Fuse block #2316724
06/05/17 06:19 PM
06/05/17 06:19 PM
PA
70HemiGTX Offline OP
PA
I need a new fuse block for my 68 Dart. I have the original factory harness in it and the fuse prongs are rusty. Does any one make a replacement block with fuse holders or a replacement block with the new spade style fuses. What have you guys used? This is for a pro-street car, so originality does not matter.
Re: Fuse block [Re: 70HemiGTX] #2316771
06/05/17 07:23 PM
06/05/17 07:23 PM
I used a $9.95 HF dremel to clean the inside edges of the blades that contact the fuse(s). that thing has very little torque & is perfect for that. On the other end if the rivets/wires are corroded a person could drill them out.
Re: Fuse block [Re: RapidRobert] #2316788
06/05/17 07:40 PM
06/05/17 07:40 PM
PA
PA
Never thought of that. Have to get my dremel out and find a wire brush end for it. That will save lots of work. Sometimes I think too big. Thanks!
Re: Fuse block [Re: 70HemiGTX] #2316864
06/05/17 09:40 PM
06/05/17 09:40 PM
I cant relate to that at all!
Re: Fuse block [Re: 70HemiGTX] #2317078
06/06/17 11:37 AM
06/06/17 11:37 AM
IMGTX Offline
IMGTX  Offline
I do not know if this will help but this is the closest I have found to the terminals for the OEM fuse blocks.
http://www.cjponyparts.com/fuse-box-repair-kit-1965-1968/p/HW2906/
Not cheap but maybe somebody else has a source that is better.
That being said if it isn't OEM restoration then I would get a modern style ATOF fuse style block. Easier to find fuses when you need them on the side of the road.
