driveshaft material?
#2311026
05/25/17 04:46 PM
05/25/17 04:46 PM
Posts: 305 Mesa, AZ
cagebob1
Mesa, AZ
aluminum? DOM steel? c/m? carbon fiber? and why?
Re: driveshaft material?
[Re: cagebob1]
#2311092
05/25/17 06:31 PM
05/25/17 06:31 PM
Posts: 4,207 New York
polyspheric
New York
Steel, the weight saving of CF, AL is really small and very little inertia due to small diameter.
Boffin Emeritus
[Re: cagebob1]
#2311312
05/26/17 01:01 AM
05/26/17 01:01 AM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
I depends on the use of the car. If it is a heads up car, or in anything where the lowest possible ET matters, you need to save every ounce you can. An aluminum or CF shaft is a good way to do that. If lowest ET is not your goal and low cost is important, steel is a durable, budget friendly way to go. According to Monte Smith, CF is safest because it disintegrates when it breaks, minimizing damage to the car and risk to the driver.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: cagebob1]
#2311601
05/26/17 04:06 PM
05/26/17 04:06 PM
Posts: 5,080 organ
maximum entropy
organ
i like big and dumb. mine is 3.5 dom. built by mark williams in ventura cali (no relation, i don't think). he dared me to hurt it. so far this monster is laughing at my pathetic attempts. big and dumb. with big and dumb solid 1350 u joints.
[Re: J_BODY]
#2311757
05/26/17 09:35 PM
05/26/17 09:35 PM
Posts: 1,454 Glendora Ca.
Just-a-dart
Glendora Ca.
Jay did you do exhaustive research on the shock loading ability of the aluminum vs steel shaft and the weight difference, or did you buy it because it was shiny?
"Just a Bracket car dressed up like a streetcar"
[Re: J_BODY]
#2311833
05/27/17 01:04 AM
05/27/17 01:04 AM
Just-a-dart
Glendora Ca.
Jay polishing your shaft might be a good idea to prevent stress risers from forming. But should probably be done in the privacy of your own garage.
[Re: cagebob1]
#2312038
05/27/17 04:54 PM
05/27/17 04:54 PM
polyspheric
New York
50 years ago, someone much smarter than me said "no race car is ever finished, until you build the next one". What does that mean: what you don't spend for the unobtanium driveshaft will buy that fuel pump you'll need next month.
Boffin Emeritus
