I use to race and build NHRA stocker motors, most stock OEM ductile iron rocker ratio vary a LOT
Some of the better after market aluminum and steel rocker do also
I buy the best rocker I can justify for my builds
That being said I don't put Jesels on a pump gas street motor but I do use Harland Sharp aluminum roller rockers a lot
I'm building a pump gas 340 4 inch stroker motor now with Harland Sharp rocker assembly, nice stuff
I have had RAS blueprint, bush and ratio correct stock ductile iron rockers in the past, no more
The reason being for a little bit more($100.00 to $300.00) I can buy brand new race parts
