Torque spec #2314213
05/31/17 04:03 PM
05/31/17 04:03 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Hi. Need the torque spec for a clutch pressure plate, 68 charger with 440 and a 23 spline 833. Thanks, my service info system doesnt go back that far without emailing them, my bet is you guys are faster. Thanks!
Re: Torque spec [Re: bbtrux] #2314236
05/31/17 05:08 PM
05/31/17 05:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Don't be the exception.
Re: Torque spec [Re: bbtrux] #2314246
05/31/17 05:39 PM
05/31/17 05:39 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
No idea how to view that...
Re: Torque spec [Re: bbtrux] #2314249
05/31/17 05:43 PM
05/31/17 05:43 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Re: Torque spec [Re: bbtrux] #2314287
05/31/17 07:58 PM
05/31/17 07:58 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use 35 Ft. Lbs. or 12x35=420 inch Lbs., if you have a inch lb. torque wrench that will do that amount up
They should be 3/8x16 grade 8 pressure plate bolts scope If not get the proper torque specs. for your bolts up
