McLeod Clutches #2315295
06/02/17 08:35 PM
06/02/17 08:35 PM
South San Francisco, Ca
70sixpkrt Offline OP
McLeod doesn't sell their 360153 Pressure Plates anymore. Does anybody know who still has some of these?
https://www.summitracing.com/nv/parts/mcl-360153/overview/
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: McLeod Clutches [Re: 70sixpkrt] #2315306
06/02/17 09:03 PM
06/02/17 09:03 PM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
I just noticed that too. Everything is diaphragm that i can find with them now.
Re: McLeod Clutches [Re: 70sixpkrt] #2315313
06/02/17 09:20 PM
06/02/17 09:20 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I don't know if it's still available, but McLeod offered a rebuild service of their line of pressure plates, if you still have one that needs refurbishing, try contacting McLeod directly
Re: McLeod Clutches [Re: 70sixpkrt] #2315317
06/02/17 09:33 PM
06/02/17 09:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Looks like they still offer the rebuild service
https://www.mcleodracing.com/content/mcleod-service-center/
Don't be the exception.
Re: McLeod Clutches [Re: 70sixpkrt] #2315473
06/03/17 04:39 AM
06/03/17 04:39 AM
If I can't find a new one, I'll probably call them about the rebuild process.
4-speed
3:54 Dana
Re: McLeod Clutches [Re: 70sixpkrt] #2315548
06/03/17 12:46 PM
06/03/17 12:46 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Darn that was my favorite pressure plate to use
Re: McLeod Clutches [Re: 70sixpkrt] #2315565
06/03/17 01:20 PM
06/03/17 01:20 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
Long story short, I have a used one with about 8K miles on it. If you decide you want to go that route, PM me, I'll give you the details.
I wound up buying a RAM setup. Hope it's as good.
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: McLeod Clutches [Re: Dixie] #2315567
06/03/17 01:22 PM
06/03/17 01:22 PM
Thanks Dixie but I like to find a new one. I might have to call Mcleod about their rebuilt service.
4-speed
3:54 Dana
Re: McLeod Clutches [Re: 70sixpkrt] #2320090
06/12/17 07:13 PM
06/12/17 07:13 PM
I just called Mcleod and they said they do not rebuild those pressure plates anymore. mad I also called Brewers and Passion Perf. and they have been recommending the Ram Pressure Plates since the Mcleods have been discontinued.
4-speed
3:54 Dana
Re: McLeod Clutches [Re: 70sixpkrt] #2320318
06/13/17 12:56 AM
06/13/17 12:56 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
maybe they have seen the light, IE: GM /Centerforce diaphragm clutch design shruggy
It does S-ck when a manufacturer tells you to go pound sand. In the last 20 years of being a shop owner, Centerforce has been our choice. In that time-frame, only 1 comeback. yes it was their problem and it took a bit of arm twisting, but they did step up and replace it / cover it eventually.
twocents beer
Re: McLeod Clutches [Re: TJP] #2386400
10/12/17 05:59 PM
10/12/17 05:59 PM
Update: I sent my discontinued Mcleod #360153 Pressure Plate to Mcleod to see if they will rebuild it. I got a call this morning and they said no problem. So if anybody is using this pressure plate, send it to Mcleod to get rebuilt. I have 2 more of these Pressure Plates that I'm going to send them for rebuild. This is what mine looked like:
4-speed
3:54 Dana
Re: McLeod Clutches [Re: 70sixpkrt] #2386439
10/12/17 07:07 PM
10/12/17 07:07 PM
Kirkland, Washington
Pacnorthcuda Offline
I wonder what the rebuild procedure is? Obviously they resurface the pressure plate itself, but then it's thinner. Do they then shim the springs to get the clamping force back to spec? Or replace all springs? Or just measure clamping force and if it's still within a spec range let it go?
Interesting
Re: McLeod Clutches [Re: 70sixpkrt] #2386754
10/13/17 11:24 AM
10/13/17 11:24 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
I've had both a pressure plate and disk rebuilt by Hayes before. Did a great job. Looked new. It was a low mileage unit but trans was out so why not.
Re: McLeod Clutches [Re: 70sixpkrt] #2386990
10/13/17 06:08 PM
10/13/17 06:08 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Clutch Pkg
This is what I ended up getting from Passion Performance in PA. 3-FINGER TYPE PRESSURE PLATE
McLeod Clutch Package 12" 23 Spline (Use With 143 Tooth Flywheel) Includes Disc, Pressure Plate, Throwout Bearing and Pressure Plate Bolts
Product Details...
Re: McLeod Clutches [Re: 70sixpkrt] #2387189
10/14/17 02:20 AM
10/14/17 02:20 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Check out KY Clutches..
502.955.9173
Talk to Chris or Dave, they can rebuild your clutch if U have the core pressure plate.
Also note Hays now part of Holley still list Borg & Beck pressure plates.
Just my $0.02... wink
Re: McLeod Clutches [Re: Sinitro] #2387285
10/14/17 11:51 AM
10/14/17 11:51 AM
New York
rarefish Offline
rarefish  Offline
New York
A couple weeks back, I called Ram to ask them about a "street" replacement clutch for my stock 69 Dart GTS and they recommended the kit #88766. It is a B&B type. I bought one from Summit Racing, but be aware that Summit's web site photo shows a diaphragm pressure plate. The Ram tech assured me that it would be a B&B pressure plate.
I has worked out very good for me. I'm happy with the pedal feel that it gives.
Re: McLeod Clutches [Re: 70sixpkrt] #2388754
10/17/17 02:56 PM
10/17/17 02:56 PM
Cruising!
Q
QuickDodge Offline
QuickDodge  Offline
Q
Cruising!
What is the difference in price between a new and a rebuilt clutch?
Re: McLeod Clutches [Re: 70sixpkrt] #2388770
10/17/17 03:23 PM
10/17/17 03:23 PM
McLeod doesn't make this particular clutch any more.
4-speed
3:54 Dana
Re: McLeod Clutches [Re: Pacnorthcuda] #2392325
10/24/17 01:51 PM
10/24/17 01:51 PM
Interesting
I just spoke with Mcleod on these questions. They said they resurface the pressure plate face and then they replace all springs and everything that is accompanied with it. After that, they check and make sure the clamping force is the same as a brand new unit.
4-speed
3:54 Dana
Re: McLeod Clutches [Re: 70sixpkrt] #2392578
10/24/17 10:00 PM
10/24/17 10:00 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
So its just like new! I sent my B&B to six states for rebuild, took a week to get it back....
http://www.sixstates.com/products/products.jsp
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
