Page 8 of 13 1 2 6 7 8 9 10 12 13
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2301296
05/08/17 06:55 PM
05/08/17 06:55 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Picture of the messed up pan from Charlies. Like to see if my friend can use it for his new build.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: gsmopar] #2301483
05/09/17 12:09 AM
05/09/17 12:09 AM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Originally Posted By gsmopar
All told, I killed two rods, two pistons, two valve guides and associated valves, one oil pump, one oil pan, had to repair the block & crank....Oh and high gear in the trans....covered the headers in 20-50 and dinged one with the rod cap. Plus all the associated gaskets.....Not sure the total, but it wasn't cheap. We found some issues with the heads we addressed this time as well.
What was the root cause of the failure? I'll be firing up my Hemi soon (with a lot of the same parts). Just hoping to learn from your experience. Thanks!
Well, two things, you can NEVER have a big enough oil pan with a Hemi, and we did not restrict the flow of oil to the heads. I now have restrictors in the block. Hopefully, we do not limit it too much and burn up push rods.
Burned #7 rod bearing on a pass and it all let go....
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2301488
05/09/17 12:18 AM
05/09/17 12:18 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Can you show the inside of your oil pan,I'm looking at oil control in a deeper sump pan,just curious what the Milodon looks like up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: hemi-itis] #2301965
05/09/17 08:25 PM
05/09/17 08:25 PM
Dragula Offline OP
Dragula  Offline OP
A week earlier, I could have taken a picture of the inside of that Milodon pan....I run the same pan on my wedge in the Duster and it has been great. If I remember right, its got a scraper on one edge and a tray built in with a couple spots for oil to drain back. I do not recall if it has a trap door in it.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316167
06/04/17 08:23 PM
06/04/17 08:23 PM
Dragula Offline OP
Dragula  Offline OP
The good news is, I can take a picture of the inside of the oil pan now for you. The bad news is, the rebuild didn't make it 10 miles down the road before major issues occurred.
So I got the engine running a few weeks ago, and it was in the car about a week. Went to take its maiden voyage down to the corner gas station and back, just to feel it out and put a few miles on it, and half way there, oil pressure started dropping.
I just happened to look across at the gauges and finally saw full engine temp and then looked over at the oil pressure, and it was already down to 45psi from 82psi....WTH!
Pull over and call a friend for a tow, no one answers...Fire it up and drive home, and it was down to 10psi if I am lucky by the time I pulled it back in.
So to make a long story short, I pull the engine a few days later and get it down to the shop. Pulled it apart, and struggled to find anything wrong.
Seems the crank we just had repaired, went and sprung once it reached full temp. That's the best explanation we can find. It was out .003" and I know it was straight when we put it in. Called Ohio crank about it, and they said that can happen on repairs like that.
So now, I am out my summer car, as I do not yet have a spare engine built. And I am wondering what my next move is....
Called Bryant for a crank, and its 14 weeks to get one...Still waiting to hear back about a Callie's for lead time. Might just sell it and build another 400/512 or a G3...Pretty depressed about it. Two summers in a row and Mopar day is this Saturday...no cruise nights or car shows this year either...
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316188
06/04/17 08:52 PM
06/04/17 08:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Sorry to hear that man and can't you street the Duster..........
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Thumperdart] #2316343
06/05/17 12:19 AM
06/05/17 12:19 AM
Dragula Offline OP
Dragula  Offline OP
I have thought about that....But got this nice looking Cuda sitting here with insurance and a fresh trans all ready to go, minus an engine...
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316349
06/05/17 12:31 AM
06/05/17 12:31 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I know you must really love your engine builder but don't you honestly think it's time for a divorce. Man I would love to have the money you spent on builds over the last five years. I wish you nothing but success on your next project
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: pittsburghracer] #2316357
06/05/17 12:42 AM
06/05/17 12:42 AM
Dragula Offline OP
Dragula  Offline OP
I honestly don't think its his fault. It kicked a rod last year, and I sent it out to repair instead of replacing it. Finding all this out is like one of those doctors commercials, in the fine print, a repaired crank can retain a lot of stress in it after the repair.
At this point, I have an entire engine minus a crank....or at least a straight crank. And getting a new 4.75 crank is a lot tougher than I thought. Seems the standard is a 4.5...So maybe change crank and pistons and go 572, dunno....I am depressed.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316382
06/05/17 01:16 AM
06/05/17 01:16 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The stock forged 413 crank in my Dart was bent like .002-.003 and we rotated around 180 degrees, and Jason Pettis smacked it a few times w/a big ass chisel and hammer and all good 14+ years later...........Hard to point fingers without all of the details or whatever but I hope this stuffs behind you guys............ thumbs
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316388
06/05/17 01:30 AM
06/05/17 01:30 AM
lake charles, la
sc4400 Offline
sc4400  Offline
lake charles, la
I just got a 4.75 crank from Ohio 2 weeks ago. Are they out of stock?
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316389
06/05/17 01:31 AM
06/05/17 01:31 AM
Cab_Burge Online work
Cab_Burge  Online Work
How about seeing about straightening it and heating it up to 250 to 300 F several times afterwards to see if it has taken a permanent set or not scope All things steel are fixable with enough effort thumbs work Powder coating company heat their stuff up in large ovens to around those temperatures work
Maybe have it heated up several times first and then straighten it shruggy
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Cab_Burge] #2316407
06/05/17 02:02 AM
06/05/17 02:02 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
Man, Hot Rods can be not worth it some days. Hope you can find a new crank for it. There has to be one somewhere.
Sheldon
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316424
06/05/17 02:44 AM
06/05/17 02:44 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Call Crower on the crank...
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: sc4400] #2316451
06/05/17 07:41 AM
06/05/17 07:41 AM
Dragula Offline OP
Dragula  Offline OP
Yes they are out...And those are on the cheapish side. Not sure if I wanted to go that route.
Whatever the material Bryant uses is twice as strong as the 4340 cranks. I think he said 43M300...not sure, but 14 week lead time.
This is what we might be up to.....It was a good crank, and its still is, but it has .003 in it now....
Had not thought about them. Looked up Weinberg last night, and 4.5" was it...
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316526
06/05/17 12:11 PM
06/05/17 12:11 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
How did the bearing look ? - if none of the main bearings were showing wear - I would suspect it is something else causing the dramatic pressure drop.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: DoubleD] #2316530
06/05/17 12:19 PM
06/05/17 12:19 PM
PA.
"Little"John
"Little"John
PA.
Make a few calls to possibly Indy, Best Machine, Bob George Racing, and any other shops you can think of. Who knows what they have on stock and willing to part with
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316591
06/05/17 02:09 PM
06/05/17 02:09 PM
Franklin, TN
23T Hemmee Offline
23T Hemmee  Offline
Franklin, TN
Ronny
6.789 @ 198.63 **.956 Brand New 60'***
4.17@ 169 1/8th mile
John 14:6
https://www.youtube.com/watch?v=TUku_hjYRh8
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: 23T Hemmee] #2316604
06/05/17 02:31 PM
06/05/17 02:31 PM
Dragula Offline OP
Dragula  Offline OP
I have been in touch with AJ at BGR...He got me the one quote for a Callie's...Just didn't let me know lead time.
Originally Posted By 23T Hemmee
I will keep that one in mind.
Got a call, it was straightened again and all polished up. Not sure if the guy was happy about doing it or not....We will probably heat cycle it in the oven at the shop and make a judgement call on it.
We also have a run in stand we can fire it up on and just see what happens before it goes in the car this time.
Re: The Quest Has Begun......605 Hemi Build, Updated! [Re: Dragula] #2316607
06/05/17 02:37 PM
06/05/17 02:37 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I don't understand how the crank can be causing the pressure loss after being machined. When you say it's out .003", are you talking clearance or out of square? Can it not be ground .010" undersize on a straight cut?
[image][/image]
