SB rockers #2309782
05/23/17 02:09 PM
05/23/17 02:09 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
Have a 360 with Edelbrock heads and solid cam currently only has as a .528 lift, but may upgrade in the future to something that is closer to the .600 lift range. I'm currently using stock 273 factory rocker arms. I would like to upgrade them to something a little better, would love to get a set of Harland Sharps, but they are pricey. Has anyone used Comp camps 1622-16 or Mancini Racing rockers? Any issues with them? This is a race only motor and only see's 6500 rpm max.
Re: SB rockers [Re: DusterKid] #2309789
05/23/17 02:25 PM
05/23/17 02:25 PM
Sac, CA
mopowers Offline
mopowers  Offline
Sac, CA
I can't answer any of your questions, but you can buy those comp rockers online through autozone for $460 using their 20% discount. Just an FYI.
Re: SB rockers [Re: DusterKid] #2310137
05/24/17 01:13 AM
05/24/17 01:13 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Many stocker eliminator drivers spin a trued 273 rocker in excess of 7000 rpms.
Re: SB rockers [Re: DusterKid] #2310279
05/24/17 11:44 AM
05/24/17 11:44 AM
Earth
Rob C Offline
Rob C  Offline
Earth
I have used the Comp roller lifters for a long time. Very good.
I just picked up Hughesengines roller lifters for another small block. They have a good reputation and I heard but don't know, there made by Dove.
Re: SB rockers [Re: DusterKid] #2310417
05/24/17 03:46 PM
05/24/17 03:46 PM
I use to race and build NHRA stocker motors, most stock OEM ductile iron rocker ratio vary a LOT shock
Some of the better after market aluminum and steel rocker do also puke
I buy the best rocker I can justify for my builds up
That being said I don't put Jesels on a pump gas street motor but I do use Harland Sharp aluminum roller rockers a lot thumbs I'm building a pump gas 340 4 inch stroker motor now with Harland Sharp rocker assembly, nice stuff thumbs
I have had RAS blueprint, bush and ratio correct stock ductile iron rockers in the past, no more tsk The reason being for a little bit more($100.00 to $300.00) I can buy brand new race parts work shruggy
