Fusible link issue 70 challenger
#2313569
05/30/17 02:34 PM
05/30/17 02:34 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
I replaced the link because it was hanging by a few strands. I put a fuse holder in place with a 20 amp fuse. It has blown the fuse a couple of times in about 300 miles. While out for a drive yesterday it quit while I was driving,now it blows the fuse as soon as I plug it in. With digital meter I am seeing 000.0 at first then goes to 000.8 or so after a second or so on the red wire and a couple of others on middle plug on bulkhead. Seems dumb but I'm not sure if I'm reading resistance across a winding or something when it goes to 000.8? If I unplug the bulkhead connector it goes open on the meter.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
Re: Fusible link issue 70 challenger
[Re: moparfan]
#2313584
05/30/17 02:51 PM
05/30/17 02:51 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Based on your description it sounds like you are trying to measure resistance while the circuit is hot. Generally not advised. If so, what you may be seeing is the resistance increase slightly as the fuse gets hot. If you are measuring votlage drop, that's OK and the explanation is the same. Take a look at this overview of the charging system power flow. I think what has happened is: 1. the battery did not get sufficiently recharged. 2. as the battery voltage decreases, the voltage regulator tries to have the alternator supply more current for recharge. 3. 20 amp quick fuse blows immediately under the larger load. If so, then everything should be back to normal after recharging your battery with a charger and installing a new fusible link. You'll have to dig through the service and parts books for the correct amperage for your car's fusible link.
[Re: stumpy]
#2313738
05/30/17 07:08 PM
05/30/17 07:08 PM
moparfan
Marysville Wa
Sorry guys, sometimes difficult to put into words. The tests with the meter were done with the battery + side disconnected. I did use the negative side for ground for the meter lead.
The battery is not dead. This is happening driving down the road.
I have no issue putting another fusible link in. My concern is I have a short. As soon as I put a fuse into the holder it blows it if the battery is connected. The other 2 times this happened I replaced the fuse and it was fine for some time.
Trying to isolate the issue with a meter and the readings are confusing me.
If I'm reading 000.0 when I first test and it goes to 000.8 on the meter a second later or so I'm wondering if I'm reading resistance on something inside the car on that circuit or if I have a short on that wire?
Where I'm taking this reading is at the bulkhead connector where the red wire that goes to the amp meter is. I'm confused if the 000.8 to ground is a short or reading resistance in the amp meter or the rest of that circuit?
[Re: ahy]
#2313885
05/30/17 11:30 PM
05/30/17 11:30 PM
RapidRobert
Agreed, I would slo charge the battery back up (if it ain't already) & replace the fusible link then (eng off) with all lights etc off including doors shut pull off a batt cable from its post after dark & see if there is a spark which if so would confirm a short somewhere that is drawing current & with everything off nothing should be "on" & drawing current or in the daytime switch your meter to the highest DC amp scale & work the meter amp scale setting downward with the probes on the batt post & the cable & should be no flow. Holler back.
[Re: moparfan]
#2313948
05/31/17 12:27 AM
05/31/17 12:27 AM
Posts: 12,234 Looking for a way out of Middl...
IMGTX
A. A 20amp fuse is too little. The Alternator can put out a minimum of 40amps, more if you have upgraded it. Additionally if you add all the fuses together and add the headlights (they usually have a built in circuit breaker in the switch IIRC), that is the potential load your fuse has to handle. Either way you look at it, the voltage potential is too great for a 20amp fuse. Most modern cars use multiple 40 to 60 amp fuses or a single 100 to 150 amp fuse on the main lead.
B. How much have you done to the rest of the harness? Is it new, used and untouched, or used and repaired?
C. I often use a circuit breaker in place of the fuse during diagnostics while I am looking for the problem.
Since it seems you have a short try this.
1. Pull all the fuses from under dash and check to see if the 20amp fuse you are using blows. 1a.If it doesn't blow then replace the fuses 1 at a time until it does. Remove the last fuse before placing the next one in place to prevent erroneous/cumulative current problems. When it blows, that circuit is the problem.
2. If it blows without any fuses installed, disconnect the wires to the alternator and make sure they don't short. Does it still blow?
3. If it still blows check the bolt on connections to the ammeter, a common problem. Does it still blow?
4. If the ammeter is not the problem disconnect the ignition switch wires, another common problem. Does it still blow?
5. Disconnect each switch and connector under the dash one at a time. Pay close attention to the fan switch and wiring. Does it still blow?
6. If everything is disconnected and it's still blowing fuses then it's probably a short in the harness. If you repair the harness it is most likely the alternator/ammeter wiring circuit since it feeds everything in the harness.
I make the following modifications when I rewire a harness. 1. Solder all connections for the Ammeter circuit. 2. Place a fusible link at the bulkhead and the alternator. A runaway alternator will burn up a harness just as fast as a short. 3. Check the Ammeter connections extremely well. NO PLASTIC WASHERS. Ammeters build up heat and require HI-TEMP insulators. 4. Don't run the ammeter wires through the bulkhead connector. Either run continuous long loops of wire through a hole in the firewall to eliminate the connectors OR use bolt on, through the firewall, terminals for a better connection. I have drilled holes through the bulkhead connector and pushed a loop of wire through the hole to eliminate the spade terminals in the bulkhead connector. Not convenient to disconnect that way though. 5. Solder the large wires going to the ignition switch under the column to eliminate the bullet connectors that fail often.
Hope it helps.
[Re: IMGTX]
#2313950
05/31/17 12:31 AM
05/31/17 12:31 AM
RapidRobert
^^^ good info. #1 pin down the short. EDIT This has been bothering me, the Fl only had a few strands left/you replace with a fuse/fuse wouldn't cut it. any possibility that there is no short?? & when you replace the FL it'll all be good. MORE EDIT I did not read back thru everything but did you say that there was no problem other than the FL was hanging on by a thread (the several strands)?
[Re: RapidRobert]
#2314130
05/31/17 12:20 PM
05/31/17 12:20 PM
moparfan
Marysville Wa
Thanks for all the info guys. history, I bought the car last year, had been sitting for years but still ran and drove when I bought it. I decided to freshen up the engine, clutch etc after I went through the car after purchase.
I removed everything from the engine compartment when the engine was out so I could clean everything. When cleaning the harness I noticed the fusible link only had a few strands of wire holding it on. I replaced that with a fuse holder and selected a 20a fuse (no idea why, seemed like a good place to start lol).I replaced the voltage regulator with an NOS one and the starter relay, left everything else as it was.
I got the car running again and drove it this way for about 200 miles, mostly short in town trips but one 60 mile trip. The fuse stayed intact until recently. The first time the fuse blew I had just installed a pertronix ignition in the original distributor, While I was driving it the fuse blew.I found I forgot to tighten the wire that goes to the positive side of the coil. I replaced the fuse and away I went. Monday I drove the car about 10 miles, when I left to go home I'm driving down the road and the car just quits. I pull over and the fuse is blown again. I go to replace the fuse and it blows the fuse as soon as I go to install it in the fuse holder. I get the car home and Test the fuse holder to ground and that is where the meter is showing 000.0 when I first test it, hold the lead in place and after a very short time ( a second or 2) the meter will climb to 000.8. My confusion is the 000.8 a short or resistance from the alt or something in the car?
I have not disconnected the power wire from the alt to bypass that yet.
All of the meter testing I've done was with the battery disconnected. When the fuse blows I have the key off and battery connected.
[Re: moparfan]
#2314138
05/31/17 12:52 PM
05/31/17 12:52 PM
Posts: 10,721 North Dakota
6PakBee
North Dakota
You are overthinking this. All of the individual accessory circuits, with the exception of the charging circuit, are protected with either fuses or circuit breakers. A fusible link is designed to protect against a gross overload of the entire electrical system. Replace your fuse with the correct fusible link and then start troubleshooting. Having the fuse in there is only muddying the waters.
[Re: 6PakBee]
#2314142
05/31/17 01:07 PM
05/31/17 01:07 PM
moparfan
Marysville Wa
I don't want to ruin the $3.00 fusible link if I have a short I'll grab a parts store fusible link and install and see what happens. Thanks again for the help.
[Re: moparfan]
#2314147
05/31/17 01:24 PM
05/31/17 01:24 PM
IMGTX
6pak is right about the accessory circuits are probably not the problem.
If you insist on a fuse go to at least a 40 amp. I am currently running a 30amp in my /six No AC/Radio/Washer pump barracuda and it works OK but I don't drive at night when I would need headlights.
I lay odds the fusible link was just a victim of age, every spike weakens them and eventually the individual wires inside start to break one buy one until a catastrophic failure occurs. If it's an unmolested or improperly repaired harness I lay odds the problem lies in the harness itself. It is very common for the main power wire to slowly melt over time and short into other wires. Eventually it will find a ground through a circuit and the fusible link goes bye bye. I had one melt into the headlight switch wiring. I couldn't turn off my parking lights but I could dim them with the dash panel dimmer.
The wiring from the factory is minimal at best. I bet if you peel back the cover on the harness behind the fuse block you will find the black or red large gauge wires are melting.
Rebuilding a harness is pretty easy. Pull the whole dash and lay it on a bench. Pull the harness and unwrap it using plastic ties to keep the bundles loosely configured so it will be easier to re-wrap. Inspect the wires and if you find a bad one SOLDER a repair/replacement wire in it's place. Do not use crimp connections alone. Those are a bandaid that will eventually fail. Re-place the main power wires with a wire at least 1 gauge larger and don't use the factory bulkhead/harness connectors for the main power (ammeter/Alternator) and main ignition switch wiring.
[Re: moparfan]
#2314148
05/31/17 01:25 PM
05/31/17 01:25 PM
6PakBee
North Dakota
I don't want to ruin the $3.00 fusible link if I have a short .... That's why I used the term "troubleshoot". If you suspect a problem, and I believe you do, don't just replace the link, hook up the battery, fry the link, and say "Gee, I think I have a problem". Do your homework.
[Re: moparfan]
#2314157
05/31/17 01:40 PM
05/31/17 01:40 PM
IMGTX
I don't want to ruin the $3.00 fusible link if I have a short I'll grab a parts store fusible link and install and see what happens. Thanks again for the help. You can buy a 10 foot roll of Fusible link at Napa for about $10. Cut to length and add ends. Napa even sells the connectors that go into the bulkhead connectors if needed but I don't suggest you run the main power through the factory bulkhead... I think I may have mentioned that in my wordy previous posts. LOL I bought two rolls, one 14 and one 12 gauge, years ago and still have most left.
[Re: IMGTX]
#2314160
05/31/17 01:54 PM
05/31/17 01:54 PM
moparfan
Marysville Wa
Thanks guys, I did pull the fuse panel off the bulkhead and look at the wires inside the car. I was actually surprised how well everything looked, no discoloration or melted insulation etc. I'll update the post when I have results.
[Re: moparfan]
#2314536
06/01/17 12:40 PM
06/01/17 12:40 PM
moparfan
Marysville Wa
Update, had a little time last night. Made up a 14 gauge fusible link and installed. There is a short. The short is on the charging circuit shown in your diagram Mattax. I checked the alternator 12v terminal to ground and it is not shorted.
Hum, I powered the Pertronic to the + and - side of the coil. I'm wondering if I powered the coil with the wrong wire from the charging circuit when I put the engine back in? This issue did start after I changed over to the pertronic ignition.
I'll get my service manual out and start chasing wires to see what's going on.
Mike
[Re: moparfan]
#2314622
06/01/17 03:28 PM
06/01/17 03:28 PM
6PakBee
North Dakota
Hmmm. Did you disconnect the battery lead from the alternator and then check each one separately? It seems odd that the charging circuit is the culprit but the lead at the alternator doesn't indicate that. The only time I have ever personally seen something like this was on a 360 where the harness to the alternator had rubbed on the intake manifold and there was an intermittent short to ground. Took a long time to find that one.
