driveshaft material? #2311026
05/25/17 04:46 PM
05/25/17 04:46 PM
Mesa, AZ
cagebob1 Online content OP
cagebob1  Online Content OP
Mesa, AZ
aluminum? DOM steel? c/m? carbon fiber? and why?
Re: driveshaft material? [Re: cagebob1] #2311036
05/25/17 04:59 PM
05/25/17 04:59 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
C/M. you can run less diameter than the others and the terminal velocity is way past what you and I might get into. AND... the price is right.
Re: driveshaft material? [Re: cagebob1] #2311050
05/25/17 05:19 PM
05/25/17 05:19 PM
Renton Washington
Triple Threat Offline
Renton Washington
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: driveshaft material? [Re: cagebob1] #2311092
05/25/17 06:31 PM
05/25/17 06:31 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Steel, the weight saving of CF, AL is really small and very little inertia due to small diameter.
Boffin Emeritus
Re: driveshaft material? [Re: cagebob1] #2311284
05/26/17 12:15 AM
05/26/17 12:15 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
just ordered an aluminum shaft for my impending 904 project. About anything I've ordered/bought/changed on the car since getting it from my dad has leaned toward the lighter..... except the R3 and W8s.
Re: driveshaft material? [Re: cagebob1] #2311312
05/26/17 01:01 AM
05/26/17 01:01 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I depends on the use of the car. If it is a heads up car, or in anything where the lowest possible ET matters, you need to save every ounce you can. An aluminum or CF shaft is a good way to do that.
If lowest ET is not your goal and low cost is important, steel is a durable, budget friendly way to go. According to Monte Smith, CF is safest because it disintegrates when it breaks, minimizing damage to the car and risk to the driver.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: driveshaft material? [Re: cagebob1] #2311317
05/26/17 01:09 AM
05/26/17 01:09 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Chrome Moly
Re: driveshaft material? [Re: J_BODY] #2311537
05/26/17 02:29 PM
05/26/17 02:29 PM
Mesa, AZ
Mesa, AZ
J Body, care to share who you ordered your shaft from? and the quoted price?
Re: driveshaft material? [Re: cagebob1] #2311601
05/26/17 04:06 PM
05/26/17 04:06 PM
organ
maximum entropy Offline
organ
i like big and dumb. mine is 3.5 dom. built by mark williams in ventura cali (no relation, i don't think). he dared me to hurt it. so far this monster is laughing at my pathetic attempts. big and dumb. with big and dumb solid 1350 u joints.
Re: driveshaft material? [Re: cagebob1] #2311725
05/26/17 07:52 PM
05/26/17 07:52 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
$660 delivered with 904 1350 slip yoke. 3.5" Inland Empire Driveline
https://www.iedls.com/?a=Custom_Aluminum_Driveshafts#Home
Re: driveshaft material? [Re: J_BODY] #2311757
05/26/17 09:35 PM
05/26/17 09:35 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Jay did you do exhaustive research on the shock loading ability of the aluminum vs steel shaft and the weight difference, or did you buy it because it was shiny?
"Just a Bracket car dressed up like a streetcar"
Re: driveshaft material? [Re: cagebob1] #2311775
05/26/17 10:29 PM
05/26/17 10:29 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I went with Inland as that's the direction I was led when I was having vibration issues with the Mirada. The faster we went, the more frequent we would break tailshaft housings. That driveshaft had been "checked" at two different shops and deemed "ok". Although I had tailshafts stacked like cord wood, I was worried my supply would end. The piece I got from Inland stopped the breakage. I'm sure there are many other "performance" oriented driveline shops that could have achieved this also... just not the one that built our steel one smile
Strength in the aluminum shaft is usually met with larger diameter, but for the length the 3.5 diameter should hold anything I throw at it (and Inland agreed). I've also been "trying" to go the lighter route on parts within reason when I can. Lb here, lb there = LBS smile
If it isn't shiny are you asking if you can polish my shaft?
Re: driveshaft material? [Re: J_BODY] #2311833
05/27/17 01:04 AM
05/27/17 01:04 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Jay polishing your shaft might be a good idea to prevent stress risers from forming. But should probably be done in the privacy of your own garage.
Re: driveshaft material? [Re: Just-a-dart] #2311888
05/27/17 03:21 AM
05/27/17 03:21 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
work
Re: driveshaft material? [Re: cagebob1] #2312038
05/27/17 04:54 PM
05/27/17 04:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
50 years ago, someone much smarter than me said "no race car is ever finished, until you build the next one".
What does that mean: what you don't spend for the unobtanium driveshaft will buy that fuel pump you'll need next month.
Boffin Emeritus
Re: driveshaft material? [Re: cagebob1] #2312137
05/27/17 09:24 PM
05/27/17 09:24 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
think I followed that analogy my first time with the Mirada and ended up buying so many parts twice that car could have been in the 8's if I just spent the right money the first time smile
Re: driveshaft material? [Re: J_BODY] #2312192
05/28/17 12:43 AM
05/28/17 12:43 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Somebody really smart once told me "when you buy the best, it only hurts once".
Re: driveshaft material? [Re: cagebob1] #2312259
05/28/17 05:02 AM
05/28/17 05:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I went with the Mark Williams 3.5" Chromoly with 1350 U-Joints, and the matching trans slip yoke. The rear end is the Strange S60 with 1350 yoke.
