Made some passes w/my 470 stealth headed motor #231752
02/21/09 09:36 PM
02/21/09 09:36 PM
southwest Alabama
challenger73400 Offline OP
southwest Alabama
I finally got to make some passes with the 470 stealth headed motor. 12:1 CR solid flat tapet cam and 2800 lbs. Mobile Dragway in only 600ft long and it clicked off a 6.08 with a 1.35 60ft. No tunning done, just back it off the trailor, set the timing and made some passes. I feel there is more in it with some tuning.
Just thought some would like to see some numbers from the stealth heads. I,m happy!
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231753
02/21/09 09:40 PM
02/21/09 09:40 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Impressive
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231754
02/21/09 10:06 PM
02/21/09 10:06 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool
Re: Made some passes w/my 470 stealth headed motor [Re: MR_P_BODY] #231755
02/21/09 10:14 PM
02/21/09 10:14 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
congrats
Re: Made some passes w/my 470 stealth headed motor [Re: redruM] #231756
02/21/09 10:17 PM
02/21/09 10:17 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
man, that seems really good..congrats! what does that equate to in the 1/4? mid 10s?
Re: Made some passes w/my 470 stealth headed motor [Re: B1Fish540] #231757
02/21/09 10:21 PM
02/21/09 10:21 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
should be closer to mid 9s
Re: Made some passes w/my 470 stealth headed motor [Re: B1Fish540] #231758
02/21/09 10:22 PM
02/21/09 10:22 PM
southwest Alabama
southwest Alabama
Depends on what calculator you use. one converted to a 9.71 and the other had it at a 10.24.
Re: Made some passes w/my 470 stealth headed motor [Re: redruM] #231759
02/21/09 10:28 PM
02/21/09 10:28 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
that was a 600ft. pass not a 660ft. pass
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231760
02/21/09 10:36 PM
02/21/09 10:36 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
ah..i was gonna say low 10s but thought i should guess more conservative..lol Thats flyin' is that in a challenger...how heavy?
Re: Made some passes w/my 470 stealth headed motor [Re: tjmarcus1] #231761
02/21/09 10:43 PM
02/21/09 10:43 PM
Columbus, OH
redruM Offline
redruM  Offline
Columbus, OH
Crap, can't say i've ever heard of a 600 ft track before.
Re: Made some passes w/my 470 stealth headed motor [Re: redruM] #231762
02/21/09 10:48 PM
02/21/09 10:48 PM
southwest Alabama
southwest Alabama
Mobile Dragway doesn't have much shut down area so they shorten the track to 600ft. It's a Dakota. Thanks!
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231763
02/22/09 10:47 AM
02/22/09 10:47 AM
Swamps of South Jersey.
W
wildcargo Offline
wildcargo  Offline
W
I would say that is into the 9s by my 6.38 1/8_10.08 1/4
Bud www.wildcar-go.itgo.com
64 DODGE
60' 1.433,
1/8 6.38 at 107.4,
1/4 10.08 at 132.02
foot brake, leaf springs
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231764
02/23/09 12:05 AM
02/23/09 12:05 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I guess those heads work........nice numbers for sure.
Re: Made some passes w/my 470 stealth headed motor [Re: Thumperdart] #231765
02/23/09 09:48 AM
02/23/09 09:48 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
nice H.P
do you have any flow numbers on the heads???
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Made some passes w/my 470 stealth headed motor [Re: 10 o to go] #231766
02/23/09 11:12 AM
02/23/09 11:12 AM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
Very impressive!!
Re: Made some passes w/my 470 stealth headed motor [Re: 10 o to go] #231767
02/23/09 08:19 PM
02/23/09 08:19 PM
southwest Alabama
southwest Alabama
nice H.P
don
I do not. My machinest said the valve job they come with is good for longtivity but not the best for performance so he narrowed the seat and moved it out, did a three angle valve job and back cut the valves. I then blended his work in, opened the push rod pinch and removed some of the head bolt bosses. I also layed back the lip in the chambers. Scott.
Re: Made some passes w/my 470 stealth headed motor [Re: challenger73400] #231768
02/23/09 09:03 PM
02/23/09 09:03 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
At a 6.08 ET at 600ft vs 660ft 1/8 mile you were on track to run a 10.25 1/4 mile to put things into perspective.
6.08 @ 600ft. = 10.25 Approx. 1/4 mile
6.08 @ 660ft. = 9.65 Approx. 1/4 mile
Your combo runs great for what it is, Id be really happy, Your 1.35 60ft is strong
And also from the comments about your heads port work, you know what your doing. Id guess those heads are flowing around 310+ cfm @ .600 0r so mike
