Re: Indy heads
[Re: MoparMichael]
#2315535
06/03/17 12:23 PM
06/03/17 12:23 PM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
I'm faster then everyone that posted and I run the cast iron -1 head. These guys are so set in there ways it's funny. Wheels up to the Christmas tree yes my car has not been washed in 3 years. 😝
Re: Indy heads
[Re: MoparMichael]
#2315553
06/03/17 12:53 PM
06/03/17 12:53 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My response is based on not being able to buy a new replacement if there was an incident that required it......... And they're heavier by a bunch than the aluminum equivalent........ So, unless they are extremely attractively priced, I don't see the upside.
I've tried to buy them for some tractor pull guys several times over the last 3 or 4 years, and they've never had any....... And couldn't give me a time frame for when they might.
Re: Indy heads
[Re: PorkyPig]
#2315963
06/04/17 02:47 PM
06/04/17 02:47 PM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
My memory ain't what it used to be but I thought the iron 440-1 heads have a reputation for cracking. I know Indy says they're 80 pounds heavier a pair than the aluminum version. I can attest to the weight! I considered using a come along to lift them into place!
Re: Indy heads
[Re: MoparMichael]
#2315978
06/04/17 03:05 PM
06/04/17 03:05 PM
Posts: 1,308 Spencer NY
killermopar
Spencer NY
That's a fast car. I don't think my back would take putting them on.
