
NEW JERSEY
NEW JERSEY
So the car had low end Richmond gears. All I did was swap out that rear for the stock gear. The drag gears never made a noise when it was in the car before. I put in a brand new 7290 axel yoke kit and a brand new drive shaft that went right into the transmission. Everything installed perfectly. Around 30-40 mph you start to hear a whine that disappears around 70mph. That's when the ringing sound happens. It will go away and come again every 30 seconds or so. Once I back off the gas a bit, it goes away.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318617
06/09/17 07:51 PM
06/09/17 07:51 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you swapped the pinion yoke did you retorque it and check the back lash.
Re: Ringing Sound? Any help?! [Re: stumpy] #2318623
06/09/17 08:16 PM
06/09/17 08:16 PM
NEW JERSEY
NEW JERSEY
No I didn't
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318627
06/09/17 08:28 PM
06/09/17 08:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You didn't swap pinions or you didn't check it?
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318628
06/09/17 08:29 PM
06/09/17 08:29 PM
Kirkland, Washington
Pacnorthcuda Offline
Originally Posted By moparfury1970
No I didn't
You are NOT providing enough info. Nobody knows what you actually did to the car.
Did you take apart the center section? Meaning did you separate the ring gear FROM the pinion gear?
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318631
06/09/17 08:35 PM
06/09/17 08:35 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
What rearend is it? 8 3/4? Dana 60? something else. Did you change the WHOLE thing? brake drum to brake drum? Or remove ONLY the ring gear and pinion gear, and reinstall the stock 2 gears? Sounds like you removed the RING GEAR and PINION GEAR and didn't re-set the backlash, and didn't re-torque the pinion nut.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318674
06/09/17 09:59 PM
06/09/17 09:59 PM
NEW JERSEY
NEW JERSEY
8 3/4 rear end. I changed the whole thing. Brake drum to brake drum.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318680
06/09/17 10:07 PM
06/09/17 10:07 PM
amxautox Offline
amxautox  Offline
Did you do anything with/to the pinion gear nut on the rearend that you put it? Anything to the ring gear? Did you take out the pig at all?
Tom
author unknown
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318681
06/09/17 10:07 PM
06/09/17 10:07 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It's like trying to pull teeth with some people, they want help but won't give out any useful info.
Don't be the exception.
Re: Ringing Sound? Any help?! [Re: Supercuda] #2318683
06/09/17 10:09 PM
06/09/17 10:09 PM
NEW JERSEY
NEW JERSEY
I'm sorry, I'm not an expert with rear ends. No need to be like that. I sincerely appreciate the help from everybody here.
Re: Ringing Sound? Any help?! [Re: amxautox] #2318684
06/09/17 10:11 PM
06/09/17 10:11 PM
NEW JERSEY
NEW JERSEY
No, I didn't touch the anything in the stock rear end. Didn't touch the ring gear. I literally bought a new 7290 axle yoke kit from Year One and a drive shaft and took the original rear end that came with the car when I bought it, the stock gears and assembled. I probably sound like an idiot, but I'm just trying to learn.
Re: Ringing Sound? Any help?! [Re: moparfury1970] #2318686
06/09/17 10:22 PM
06/09/17 10:22 PM
amxautox Offline
amxautox  Offline
That's how you learn, by doing it, and asking about it. So you installed the yoke kit, but didn't torque the pinion nut when you installed it. How tight did you get the pinion nut? Very tight, VERY tight, or sorta tight?
And that axle yoke kit, is that a yoke and u-joint, or just the two sized u-joint?
Tom
author unknown
