Gas mileage?? #2316870
06/05/17 09:55 PM
06/05/17 09:55 PM
Third rock from the sun.
busboy Offline OP
busboy  Offline OP
Not something I usually concern myself with in this hobby doing local cruise nights and short drives but we're taking our first long (about 2500mi) round trip this year. I've swapped the 3:55's for 2:94's, It'll get fresh oil and filter, fresh set of plugs and check tire pressures before leaving. The few day trips I've done so far are giviving me 14mpg cruising close to 60mph in my 340/6 a-body. Can anybody give me approximate numbers that they're getting, if you keep track of such things. Please include body type, drivetrain and rear gears so we have a fighting chance at keeping this all straight😁! Also any suggestions on squeezing better mileage out of a six pack would be much appreciated.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Gas mileage?? [Re: busboy] #2316961
06/06/17 12:45 AM
06/06/17 12:45 AM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Get an Air/fuel reader in the exhaust and tune your distributor to go in 40's during cruise.
What do you have for a torque converter and camshast.
Re: Gas mileage?? [Re: Magnum] #2316977
06/06/17 01:30 AM
06/06/17 01:30 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
This was from 20+ years ago, before 10% ethanol gas...
70 Super Bee
-orginal 440-6 gone, replaced with used '69 std 440 LP, 440-6 int and exh manifolds swapped over
-orginal 727 trans & 3.23 SG
-1 jet size larger on center carb
-int and mech timing 38*, vac adv unknown, dist is MP electronic
Trip...
250 miles
80% hwy @70, 20% city
result, 16 MPG
Re: Gas mileage?? [Re: busboy] #2316979
06/06/17 01:34 AM
06/06/17 01:34 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
One of the reasons I advocated having an OD transmission for the last decade and a half, sure gas is "cheap" for now (not really)but who knows what the future holds...
I'd see 14-16 MPG cruising 70-80 MPH in a 71 B body with a 472 HEMI with a 6 bbl induction, 4:10 gears running a TKO 600 5spd with .64 OD on long hauls
My 70 Charger Daytona 440/6 450hp 4:10 dana, TKO600 5spd .64 OD would get upwards of 22 MPG cruising 80+ MPH on HotRod Power Tours and other cross country driving events
On the streets however I could destroy those MPG figures into the single digits if I had my foot in it, so tune all you want, drive prudently, granny shift, etc, etc, you won't see any drastic results until you take advantage of some mechanical/mathematical gear/RPM reduction
Re: Gas mileage?? [Re: busboy] #2316990
06/06/17 01:47 AM
06/06/17 01:47 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Pump up those tires to 50lbs. smirk and slow the hell down! biggrin Throw a bag of ice on the intake??? whistling I'm thinking that's pretty good, you could try squeezing one more with timing and whatnot. Tires at least 40lbs. will help a little.
Re: Gas mileage?? [Re: Dave Hall] #2317023
06/06/17 06:05 AM
06/06/17 06:05 AM
IN
ahy Offline
ahy  Offline
IN
I think 14 MPG is decent.
I ran a '70E about 4,000 miles in 10 days a couple of years ago. From IL to CA and back over the Rockies. 14 MPG running 75-80 ish. Engine is a 496B with warm cam. EFI, .81 OD TKO, 3.23 rear and ~25" tires. At light cruise running around 50 degrees advance and a little lean on the AF. One tuning challenge was when to dial back advance and richen the mixture for moderate acceleration w/o rattle. WOT is pretty easy to tune. I would likely have gotten 15+ MPG with taller OD which the engine could eaisly handle at cruising speed... but like the shorter OD as a top end track gear.
My understanding, the 6 pack can do quite well with careful tuning of the center carb and plenty of vacuum advance (50+ degrees?). Just a little easier to get there with EFI. Also, EFI handles altitude, temp and fuel changes w/o penalty which matters a lot in the mountains.
Re: Gas mileage?? [Re: busboy] #2317097
06/06/17 12:20 PM
06/06/17 12:20 PM
Charlotte, NC
81ImperialMan Offline
Charlotte, NC
This is an interesting topic. We have an 81 Imperial with the 904. It has 139K original on drivetrain. So far everything is holding up well. However given the mileage, the thought occurred to me that if the trans ever needs an overhaul I have thought about dropping in a 4-speed OD from a truck from the late 80s' early 90's before they put in the electronic controls. I cannot imagine it would be technically difficult.
Owner of a 1981 Chrysler Imperial EFI.
Re: Gas mileage?? [Re: busboy] #2317135
06/06/17 01:55 PM
06/06/17 01:55 PM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
528 Hemi all iron 10:1 CR, dual AFB's with progressive linkage, stock intake, stock exhaust manifolds, very small cam (270 advertised), 30deg timing, 727auto, 3.23 gears, electric fans, non power steer, non power brakes, 26" tires @ 32psi, in 70 b-body.
13 mpg with pump-93
Re: Gas mileage?? [Re: busboy] #2317138
06/06/17 02:01 PM
06/06/17 02:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
My Challenger 360, 224@.050 cam TTI headers and 2.5 exh,650 Holley DP (leaned 2 jet sizes),LD340,4 speed, 2.76 gear for a trip out west. 18mpg
Doug
Re: Gas mileage?? [Re: busboy] #2317192
06/06/17 04:45 PM
06/06/17 04:45 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Bone stock 340 Swinger with 383 AVS, 3.23's 14" tires, 18 mpg on highway. Swapping a single 4 for the road trip would be the biggest mpg boost you could make.
Re: Gas mileage?? [Re: busboy] #2317519
06/07/17 08:41 AM
06/07/17 08:41 AM
jersey
Spaceman Spiff Offline
jersey
526 wedge, 3.73's 4600lbs. 14.6 on the 3 her ride to Carlisle.
Trying to keep it around 3000rpm.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Gas mileage?? [Re: Magnum] #2317616
06/07/17 01:12 PM
06/07/17 01:12 PM
busboy Offline OP
busboy  Offline OP
Magnum, pretty mild stuff, 2200 stall with a 286XE cam. My plan is also to run the black springs in the outers to try to stay just on the center carb, and of course keep my foot out of the loud pedal whistling
Re: Gas mileage?? [Re: busboy] #2317626
06/07/17 01:29 PM
06/07/17 01:29 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Stock 74 Duster360, 727 and 2.45:1 rear gear with 235/60/14 tires . . . ran 70mph all day long - 22mpg !!
Stock 76 Road Runner, 318 with factory 4spd OD, not sure rear gear, same tire as Duster360, 70mph all day long - 22mpg.
Stock 70 300Hurst (Ragtop), 440, 727, 3.23:1 rear gear, 50 - 80mph (didn't seem to matter the speed), 16mpg all day long . . .
Cheers,
Re: Gas mileage?? [Re: a12rag] #2317681
06/07/17 03:27 PM
06/07/17 03:27 PM
Ottawa, ontario
dd340 Offline
dd340  Offline
Ottawa, ontario
Cheers,
Canadian or US gallons?
Re: Gas mileage?? [Re: busboy] #2317707
06/07/17 04:22 PM
06/07/17 04:22 PM
a12rag Offline
a12rag  Offline
US gallon
