Do you all think autozone bearings are undersized? #2317227
06/06/17 06:18 PM
06/06/17 06:18 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
AutoZone Bearing
I'm working on a 72 Dart with 7.25 rear with 10" brakes, got a new bearing off ebay that said for 72 dart with 10" brakes & 7.25 rear, But it was too big in center, part # of it was skf rwc35-yyr
So now I'm thinking of just going with the autozone one, but someone put on it that its undersized, what do you all think?
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317254
06/06/17 07:10 PM
06/06/17 07:10 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would not think it would be undersized unless it stated so. The size should be listed. Measure the old one and then compare measurements. BTW, maybe sometime if the life of the dart the brakes were upgraded to 10 inch.
Re: Do you all think autozone bearings are undersized? [Re: mopars4ever] #2317282
06/06/17 08:18 PM
06/06/17 08:18 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
don't have old one to go by, replacing a new bearing from rockauto that seems like it was pressed on too far, but would like to go with a deff. brand this time!
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317283
06/06/17 08:21 PM
06/06/17 08:21 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
But the guy that posted that they wear undersized on autozone was a ford guy, may just been him! lol
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317289
06/06/17 08:30 PM
06/06/17 08:30 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Originally Posted By Hoop
AutoZone Bearing
Pulled out a big bolt axel I have in a junk rear from a 74 scamp, bearing was biger like one I have new, guy on ebay sould of posted 73 & up!.. see if I can get a refund on it, if not you'll see the new bearing I have for sale on hear prob.!
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317343
06/06/17 10:01 PM
06/06/17 10:01 PM
md
mopars4ever Offline
mopars4ever  Offline
md
72 mopar axle bearing part number is 3420090 It`s not listing a difference for 9 or 10 inch brakes.
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317345
06/06/17 10:03 PM
06/06/17 10:03 PM
dogdays Offline
dogdays  Offline
This horsepoop has got to stop. There is no such thing as an Autozone bearing!!!!!
For there to be one, Az would have to have a bearing factory and the plain and simple fact is, Autozone makes nothing. Period. They even have their sale flyers printed by a contractor. And this is exactly the same as O'Reilly's, Advance Auto, CARQUEST, NAPA, even Harbor Freight.
All these companies give their brand names to items that are made by others. That's how life works. Shoot, even back in the day, GM didn't make many of their frames, they were made by Budd. And Chrysler used Budd, too This is just one example.
And another thing - bearings are made to international standards. You, the designer, look in the bearing catalog and find what will work acceptably and then you make the part fit the bearing. Talking about rolling element bearings. It's been this way for at least 80 years.
Seals are the same. Many of the smaller parts you find on your car are made by a specialty company and picked out by the designer. O-rings are another, with standardized sizes across the globe (well, maybe not in France).
So if the bearing that someone bought from Autozone doesn't fit properly, either it was made with no quality control or else the shaft or bore it pushes against was made the wrong size. Or else the person trying to assemble it doesn't know how it is supposed to fit.
R.
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317390
06/06/17 11:28 PM
06/06/17 11:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
He's been told repeatedly what's up, but he wants to hear what he wants to hear.
Don't be the exception.
Re: Do you all think autozone bearings are undersized? [Re: dogdays] #2317398
06/06/17 11:52 PM
06/06/17 11:52 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Hey dummy, everbody knows Duralast is autozone brand, I just like to call it autozone!
Re: Do you all think autozone bearings are undersized? [Re: Supercuda] #2317405
06/07/17 12:03 AM
06/07/17 12:03 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Yell, dogdays must think people don't know nothing!
Re: Do you all think autozone bearings are undersized? [Re: mopars4ever] #2317417
06/07/17 12:18 AM
06/07/17 12:18 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Well thats not what I was asking about, but ok!..So that's just the way most other auto parts douse, all 72 & down you got to get the bearing for 9"?... Witch I was thinking same thing when I looked at bearing on the big bolt axle & saw it was the same as the new one I got that was bigger!
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317432
06/07/17 12:37 AM
06/07/17 12:37 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Just letting you know what the correct mopar bearing was for the car since you seem to be questioning the aftermarket one. Their listings I`m sure are for multiple years and the mopar catalog is just for 72 vehicles and only one part number is listed for a 72 Dart with a 7 1/4 rear. I know on the NAPA website you can enter the mopar part number and it will cross reference to the aftermarket part number.
Re: Do you all think autozone bearings are undersized? [Re: mopars4ever] #2317450
06/07/17 01:15 AM
06/07/17 01:15 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
Yeal, on the new bearing I got off ebay, I first looked up the Napa one, 10" was high, so took the part number & went to ebay, guy had on their listed for my car, the little bit bigger bearing should be listed for 73 & up!.. That's prob. why autozone don't have 9" or 10" listed on theirs!
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317497
06/07/17 03:25 AM
06/07/17 03:25 AM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
So nobody has tried autozone brand for 7 1/4?
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317524
06/07/17 08:54 AM
06/07/17 08:54 AM
crlush Offline
crlush  Offline
Cant you just take the number off your old bearing and get that.
Re: Do you all think autozone bearings are undersized? [Re: dogdays] #2317634
06/07/17 01:56 PM
06/07/17 01:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
R.
What he said and as you should know there is only one 7.25 bearing regardless of year and brake size.
Re: Do you all think autozone bearings are undersized? [Re: 62maxwgn] #2317698
06/07/17 04:03 PM
06/07/17 04:03 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I think I know that all ready, not what I was asking, I was ask about the bearings at autozone in the link, stick to the subject!... I all ready know, Their is only one for 72 & down, 73 & up is the bigger one!
Re: Do you all think autozone bearings are undersized? [Re: crlush] #2317709
06/07/17 04:23 PM
06/07/17 04:23 PM
Partridge, KY
Hoop Offline OP
Hoop  Offline OP
Partridge, KY
I think I know that, I do have The numbers from my old one & it did not brag up the bearing on any auto parts, but did find some NOS ones on ebay, but that don't matter now, if you read the other post, all I need to know is has anybody ever had a prob. with the bearing from autozone like the ford guy wrote, I'm fixing to go order one, but it would of been good to know nobody has had any prob. with their brand of bearing!
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317753
06/07/17 06:27 PM
06/07/17 06:27 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I used AZ bearings on my 7-1/4 in my old Duster a few times. Order the right year and they work fine.
Re: Do you all think autozone bearings are undersized? [Re: Hoop] #2317849
06/07/17 10:35 PM
06/07/17 10:35 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would surely would rather use a NOS mopar bearing before using a Duralast bearing. Probably made in China.
Did you get the info for the undersize bearing from the autozone website? This is the review that was left. It apparently was for a Ford Mustang.
"This bearing does not fit Mustang 8" or small bearing 9"
Beware. This bearing is undersized by a whole bunch. If you try to press it on your axle without checking to see if it fits first, it will fly apart and possibly injure you. Maybe the ones I got were in the wrong box or mismarked or something, but they were in their sealed package.
The bearing should be a 0.002" to 0.003" press fit. There is no way it will go on the axle without breaking.
Pros: It is shiny when you take it out of the box
Cons: The ID of the bearing is almost 0.030" (THIRTY THOUSANDTHS!!!) undersized"
