Project 470 Underway!! New Victor Heads!! #2315807
06/04/17 02:52 AM
06/04/17 02:52 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
I received the Gen 3 Victor heads directly from Edelbrock a week or so ago after waiting for them for over 5 months due to some changes Edelbrock made to the heads.
I spoke with a engineer at Edelbrock about the changes made to the Victor heads. The engineer said the ports and combustion chambers were not changed however the following changes make these Victor heads different from the Gen two castings.
The solidification process of the heads is more controlled than the previous process. The benefits are a more consistent casting with less impurities in the aluminum.
The center rocker shaft stand on the heads is thicker by 3/16 in order to better handle the emence spring pressures seen in some full race applications.
One of the heads I received had some core shift however I'm moving forward with this set of heads. Here are the flow numbers out of the box up Future posts will detail the changes made to the heads with new flow numbers beer
100 in 77.2 / ex 55.7
200 136.4 / 110
300 196 / 143.3
400 251 / 188.3
500 295.5 / 201.2
600 314.8 / 207.7
700. 318.4 / 209.3
All flow work performed on a SuperFlow SF-600 at Thunder Performance in Madison Heights, Mi. up
Core shift
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2315812
06/04/17 03:05 AM
06/04/17 03:05 AM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Sf 600
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2315894
06/04/17 12:32 PM
06/04/17 12:32 PM
The Great White North
RAMM Offline
RAMM  Offline
Thanks for the documentation! J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: Project 470 Underway!! New Victor Heads!! [Re: RAMM] #2315899
06/04/17 12:43 PM
06/04/17 12:43 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
When will you be posting the descriptions and flow tests for the additional work done? Those numbers are pretty sad for how that head is intended to be used.
Re: Project 470 Underway!! New Victor Heads!! [Re: PorkyPig] #2315912
06/04/17 12:59 PM
06/04/17 12:59 PM
RAMM Offline
RAMM  Offline
Those heads flow very poorly as do many. I see exactly that kind of flowrate on my bench. J.Rob
Re: Project 470 Underway!! New Victor Heads!! [Re: RAMM] #2315922
06/04/17 01:15 PM
06/04/17 01:15 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Man that is PATHETIC. Who the heck do they have designing these heads. You would think that after all these years they would be able to get it so much better out of the box.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2315924
06/04/17 01:23 PM
06/04/17 01:23 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
They go to the trouble of changing other things on those heads, but couldn't tweak the ports a little?
When they first came out, the Gen 1 heads would flow about 325-330 ootb. The Gen 2 was a big step backwards........and it appears that trend remains unchanged in the Gen 3.
Gen 2 head, ootb, Ede 2.20/1.81 valves, 4.375 bore, radius plate on intake, no flow tube on exhaust, #1 cyl;
Lift--------in/ex
.100---71.9/ 52.7
.200--135.9/99.7
.300--196.4/143.8
.400--249.4/174.8
.500--292.9/187.7
.550--309.9/189.0
.600--296.7/191.0
.650--304.2/191.7
.700--317.5/192.9
And....... If those numbers werent bad enough...... I could see the way the bowls/chambers showed a little core shift....... That the numbers would likely get progressively worse as you worked your way down to the other end of the head.
Same head as above, #7 cyl:
Lift---------in/ex
.100---64.2/51.0
.200--126.1/104.1
.300--183.4/143.8
.400--238.9/167.4
.500--281.6/174.8
.550--297.4/176.0
.600--311.8/176.0
.650--302.4/176.0
.700--308.7/176.0
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316056
06/04/17 05:23 PM
06/04/17 05:23 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
All that money and work to maybe match a stock Apache head.
Mopar to the bone!!!
Re: Project 470 Underway!! New Victor Heads!! [Re: fast68plymouth] #2316063
06/04/17 05:34 PM
06/04/17 05:34 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
This is our chance to let Edelbrock know what we think. This thread will be sent to them as they asked me for feedback up
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316072
06/04/17 05:45 PM
06/04/17 05:45 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline
Wedgeman  Offline
W
MY 360-1 SMALL BLOCK heads flow 343cfm at .700......
Why go big block ?
Dan
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316073
06/04/17 05:45 PM
06/04/17 05:45 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Gen 2 heads I ported for Brad H had what I consider ridiculously small bowls.
I ended up making them about .300" larger in diameter than as cast.
IMO they should be cast with the bowls around 2.00 int/1.64 ex.
They're supposed to be race heads....... They don't need to be great for a guy running a .480" lift cam, so the bowls/ports should be configured towards high lift race applications.
Re: Project 470 Underway!! New Victor Heads!! [Re: Wedgeman] #2316114
06/04/17 06:48 PM
06/04/17 06:48 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Why go big block ?
Dan
My 360-2 heads flow 337 @ .650...
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316117
06/04/17 06:52 PM
06/04/17 06:52 PM
So. Burlington, Vt.
So. Burlington, Vt.
And those 360-1 and 360-2 posts are relevant to this thread about BB Victor heads how?
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316128
06/04/17 07:11 PM
06/04/17 07:11 PM
AndyF Offline
AndyF  Offline
Are those Max Wedge Victors? If so, the flow numbers look pretty weak when compared to a Trick Flow head. Any chance the guy has Trick Flow numbers on the same bench? It would be nice to do a comparison if he does.
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316141
06/04/17 07:34 PM
06/04/17 07:34 PM
So. Burlington, Vt.
So. Burlington, Vt.
You can tell from the pics.......std port.
Re: Project 470 Underway!! New Victor Heads!! [Re: fast68plymouth] #2316178
06/04/17 08:42 PM
06/04/17 08:42 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Sorry I tried to delete my post but it will not let me.
Re: Project 470 Underway!! New Victor Heads!! [Re: AndyF] #2316222
06/04/17 09:42 PM
06/04/17 09:42 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Std port. He does not have Trick Flow heads to flow.
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316281
06/04/17 10:36 PM
06/04/17 10:36 PM
AndyF Offline
AndyF  Offline
Still seems a little weak for a standard port head. The Trick Flow 240 head numbers are a little better than that and I think they are less expensive but it probably depends on which parts you buy. The Trick Flow heads are fully CNC ported, not sure if the Victor heads are. From what I recall the Victor heads were only port matched but maybe they have changed that since I had my set many years ago.
Re: Project 470 Underway!! New Victor Heads!! [Re: AndyF] #2316322
06/04/17 11:38 PM
06/04/17 11:38 PM
Mopar Country, Mi
ccdave Offline OP
The Ultimate
ccdave  Offline OP
The Ultimate
Mopar Country, Mi
Just the port entries are cnc'd on these heads. We shall see what a valve job and some port work will do to improve the numbers.
Re: Project 470 Underway!! New Victor Heads!! [Re: ccdave] #2316360
06/05/17 12:45 AM
06/05/17 12:45 AM
AndyF Offline
AndyF  Offline
Not sure what value proposition that Edelbrock thinks they have selling a non-ported head for basically the same price as the fully ported Trick Flow heads. They call the Victor a race head but they don't give it enough installed height or good enough ports to really be a race head. The Victor heads are also heavier than they need to be because of all of the extra material on the intake face. They need to fix that design. It shouldn't take too much work, not sure why they don't do it.
