Gen II Hemi Blower Manifold
#2312341
05/28/17 12:06 PM
05/28/17 12:06 PM
Posts: 554 Mesa , Az
Jambbii
Mesa , Az
Looking for any input on blower manifolds (fitment etc). I have zero experience and it seems like there are a few to choose from. Indy has a couple, Stage V, and other blower shops. Any feedback would be appreciated.
Josh
70 Challenger 1960 Town Wagon P Pump 24v cummins project 06 Mega 3500 Drw 2wd 12 Durango R/T 18 Power Wagon 67 A100
Re: Gen II Hemi Blower Manifold
[Re: Jambbii]
#2312629
05/28/17 10:34 PM
05/28/17 10:34 PM
Jambbii
Mesa , Az
Either going PSI or the Whipple 8L. I am going injection (E 85). From what I understand most of the time you want to inject above
[Re: polyspheric]
#2312630
05/28/17 10:35 PM
05/28/17 10:35 PM
Jambbii
Mesa , Az
If you limit the choice to top-mounted positive displacement types (Roots, GMC, Kobelco, Sprintex, KenneBell, Eaton, BDS) you'll find that the really big power manifolds have a triangular top opening which aligns with the blower's discharge window. That's right - those rectangular tops that you see on most Gen-2 manifolds are not what those Pro Mods use, because that's not where the air goes. Very interesting! Thanks Polysheric!
[Re: Jambbii]
#2312731
05/29/17 01:07 AM
05/29/17 01:07 AM
Superfreak
Superfreak
Will be using a Stage V for mine with 2 x 1050 Quickfuel carbs
[Re: ]
#2312936
05/29/17 01:12 PM
05/29/17 01:12 PM
Jambbii
Mesa , Az
Will be using a Stage V for mine with 2 x 1050 Quickfuel carbs That looks like a nice piece. Did you purchase it yet?
[Re: cudacustoms1]
#2312938
05/29/17 01:14 PM
05/29/17 01:14 PM
Jambbii
Mesa , Az
Is the PSI roots or screw charger? From what I have been told a screw blower moves the air completely different than a roots. A roots constantly pushes the air to the front of the case and it tends to come out at ruffly a 45 degree angle. Thats why you see a lot of racers moving the blowers back on the manifold. Even the newer blower are moving the rotors future and future back in the cases. The big roots blowers do have a triangle shape bottom. Each manufacture is probably a little different position.Those blowers are for purpose built race cars. Is this a street or race aplication> Mostly a street car. PSI makes both but I will be using the screw if I use them. There have been a few people that have had luck with fuel injection and the C rotor believe getting it to behave on the street.
[Re: Jambbii]
#2313340
05/30/17 12:42 AM
05/30/17 12:42 AM
Superfreak
Superfreak
Will be using a Stage V for mine with 2 x 1050 Quickfuel carbs That looks like a nice piece. Did you purchase it yet? Not yet $1100US which will be about $2000 with exchange and shipping by the time I get it in my hands. My car will be street/strip running a 14/71 standard Littlefield.
[Re: FastmOp]
#2313348
05/30/17 12:59 AM
05/30/17 12:59 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
The pan evac valve was stuck.It pushed oil right up the intake bolts.Capped the evac tube on the headers and installed 2 puke tanks with breathers.
[Re: hemi-itis]
#2314450
06/01/17 02:46 AM
06/01/17 02:46 AM
Jambbii
Mesa , Az
Any complaints on design or fitment?
