1971 SPD / Door tag / Casting ? #2315923
06/04/17 01:17 PM
06/04/17 01:17 PM
Massachusetts
RAII4-speed Offline OP
Massachusetts
1971 Duster 340 SPD is 6/01 .... Door tag read 5/1971 .... Casting on block is 1/18/71 Does this seem to be correct?
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316000
06/04/17 03:57 PM
06/04/17 03:57 PM
Massachusetts
Massachusetts
Trying to upload pics
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316208
06/04/17 09:20 PM
06/04/17 09:20 PM
Alabama
BigMoneyLewis Offline
Alabama
Certainly not unusual. What's the assembly date on the block look like ?
Greg
gregward@mchsi.com phone 256-852-0955
Re: 1971 SPD / Door tag / Casting ? [Re: BigMoneyLewis] #2316660
06/05/17 04:08 PM
06/05/17 04:08 PM
dogdays Offline
dogdays  Offline
As long as they are in chronological order, IMHO you're good. Chrysler didn't have a very efficient inventory system. Again that's in my opinion, but it comes up so often.
R.
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316699
06/05/17 05:12 PM
06/05/17 05:12 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No concerns with those dates.
I have a 340 block that was cast in 3/71 IIRC and went into a 72 car
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316708
06/05/17 05:34 PM
06/05/17 05:34 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
is it an orange "GW340" Windsor assembled engine or a blue "GM340" Mound Rd. assembled engine
what transmission?
SPD of 6/1/71 (601) is "SCHEDULED"
door tag of "5 - 71" represents the car's build being completed by Friday 5/28/71
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316723
06/05/17 06:16 PM
06/05/17 06:16 PM
Massachusetts
Massachusetts
Not able to read it without scrapping paint ... 4-speed car ... Blue engine
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316731
06/05/17 06:25 PM
06/05/17 06:25 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
what does the VIN stamping look like? you are going to have to scrape paint if you want to know the answer to the question that wasn't asked? work
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316738
06/05/17 06:33 PM
06/05/17 06:33 PM
Massachusetts
Massachusetts
Stamping looks good, Just thought the casting date and SPD were a bit too far apart ...
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316766
06/05/17 07:11 PM
06/05/17 07:11 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
I have a '71 340 engine
VIN: 1B450330
stamped: GM340P 3567 0071
CAST: 1/20/71
EAD: 5/4/71
car's SPD: early July
Re: 1971 SPD / Door tag / Casting ? [Re: 6bblgt] #2316774
06/05/17 07:26 PM
06/05/17 07:26 PM
Las Vegas, NV
6bblgt Online work
6bblgt  Online Work
Las Vegas, NV
angle & location of the 2 "GM340" stampings are nearly identical
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316779
06/05/17 07:31 PM
06/05/17 07:31 PM
Massachusetts
Massachusetts
How does this break down to a date?.... GM340P 3567 0071
Re: 1971 SPD / Door tag / Casting ? [Re: RAII4-speed] #2316784
06/05/17 07:36 PM
06/05/17 07:36 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
3567 is the date based on the 10000 calendar
0071 is the 71st engine built that day
