Pictures fuel pressure regulators #2312193
05/28/17 12:44 AM
05/28/17 12:44 AM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Any pictures of where you have your fuel pressure regulators mounted thank you
Re: Pictures fuel pressure regulators [Re: scottb] #2312213
05/28/17 01:40 AM
05/28/17 01:40 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Scott, I have always put mine on the passenger side inner fender, just in front of the firewall.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Pictures fuel pressure regulators [Re: scottb] #2312216
05/28/17 02:03 AM
05/28/17 02:03 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I've got mine right on the intake manifold, yeah, I know...a bit of a heat sink I suppose, but I was trying to stick to as "stock looking" as possible approach, seems to work.
Re: Pictures fuel pressure regulators [Re: scottb] #2312223
05/28/17 02:18 AM
05/28/17 02:18 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Pictures fuel pressure regulators [Re: scottb] #2312356
05/28/17 12:38 PM
05/28/17 12:38 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Mounted mine on front of intake so that low pressure fuel will be in rearward motion during run.
Re: Pictures fuel pressure regulators [Re: scottb] #2312360
05/28/17 12:47 PM
05/28/17 12:47 PM
New Smyrna Beach FL
scottb Offline OP
scottb  Offline OP
New Smyrna Beach FL
Looks very nice
Re: Pictures fuel pressure regulators [Re: J_BODY] #2312394
05/28/17 02:06 PM
05/28/17 02:06 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By J_BODY
BANGSHIFT. up
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Pictures fuel pressure regulators [Re: scottb] #2312610
05/28/17 09:43 PM
05/28/17 09:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A couple of pieces I bought at a dirt track race shop and welded together.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pictures fuel pressure regulators [Re: pittsburghracer] #2312665
05/28/17 11:35 PM
05/28/17 11:35 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
We have our RobbMC regulator mounted on the right front inner fender on the 70 RR. I figured forward was good in terms of being away from heat. The RobbMC filter is mounted just below it for easy access. We have a bigger filter before the Mallory 140 in the back. Nice thing about this regulator it can be easily converted to a return style when the time comes.
Yes, I did fix the loose alternator bolt. I was doing some vacuum advance testing at the time of these pictures hence the hoses to the vacuum pump.
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Pictures fuel pressure regulators [Re: scottb] #2312818
05/29/17 10:03 AM
05/29/17 10:03 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Re: Pictures fuel pressure regulators [Re: scottb] #2312970
05/29/17 01:52 PM
05/29/17 01:52 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What I've learned is a fuel gauge is NO different than any other that needs to be monitored while driving so what good is it under the hood? I have solved several fuel/carb issues do to too MUCH or not enuff fuel pressure under hard load where it matters...........you can idle on 1 lb. try that at 5000+ rpm`s and get back w/us............. coffee
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2313020
05/29/17 03:28 PM
05/29/17 03:28 PM
PA.
"Little"John
"Little"John
PA.
I run both as I like to take a peak at it while doing maintenance. The black wire on mine goes inside to the Racepak and also monitored on my dash. You can never be to safe.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Pictures fuel pressure regulators [Re: scottb] #2313262
05/29/17 10:03 PM
05/29/17 10:03 PM
Az
Crizila Offline
Crizila  Offline
Az
Mine
Fastest 300
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2313282
05/29/17 10:54 PM
05/29/17 10:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
On mine I put a gauge at the regulator to set the fuel pressure when I installed it. I figure if I have a problem then I can always get a gauge for either on the cowl or in the car to read it when I race. But I dont race alot and the car has always run good with no fuel starving problems so I have not worried about putting a fuel gauge where I can read it when driving the car. If I ever have problems and have to do some diagnosing then I will put one in. Ron
Re: Pictures fuel pressure regulators [Re: 383man] #2313338
05/30/17 12:40 AM
05/30/17 12:40 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I get it BUT, you sure can spot an issue like a stuck N&S which could kill the oil in short order or like on a car I built a carb for w/damn near zero pressure as we approached 5000 r's. To each his own I guess........... beer
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2313341
05/30/17 12:42 AM
05/30/17 12:42 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
I totally agree. In a street car, when the car is having problems, that gauge will diagnose half of what the problems can or cant be.
Re: Pictures fuel pressure regulators [Re: Thumperdart] #2313404
05/30/17 05:55 AM
05/30/17 05:55 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I actually agree with you and of course since I did not buy a fuel gauge for in the car when I switched from the Holley red pump with no ext reg to the black pump with the ext reg I just mounted this gauge right on the reg so I could set my fuel press with the adjustable reg. And I also agree the fuel press gauge is a great diagnosis tool as I have been a tech most of my adult life since 1974. But I also can tell if I am having a fuel problem pretty quick since I have been a tech most of my life and have never had any major problems with my car from a fuel press problem to warrant a gauge in the car. And living on disability I have to watch my cash flow closely. Thats pretty much why I did not install a fuel press gauge in my car. But again I do agree if you install a fuel press gauge on your car its best to install it where you can watch it while going down the track and if I was not such a cheapsake I would buy the in car gauge and install it on my car. grin Course if I had more play money I would also be a little faster. drive smile Ron
Re: Pictures fuel pressure regulators [Re: 383man] #2313512
05/30/17 12:49 PM
05/30/17 12:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I made a little cluster for my cowl to see vacuum and fuel pressure another great way to see pv opening/closing points also......... beer
Re: Pictures fuel pressure regulators [Re: scottb] #2313544
05/30/17 01:46 PM
05/30/17 01:46 PM
Suffolk County, New York
1mean340 Offline
1mean340  Offline
You can kind of see it on the passenger side firewall back there. I needed a pretty big open space to mount it as I have a Y block attached it (dual feed to the FITECH throttle body, deadheaded at the throttle body and have the return out the bottom of the regulator).
Re: Pictures fuel pressure regulators [Re: scottb] #2313548
05/30/17 01:53 PM
05/30/17 01:53 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Carb gurus will tell you to never solid mount a regulator. Always let them hang off the lines. For a single 4 Holley type application they always are mounted on pass side of engine hanging from the lines.
