Re: McLeod Clutches
[Re: Dixie]
#2315567
06/03/17 01:22 PM
06/03/17 01:22 PM
Posts: 3,675 South San Francisco, Ca
70sixpkrt
Long story short, I have a used one with about 8K miles on it. If you decide you want to go that route, PM me, I'll give you the details.
I wound up buying a RAM setup. Hope it's as good. Thanks Dixie but I like to find a new one. I might have to call Mcleod about their rebuilt service.
Re: McLeod Clutches
[Re: 70sixpkrt]
#2387189
10/14/17 02:20 AM
10/14/17 02:20 AM
Posts: 5,435 So Cal
Sinitro
So Cal
Check out KY Clutches.. 502.955.9173 Talk to Chris or Dave, they can rebuild your clutch if U have the core pressure plate. Also note Hays now part of Holley still list Borg & Beck pressure plates. Just my $0.02...
Re: McLeod Clutches
[Re: Pacnorthcuda]
#2392325
10/24/17 01:51 PM
10/24/17 01:51 PM
70sixpkrt
I wonder what the rebuild procedure is? Obviously they resurface the pressure plate itself, but then it's thinner. Do they then shim the springs to get the clamping force back to spec? Or replace all springs? Or just measure clamping force and if it's still within a spec range let it go?
Interesting I just spoke with Mcleod on these questions. They said they resurface the pressure plate face and then they replace all springs and everything that is accompanied with it. After that, they check and make sure the clamping force is the same as a brand new unit.
