upper control arm mod...need input please #231441
02/21/09 04:20 PM
02/21/09 04:20 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
I have a 72 demon and can't get it the front end with in spec. I replaced bushings and even welded up the camber bolts and still coming up short. Tubbular control arms would solve the problem but money is tight so I would like to just lengthen or shorten the upper control arm. Any one have a pic on where and how much to lengthen or shorten? The front end is alittle high for oil pan clearance I really don't want to go lower...oil pan makes it's own track in the snow as it sits now. Any input would be great. thanks
Re: upper control arm mod...need input please [Re: E85-408] #231442
02/21/09 04:22 PM
02/21/09 04:22 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
How about the Moog offset bushings. They could get you what you need. Maybe listed as: Problem Solver bushings.
Re: upper control arm mod...need input please [Re: bobby66] #231443
02/21/09 04:25 PM
02/21/09 04:25 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
Yes I thought about that and will go that route if I can't figure out how to mod the control arms. I really like the difference in poly compared to rubber and hesitant to go back to rubber. Thanks for the fast reply.
Re: upper control arm mod...need input please [Re: E85-408] #231444
02/21/09 04:43 PM
02/21/09 04:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The lower control arm take most of the loads. Getting the right performance alignment will outweigh any difference you feel or performance of the polys. You can't even get to the spec alignment numbers.
You can just take a 3/8" to 1/2" section out of the rear A-arm leg and pie slice the front leg then weld. Then overlap with some steel for good measure.
Re: upper control arm mod...need input please [Re: autoxcuda] #231445
02/21/09 04:59 PM
02/21/09 04:59 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
Thank you for fast reply. I wasn't meaning about performance difference...sorry if my reply mislead. Was refering to how long they last. It's a daily driver and have went through two sets up rubber between my last car and new one. I really don't enjoy replacing them. Again thanks for the info sounds alot easier then trying to extend one.
Re: upper control arm mod...need input please [Re: E85-408] #231446
02/21/09 05:07 PM
02/21/09 05:07 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
My offset rubber ones have been on the car since 1993 and about 50K miles and 5 winters in Iowa.
How long are yours lasting? I wonder if that and you not being able to get it to stock specs is related?
With modern radial tires you can run .5 degrees negative camber and 3 degree postive caster. Will make the car drive and track straighter and take some of the looseness feeling out of it.
Re: upper control arm mod...need input please [Re: autoxcuda] #231447
02/21/09 05:32 PM
02/21/09 05:32 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I find the poly doesn't last, after about 8000, miles with lots of city driving my poly bushings are done, torn up.
Re: upper control arm mod...need input please [Re: boydsdodge] #231448
02/21/09 05:55 PM
02/21/09 05:55 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
I was getting about 2 years out of them and the lowers were getting pushed to one side and pushing out bad. I figured uppers would do the same. I just replace them all at one time. Polys have been in for over a year and seem fine.
Re: upper control arm mod...need input please [Re: autoxcuda] #231449
02/21/09 07:12 PM
02/21/09 07:12 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Nice tip!
Re: upper control arm mod...need input please [Re: Lefty] #231450
02/22/09 04:31 AM
02/22/09 04:31 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Nice tip!
That's what the Super Stock A-body guys did to get a lot of caster. They probably bondo's things up a bit so or put the strap underneath were you wouldn't see it so much. I'm sure there are people doing this in the stock classes today even.
Re: upper control arm mod...need input please [Re: E85-408] #231451
02/22/09 10:25 PM
02/22/09 10:25 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
When I had trouble with my front end,I installed
problem solver bushings-still not enough. So I shortend my strut rod to pull the control arm forward. Did a garage floor alingment and the car drove great. A couple years later I wanted more caster so I bought tubular arms anyway. Mike
Re: upper control arm mod...need input please [Re: mkdart] #231452
02/23/09 01:04 AM
02/23/09 01:04 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Where you using the poly strut rod bushings? Those are thicker than stock by about 3/16". I shaved mine 3/16" in addition to running Moog 7103 offset bushings. How to here: http://users.erols.com/mathewg/bushings.html
I can get 5-6 degrees of postive caster if I keep the camber under 1/2 degree. I ran 1.5 negative camber this time and only could get 4.3 degrees positive caster.
What caster did you have before the tubular UCA's? How much now with the tubular UCA's.
Re: upper control arm mod...need input please [Re: autoxcuda] #231453
02/23/09 01:43 PM
02/23/09 01:43 PM
northeast ohio
mkdart Offline
mkdart  Offline
northeast ohio
Steve, I rebuilt the front end 6years ago, I bought
all rubber, But I think I used poly on the strut rods, not sure.
I welded the strut rods so I could create a new shoulder. Put the rod in a lathe, machined off the old shoulder and cut a new one.
1 degree max. caster w/ about 1 degree neg.camber w/ old A arms.
Settings now are 3.5 pos. caster, 1.5 neg. camber.
more is possible not sure how much.
Brad, sorry if this looks like a hyjack.
Mike
Re: upper control arm mod...need input please [Re: mkdart] #231454
02/26/09 01:39 PM
02/26/09 01:39 PM
USA IN
E85-408 Offline OP
E85-408  Offline OP
USA IN
no problem. I'm learning all I can.
Re: upper control arm mod...need input please [Re: E85-408] #231455
02/26/09 07:13 PM
02/26/09 07:13 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
is your car stock height? and are you using stock specs. if you have changed height(most of us have) you have to consider the angles, they will change the factory specs. I have a tire store and do alignments, a younger tech will go by factory specs and not comp for heigth changes, make sure who is doing align knowns this
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
