no traction at the track
#2312227
05/28/17 02:35 AM
05/28/17 02:35 AM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
this is the 2nd time out & nitto's just wont hook, but I had fun in my 4100lb AC, overdrive 68 Charger, it was a spin fest again, you can see I wrote the density altitude down for each run, & the what the car should run at sea level air, it was hot & we had a 20 mph head wind, still could not do any tuning cause NO traction, but I am pleased with the MPH.
Re: no traction at the track
[Re: CSK]
#2312229
05/28/17 02:44 AM
05/28/17 02:44 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
What size and type of rear tires,suspension,shocks do you have? Also is it a stick or auto? That's good mph
[Re: CSK]
#2312232
05/28/17 02:56 AM
05/28/17 02:56 AM
CSK
Pattison Texas
nitto 555,325-50-15, caltracs & split mono leafs,a518overdrive, 3.54 gear ,stock type shocks, track prep was none.
[Re: CSK]
#2312287
05/28/17 09:46 AM
05/28/17 09:46 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I used to have a fox body mustang that would run 12.30s on slicks. For my street tires I had run Nittos(275/50/15) and BFG plain old radial TAs in the same size. The nittos hooked better on the street but I ended up having way better luck at the track with the plain old BFG radial.
I have had great luck with the mickey thompson drag radials on my Barracuda.
68 Barracuda Formula S 340
[Re: CSK]
#2312421
05/28/17 03:18 PM
05/28/17 03:18 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
The Nittos are a great street and highway tire. I've found they don't stick too well to a rubber coated surfaces. I go to the track so rarely that it would be hard for me to justify shelling out $ for a set of dedicated slicks. They've closed nearly all the local tracks around here. It's over a 2 hour ride to the closest ones.
Those are some very good times for a heavy car with those gears and limited traction. Nice build.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2312456
05/28/17 04:36 PM
05/28/17 04:36 PM
CSK
Pattison Texas
Those are some very good times for a heavy car with those gears and limited traction. Nice build. This is my daily driver & I agree the nitto works great for that, & so far made it to the track twice in a years time, new slicks & rims are out of the budget right now, disc brakes in the front is my next project. the track is an 80 mile round trip for me, 85mph with the ac blowin cold on I-10 west
[Re: CSK]
#2312718
05/29/17 12:47 AM
05/29/17 12:47 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
You say over drive, is this a stick or auto tranny? If stick good luck on hooking that rascal up on radials at the track Slipping the clutch may work well, or bog it with real low RPM on the line and hope it sticks
[Re: Cab_Burge]
#2312734
05/29/17 01:19 AM
05/29/17 01:19 AM
CSK
Pattison Texas
You say over drive, is this a stick or auto tranny? If stick good luck on hooking that rascal up on radials at the track Slipping the clutch may work well, or bog it with real low RPM on the line and hope it sticks It is an A518 auto overdrive.
[Re: CSK]
#2312836
05/29/17 10:32 AM
05/29/17 10:32 AM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
It's definitely making power, you've not nice mph. Nothing broke and you and the car made it back home, and it sounds like you had a good time anyway. also like Ron I'm interested to hear the combo.
I have the 555"R" on my b body, but I only use them for street. For strip I've always switched to Hoosier quick time pro/bias/wrinkle wall cheater slicks.
Rich H.
Esse Quam Videri
[Re: jbc426]
#2312934
05/29/17 01:10 PM
05/29/17 01:10 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Those are some very good times for a heavy car with those gears and limited traction. Nice build. Down here what the people with street tires do is to launch from the side where it is plain asphalt, rather than the treated area, seems to work well in that situation.
[Re: 383man]
#2313026
05/29/17 03:35 PM
05/29/17 03:35 PM
CSK
Pattison Texas
after I do the disc brakes I will save up & get some extra wheels & slicks, here is my engine spec, I built it & do my own port work, I have a little 110 Super Flow bench. 4.380" bore 4.250 stroke 6.536 H beam rod 440 SOURCE STROKER KIT (.040 over) -24cc dish 1.320" 9.9 to1 comp Indy single plane intake Howards Cams​ solid flat tappet .579 lift 248 @.050 duration Trend Performance Products​ custom push rods & tool steel solid lifters edm oiling 440 source SUPER STEALTH heads flow 330 @ .650 lift,,,ALMOST Max Wedge port size. THIS IS A STREET BUILD, yes the Charger has COLD A/C 3.54 rear gear, a518 overdrive with lock up torque converter Holley 950 hp carb,, for now Machine work done by G & G performance co in Tomball TX
[Re: CSK]
#2313626
05/30/17 04:08 PM
05/30/17 04:08 PM
ZIPPY
S.E. Michigan
512ci, cold air conditioning, overdrive, mild gearing, sounds great. I like what you did with the air Pan for the scoop, that's a different approach and looks good.
Rich H.
Esse Quam Videri
