Re: Pictures fuel pressure regulators
[Re: scottb]
#2312213
05/28/17 01:40 AM
05/28/17 01:40 AM
Posts: 11,717 Portage,michigan
B3422W5
Portage,michigan
Scott, I have always put mine on the passenger side inner fender, just in front of the firewall.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: scottb]
#2312216
05/28/17 02:03 AM
05/28/17 02:03 AM
Posts: 1,760 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
I've got mine right on the intake manifold, yeah, I know...a bit of a heat sink I suppose, but I was trying to stick to as "stock looking" as possible approach, seems to work.
[Re: scottb]
#2312223
05/28/17 02:18 AM
05/28/17 02:18 AM
Posts: 13,198 aZLiViN
J_BODY
aZLiViN
[Re: scottb]
#2312818
05/29/17 10:03 AM
05/29/17 10:03 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
[Re: scottb]
#2312970
05/29/17 01:52 PM
05/29/17 01:52 PM
Thumperdart
State of confusion
What I've learned is a fuel gauge is NO different than any other that needs to be monitored while driving so what good is it under the hood? I have solved several fuel/carb issues do to too MUCH or not enuff fuel pressure under hard load where it matters...........you can idle on 1 lb. try that at 5000+ rpm`s and get back w/us.............
[Re: Thumperdart]
#2313020
05/29/17 03:28 PM
05/29/17 03:28 PM
Posts: 20,180 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What I've learned is a fuel gauge is NO different than any other that needs to be monitored while driving so what good is it under the hood? I have solved several fuel/carb issues do to too MUCH or not enuff fuel pressure under hard load where it matters...........you can idle on 1 lb. try that at 5000+ rpm`s and get back w/us............. I run both as I like to take a peak at it while doing maintenance. The black wire on mine goes inside to the Racepak and also monitored on my dash. You can never be to safe.
[Re: scottb]
#2313262
05/29/17 10:03 PM
05/29/17 10:03 PM
Posts: 7,506 Az
Crizila
Az
Any pictures of where you have your fuel pressure regulators mounted thank you Mine
Fastest 300
[Re: Thumperdart]
#2313404
05/30/17 05:55 AM
05/30/17 05:55 AM
383man
Balt. Md
I get it BUT, you sure can spot an issue like a stuck N&S which could kill the oil in short order or like on a car I built a carb for w/damn near zero pressure as we approached 5000 r's. To each his own I guess........... I actually agree with you and of course since I did not buy a fuel gauge for in the car when I switched from the Holley red pump with no ext reg to the black pump with the ext reg I just mounted this gauge right on the reg so I could set my fuel press with the adjustable reg. And I also agree the fuel press gauge is a great diagnosis tool as I have been a tech most of my adult life since 1974. But I also can tell if I am having a fuel problem pretty quick since I have been a tech most of my life and have never had any major problems with my car from a fuel press problem to warrant a gauge in the car. And living on disability I have to watch my cash flow closely. Thats pretty much why I did not install a fuel press gauge in my car. But again I do agree if you install a fuel press gauge on your car its best to install it where you can watch it while going down the track and if I was not such a cheapsake I would buy the in car gauge and install it on my car. Course if I had more play money I would also be a little faster. Ron
[Re: scottb]
#2313548
05/30/17 01:53 PM
05/30/17 01:53 PM
Posts: 19,369 Las Vegas
Al_Alguire
Las Vegas
Carb gurus will tell you to never solid mount a regulator. Always let them hang off the lines. For a single 4 Holley type application they always are mounted on pass side of engine hanging from the lines.
