no traction at the track #2312227
05/28/17 02:35 AM
05/28/17 02:35 AM
Pattison Texas
CSK Online shake_head OP
CSK  Online Shake_Head OP
Pattison Texas
this is the 2nd time out & nitto's just wont hook, but I had fun in my 4100lb AC, overdrive 68 Charger, it was a spin fest again, you can see I wrote the density altitude down for each run, & the what the car should run at sea level air, it was hot & we had a 20 mph head wind, still could not do any tuning cause NO traction, but I am pleased with the MPH.
Re: no traction at the track [Re: CSK] #2312229
05/28/17 02:44 AM
05/28/17 02:44 AM
New York, USA
Chargerfan68 Offline
New York, USA
What size and type of rear tires,suspension,shocks do you have? Also is it a stick or auto? That's good mph
Re: no traction at the track [Re: CSK] #2312232
05/28/17 02:56 AM
05/28/17 02:56 AM
Pattison Texas
Pattison Texas
nitto 555,325-50-15, caltracs & split mono leafs,a518overdrive, 3.54 gear ,stock type shocks, track prep was none.
Re: no traction at the track [Re: CSK] #2312235
05/28/17 02:59 AM
05/28/17 02:59 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Nittos suck
Re: no traction at the track [Re: CSK] #2312287
05/28/17 09:46 AM
05/28/17 09:46 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I used to have a fox body mustang that would run 12.30s on slicks. For my street tires I had run Nittos(275/50/15) and BFG plain old radial TAs in the same size. The nittos hooked better on the street but I ended up having way better luck at the track with the plain old BFG radial.
I have had great luck with the mickey thompson drag radials on my Barracuda.
68 Barracuda Formula S 340
Re: no traction at the track [Re: CSK] #2312295
05/28/17 10:18 AM
05/28/17 10:18 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
If the Nitto's are in good condition then keep them in the 18-24 lbs realm. Too much front weight bias, so keep it simple to work out the bugs. I hope you have the Calvert Ranchos for rear shocks set at 5 or 6. Try 300 lbs of bagged sand(contractors bagged sand that in HD bags with metal twist ties). 100 pounds over the right rear wheel and the remainder evenly spaced and the end of the trunk. This should gives you a base line.
Re: no traction at the track [Re: CSK] #2312421
05/28/17 03:18 PM
05/28/17 03:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The Nittos are a great street and highway tire. I've found they don't stick too well to a rubber coated surfaces. I go to the track so rarely that it would be hard for me to justify shelling out $ for a set of dedicated slicks. They've closed nearly all the local tracks around here. It's over a 2 hour ride to the closest ones.
Those are some very good times for a heavy car with those gears and limited traction. Nice build.
Re: no traction at the track [Re: jbc426] #2312456
05/28/17 04:36 PM
05/28/17 04:36 PM
Pattison Texas
Pattison Texas
This is my daily driver & I agree the nitto works great for that, & so far made it to the track twice in a years time, new slicks & rims are out of the budget right now, disc brakes in the front is my next project. the track is an 80 mile round trip for me, 85mph with the ac blowin cold on I-10 west smile
Re: no traction at the track [Re: CSK] #2312617
05/28/17 10:02 PM
05/28/17 10:02 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
MPH good for mid 11's...nice job, especially for a daily driver.
Re: no traction at the track [Re: CSK] #2312718
05/29/17 12:47 AM
05/29/17 12:47 AM
You say over drive, is this a stick or auto tranny?
If stick good luck on hooking that rascal up on radials at the track shruggy Slipping the clutch may work well, or bog it with real low RPM on the line and hope it sticks luck
Re: no traction at the track [Re: Cab_Burge] #2312734
05/29/17 01:19 AM
05/29/17 01:19 AM
Pattison Texas
Pattison Texas
It is an A518 auto overdrive.
Re: no traction at the track [Re: CSK] #2312799
05/29/17 09:10 AM
05/29/17 09:10 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You should be able to hook fine on a good tire. Does it have much front end lift for weight transfer ? Myself all I use is SS springs with the older non adjustable shocks and a 9" radial slick. I found as long as I make sure I stage in the grove which is the marks where all the cars are launching then I hook great even on radial slicks. But its important to stage in the tracks where all the cars have been launching for the best hook for me. At the 119 corrected mph thats low 11's with good hook. Whats the combo if you dont mind me asking ? Maybe you should try a better tire ? Good luck , Ron
Re: no traction at the track [Re: CSK] #2312836
05/29/17 10:32 AM
05/29/17 10:32 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
It's definitely making power, you've not nice mph. Nothing broke and you and the car made it back home, and it sounds like you had a good time anyway. also like Ron I'm interested to hear the combo.
I have the 555"R" on my b body, but I only use them for street. For strip I've always switched to Hoosier quick time pro/bias/wrinkle wall cheater slicks.
Rich H.
Esse Quam Videri
Re: no traction at the track [Re: jbc426] #2312934
05/29/17 01:10 PM
05/29/17 01:10 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Down here what the people with street tires do is to launch from the side where it is plain asphalt, rather than the treated area, seems to work well in that situation.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: no traction at the track [Re: 383man] #2313026
05/29/17 03:35 PM
05/29/17 03:35 PM
Pattison Texas
Pattison Texas
after I do the disc brakes I will save up & get some extra wheels & slicks, here is my engine spec, I built it & do my own port work, I have a little 110 Super Flow bench.
4.380" bore 4.250 stroke 6.536 H beam rod 440 SOURCE STROKER KIT
(.040 over) -24cc dish
1.320" 9.9 to1 comp
Indy single plane intake
Howards Cams​ solid flat tappet .579 lift 248 @.050 duration
Trend Performance Products​ custom push rods
& tool steel solid lifters edm oiling
440 source SUPER STEALTH heads flow 330 @ .650 lift,,,ALMOST Max Wedge port size.
THIS IS A STREET BUILD, yes the Charger has COLD A/C 3.54 rear gear, a518 overdrive with lock up torque converter
Holley 950 hp carb,, for now smile
Machine work done by G & G performance co in Tomball TX
Re: no traction at the track [Re: CSK] #2313108
05/29/17 05:46 PM
05/29/17 05:46 PM
Pattison Texas
Pattison Texas
Re: no traction at the track [Re: CSK] #2313129
05/29/17 06:18 PM
05/29/17 06:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Do you have 5 or 6 inches of front end travel??
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: no traction at the track [Re: CSK] #2313289
05/29/17 11:16 PM
05/29/17 11:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Very nice combo. I used a 440 Source kit with the 4.15 crank and D-dished pistons for 10.6 comp. I am at 493 cubes. You have the Stealth heads working good as my basic EZ heads are just opened up a little by Dwayne Porter and flow 329 @ .700. I also run a solid flat tappet cam. Nice looking and running Charger. Ron
Re: no traction at the track [Re: CSK] #2313626
05/30/17 04:08 PM
05/30/17 04:08 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
512ci, cold air conditioning, overdrive, mild gearing, sounds great. I like what you did with the air Pan for the scoop, that's a different approach and looks good.
Rich H.
Esse Quam Videri
Re: no traction at the track [Re: CSK] #2315195
06/02/17 05:12 PM
06/02/17 05:12 PM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
That is one nice looking Charger up
