Nooone stocks 60 over stroker pistons #2309943
05/23/17 06:46 PM
05/23/17 06:46 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Looking for a set of 8
Discontinued from fed mogul
Any leads
H838 cp060
I think they were common on mp crates
Thanks in advance
Re: H838 cp060 pistons [Re: sogtx] #2309966
05/23/17 07:44 PM
05/23/17 07:44 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
No one I have called can seem to match it I guess it means pull everything and rebalance
Re: H838 cp060 pistons [Re: sogtx] #2309978
05/23/17 08:12 PM
05/23/17 08:12 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
If it was me it would be getting a full teardown anyway. What does the cylinder wall look like?
Re: H838 cp060 pistons [Re: GomangoCuda] #2310034
05/23/17 10:28 PM
05/23/17 10:28 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Luckily still see light hashmarks walls are perfect.
Gonna yank all 8 and see . Bearings look good .
If i cant find a matched piston ,
No easy fix .
Cp doesnt make strokerp istons i guess
So much for rattle can rebuild ... frown
Want to do it right , but summer is here
I think a piston replace would make it til winter .
Oh well .
Re: H838 cp060 pistons [Re: sogtx] #2311385
05/26/17 06:59 AM
05/26/17 06:59 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Yep -Gonna be a slightly boring start to summer hope it doesnt get hot out .
Noone can match 1 or 8 pistons
Noone stocks a piston set
Noone , even 440 source has a 60 over stroker kit.
Hopefully the piston people can make a set quick
Since this happened to me with cast , and im sure i deserved it sometime along the way , should I try to go forged next time?
Going to go from 10.5 to 9.5
Thought i could easily stroke up to 4250 crank and get a new balanced kit next dayed .
With a smaller rod journal so I didnt have to grind memorial day away and be done in a couple days , but No .
Everything I own has to be difficult.
Re: H838 cp060 pistons [Re: sogtx] #2311395
05/26/17 08:37 AM
05/26/17 08:37 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I purchased my 4.380" flat tops 4.15" stroke from 440 Source, but several years ago. Were in stock and shipped right out. Mine have .990" wristpins. What size pin are you looking for? Maybe a stock pin is the problem?
[image][/image]
Re: H838 cp060 pistons [Re: sgcuda] #2311701
05/26/17 07:19 PM
05/26/17 07:19 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Yes big pin 1.094
Re: H838 cp060 pistons [Re: sogtx] #2311796
05/26/17 11:11 PM
05/26/17 11:11 PM
sgcuda Offline
sgcuda  Offline
Bush your rods and go with .990 pin.
[image][/image]
Re: H838 cp060 pistons [Re: sgcuda] #2312153
05/27/17 10:32 PM
05/27/17 10:32 PM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Hmm
Good idea , might add some weight ?
Not much i guess
Re: H838 cp060 pistons [Re: sogtx] #2312172
05/27/17 11:35 PM
05/27/17 11:35 PM
sgcuda Offline
sgcuda  Offline
Actually, it should lose weight due to a lighter wristpin. Rod bushing doesn't weigh much.
[image][/image]
Re: H838 cp060 pistons [Re: sogtx] #2312263
05/28/17 06:26 AM
05/28/17 06:26 AM
Norway (old world)
Oyvind Mopar Offline
Norway (old world)
Hi, I have a set of new H838 CP 060 pistons, please PM me if you want to buy. Only issue is my location, but sending to USA should be no big deal.
Re: H838 cp060 pistons [Re: Oyvind Mopar] #2312302
05/28/17 10:45 AM
05/28/17 10:45 AM
upstate western ny
sogtx Offline OP
sogtx  Offline OP
upstate western ny
Geesh - wish i would have known couple days ago lol.
Wonder how long shipping takes from Norway.
How in heck do you have a set if these ?
Re: H838 cp060 pistons [Re: sogtx] #2312319
05/28/17 11:19 AM
05/28/17 11:19 AM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Try RaceTec/AutoTec in SoCal and see what they can do for you in their AutoTec line. It wouldn't be a stocking part but it should at least be worth a phone call. Get rid of the cast slugs and put forged ones in since it's torn down already.
