Gas mileage??
#2316870
06/05/17 09:55 PM
06/05/17 09:55 PM
Posts: 670 Third rock from the sun.
busboy
Not something I usually concern myself with in this hobby doing local cruise nights and short drives but we're taking our first long (about 2500mi) round trip this year. I've swapped the 3:55's for 2:94's, It'll get fresh oil and filter, fresh set of plugs and check tire pressures before leaving. The few day trips I've done so far are giviving me 14mpg cruising close to 60mph in my 340/6 a-body. Can anybody give me approximate numbers that they're getting, if you keep track of such things. Please include body type, drivetrain and rear gears so we have a fighting chance at keeping this all straight😁! Also any suggestions on squeezing better mileage out of a six pack would be much appreciated.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Gas mileage??
[Re: busboy]
#2316961
06/06/17 12:45 AM
06/06/17 12:45 AM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
any suggestions on squeezing better mileage out of a six pack would be much appreciated. Get an Air/fuel reader in the exhaust and tune your distributor to go in 40's during cruise. What do you have for a torque converter and camshast.
Re: Gas mileage??
[Re: busboy]
#2316979
06/06/17 01:34 AM
06/06/17 01:34 AM
Posts: 18,157 Mass
DAYCLONA
Mass
14mpg cruising close to 60mph in my 340/6 a-body. Can anybody give me approximate numbers that they're getting, if you keep track of such things. Please include body type, drivetrain and rear gears so we have a fighting chance at keeping this all straight😁! Also any suggestions on squeezing better mileage out of a six pack would be much appreciated. One of the reasons I advocated having an OD transmission for the last decade and a half, sure gas is "cheap" for now (not really)but who knows what the future holds... I'd see 14-16 MPG cruising 70-80 MPH in a 71 B body with a 472 HEMI with a 6 bbl induction, 4:10 gears running a TKO 600 5spd with .64 OD on long hauls My 70 Charger Daytona 440/6 450hp 4:10 dana, TKO600 5spd .64 OD would get upwards of 22 MPG cruising 80+ MPH on HotRod Power Tours and other cross country driving events On the streets however I could destroy those MPG figures into the single digits if I had my foot in it, so tune all you want, drive prudently, granny shift, etc, etc, you won't see any drastic results until you take advantage of some mechanical/mathematical gear/RPM reduction
Re: Gas mileage??
[Re: busboy]
#2316990
06/06/17 01:47 AM
06/06/17 01:47 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
Pump up those tires to 50lbs. and slow the hell down! Throw a bag of ice on the intake??? I'm thinking that's pretty good, you could try squeezing one more with timing and whatnot. Tires at least 40lbs. will help a little.
Re: Gas mileage??
[Re: busboy]
#2317097
06/06/17 12:20 PM
06/06/17 12:20 PM
Posts: 3 Charlotte, NC
81ImperialMan
Charlotte, NC
This is an interesting topic. We have an 81 Imperial with the 904. It has 139K original on drivetrain. So far everything is holding up well. However given the mileage, the thought occurred to me that if the trans ever needs an overhaul I have thought about dropping in a 4-speed OD from a truck from the late 80s' early 90's before they put in the electronic controls. I cannot imagine it would be technically difficult.
Owner of a 1981 Chrysler Imperial EFI.
Re: Gas mileage??
[Re: busboy]
#2317135
06/06/17 01:55 PM
06/06/17 01:55 PM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
528 Hemi all iron 10:1 CR, dual AFB's with progressive linkage, stock intake, stock exhaust manifolds, very small cam (270 advertised), 30deg timing, 727auto, 3.23 gears, electric fans, non power steer, non power brakes, 26" tires @ 32psi, in 70 b-body.
13 mpg with pump-93
Re: Gas mileage??
[Re: busboy]
#2317519
06/07/17 08:41 AM
06/07/17 08:41 AM
Posts: 3,696 jersey
Spaceman Spiff
jersey
526 wedge, 3.73's 4600lbs. 14.6 on the 3 her ride to Carlisle. Trying to keep it around 3000rpm.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Gas mileage??
[Re: busboy]
#2317626
06/07/17 01:29 PM
06/07/17 01:29 PM
Posts: 2,919 Calgary, Alberta Canada
a12rag
Stock 74 Duster360, 727 and 2.45:1 rear gear with 235/60/14 tires . . . ran 70mph all day long - 22mpg !!
Stock 76 Road Runner, 318 with factory 4spd OD, not sure rear gear, same tire as Duster360, 70mph all day long - 22mpg.
Stock 70 300Hurst (Ragtop), 440, 727, 3.23:1 rear gear, 50 - 80mph (didn't seem to matter the speed), 16mpg all day long . . .
Cheers,
Re: Gas mileage??
[Re: a12rag]
#2317681
06/07/17 03:27 PM
06/07/17 03:27 PM
Posts: 727 Ottawa, ontario
dd340
Ottawa, ontario
Cheers, Canadian or US gallons?
