Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Medlock51] #2309388
05/22/17 10:35 PM
05/22/17 10:35 PM
aZLiViN
J_BODY Online rolleyes
J_BODY  Online Rolleyes
aZLiViN
Originally Posted By Medlock51
I'm exploring building a carb'd Gen 3 for my dirt late model deal... rebuilding a small block 383 right now.
Seems to me it will be cheaper than buying a Ritter block and W-2 or ported aftermarket heads. Plus the good Eagle heads are better than most any small block head and are on the shelf at my local dealer 6 blocks away.
The juice lifter deal is my only question mark... can they live for 25 laps on a 1/2 mile at 7,000 rpm's? The T&D/Jesel numbers don't fit my budget right now so solid lifters are pretty much a no go.
We'll see.....
there was a member here that built a GenIII for a dirt modified here. Seems they had some bearing probs, but corrected some oiling issues and it worked.... can't for the life of me remember who it was.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2309529
05/23/17 01:48 AM
05/23/17 01:48 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I have only had decent flat top pump gas BB's. I have a decent flat top stroked Gen III now and it's a no brainer. This 45 yr old is done with the old stuff, unless I have something fall into my lap and the budget dictates.
Mopar to the bone!!!
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: J_BODY] #2309530
05/23/17 01:51 AM
05/23/17 01:51 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
We'll see.....
CHAPPER did, and it took an aftermarket crank to get to live at 8000+ and a 13qt pan iirc.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: DaytonaTurbo] #2309614
05/23/17 09:23 AM
05/23/17 09:23 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Originally Posted By DaytonaTurbo
I'll stick with the old school junk. Regardless of what anyone says, the Gen 3's are more expensive to build and install. The headers, oil pans and engine mounts they require are not cheap. The rotating assemblies in side the junkyard pickup truck 5.7's are just that, junk. For a fun, 500-600hp street car, an old school RB build can be done for a fraction of the cost without roller-this or stroker-that.
you know the old Hemi guys in the 60s felt the same way about the 440's and small block Chevys
Time has a way of moving forward, and it's a good thing that some people stay in the past....
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: 72Swinger] #2309642
05/23/17 10:17 AM
05/23/17 10:17 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
We'll see.....
Yep, I think it was the 6.1 crank's cross drilling that caused oil starvation
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310168
05/24/17 02:56 AM
05/24/17 02:56 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I don't think he used a 6.1 crank, IIRC he used a 5.7 crank.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310256
05/24/17 10:54 AM
05/24/17 10:54 AM
Tacoma, Washington USA
Adam71Charger Offline
I keep seeing the word cost thrown around. What's the comparative ballpark dollar value for a guy starting from scratch?
No friend deals and nothing sitting in garage, buying aftermarket stuff at full price, blocks from junkyard or Craigslist, assembling everything himself except the short block, and also paying a shop for machining... what would be the cost to build a turn key 700hp BB vs a turn key 700hp G3 street engine, with headers and motor mounts to fit in a late 60's B body?
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Adam71Charger] #2310266
05/24/17 11:21 AM
05/24/17 11:21 AM
PA.
pittsburghracer Offline OP
"Little"John
"Little"John
PA.
Ohhhhh boy. This should get good.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Adam71Charger] #2310274
05/24/17 11:37 AM
05/24/17 11:37 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
For your 700 hp Gen III you can use junkyard stuff, sixpackgut would be one of the guys to answer this question the best.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310312
05/24/17 12:47 PM
05/24/17 12:47 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Your shortblock cost will likely be about the same because it will all be aftermarket rods, crank, pistoms, etc. The top end is where the G3 will shine. Factory heads, lifters, and rockers. The intakes are still stupid expensive but your still cheaper with a G3 IMO.
When you get to ignition for the BB you need to buy, a coil, a distributor, an ignition box, and plug wires. For the Hemi you can use your stock coils and get an MSD Hemi 6 to handle everything else.
Your headers and mounts will likely cost about the same for either engine.
68 Barracuda Formula S 340
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: Adam71Charger] #2310324
05/24/17 01:03 PM
05/24/17 01:03 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
And we're off! This is a honest look, apples to apples for the 600-650 HP target. Of note, one can find Eagle heads cheaper than my listed $750, just threw that number out there. There is also a new single plane Arrow intake that hit the market for $550. Of course there is more than one approach to the build, these were comparable parts and their costs:
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310325
05/24/17 01:03 PM
05/24/17 01:03 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
No need for anything other than good rods and pistons to build a 700 hp 440. I have a .030" over 440 that makes about 700 hp w/ a stock crank and block.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310331
05/24/17 01:20 PM
05/24/17 01:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Ummmm I'm with Chip. The 440 that was in the Dragster had stock block and crank 440 Source rod and pistons. Small roller and OOTB -1 heads. Did not have a ton of money in it as the heads, intake, and rockers were all bought used(wont buy from Indy). Basic machine work and balancing and off she went. 8.30/160 all the time in Vegas between 675-700
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310336
05/24/17 01:34 PM
05/24/17 01:34 PM
Renton Washington
Triple Threat Offline
Renton Washington
The costs are about the same regardless of platform. I've done the math, created spreadsheets and even built a few of them.
Al is cheating and using used parts. He also broke the block in his dragster so there is that to consider. I haven't heard of any G3's splitting blocks at those power levels.
While you might be able to save some money on using a stock crank in a 440, you're going to save money using factory G3 heads over the Indy varieties mentioned above that are >$3K new.
It's a balancing act, I continue to take the stance though that it doesn't matter, you're going to end up spending the same money give or take a few bucks.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310337
05/24/17 01:34 PM
05/24/17 01:34 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
cudadoug, that's pretty spendy for a 600hp RB. I see 2.5k worth of stuff there you do not need for only a 600hp RB based stroker.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310342
05/24/17 01:38 PM
05/24/17 01:38 PM
cudadoug Offline
cudadoug  Offline
My spread sheet isn't to say one is better then the other, it's just a side by side comparison. However, with the exception of the block cores (and Gen 3 heads) these are NEW part prices.
We all have had "not a ton of money" in bullets before as they're are always used parts deals to be had someplace. The above example is based on: acquire the used cores and then open the required catalogs and order.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310352
05/24/17 01:57 PM
05/24/17 01:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Broken block because I didn't bother to chrck it, I have the tools :)Didn't think we needed to bother, obviously wrong. Nothing wrong with buying used parts and making them useable. A lot of stuff out there to purchase for a song. Just have to realize they will need work. I have put together a lot of low dollar BB's over the years that were well under $6K.
I have built, sold, bought a TON of stuff over the years. I buy a lot of "used" stuff that has never been used. Contrary to popular belief I am not a rich guy, just try to be smart about it. I have looked into the gen 3 stuff and as of yet am not overly impressed. Must be the old guy in me. For me bang for the buck a BB is going to be easier way to make that kind of power. Not poopooing anyones stuff but have not seen many NA Gen 3 pieces that make me sit up and take notice.
Maybe someone needs to do the Gen 3 like the LS guys do. Buy a junkyard Gen3 bolt a turbo on it and run it. When it blows go get another. Seems to work for a lot of fast LS stuff
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310421
05/24/17 03:56 PM
05/24/17 03:56 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I just bought a complete eagle 109,000 miles, non mds engine off CL for $300 threw it in my truck and am driving it now. That is a screaming deal but I frequently see cores around $500 and have 2 sitting under the bench right now. I more commony find the early ones for under $500 and have 3 of them sitting around. While it will not get you 700 HP (probably be close with some cubes and compression thrown in the short block with a good $500 arrow intake) a new 6.4 cam (.577 lift) from the dealer cost me $68 and matching valve springs are under $200. If thats not enough regrind it for under $100 to get you what you need. The factory lifters in that core usually will work in a 700 hp motor, stock 440 ones not so much and the cheap regrind only gets you a flat tappet cam. Another thing about the new hemi, real nice, MLS head gaskets are $22 from autozone.
Really though I don't see a reason to build your own stroker gen III when you cna buy a 6.4 short block from the dealer for around $2500 or in other words the price of a 6.4 stroker kit for your 5.7. Mill your boneyard heads for a little comp, do a little port clean up, throw on a good intake and you probably can be under $4000 in a quality motor then the exterior stuff is very similar price like quality headers.
Another option is buy a complete used 6.4 off car part . com or ebay throw in a bigger cam, better intake and quality headers and you can be close to 700 at the flywheel without even pulling the heads. After all they are making nearly 500 SAE net with sucky exhaust and emmision friendly tune and cam and a quietified intake.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310423
05/24/17 04:02 PM
05/24/17 04:02 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Guess we need to see more timeslips. I am a visual guy and short of Dustin and Ray have not seen to many slips at all. Also what kind of money do those two have in their set ups? I am genuinely curious. FWIW I have nott seen to many cheap core engines but I am sure they are out there. We considered it for my old truck at one point and may again.
Re: So a Friend asked me why won't you build a Gen 3 Hemi [Re: pittsburghracer] #2310473
05/24/17 05:38 PM
05/24/17 05:38 PM
K
KOS Offline
KOS  Offline
K
Dave_S combo
5.7 (+.020) from an 05 Ram
Home ported eagle heads (stock valves) Manley DragPak springs
6.1 crank, K1 rods, Wiseco dished pistons 10.7:1 comp
6.1 cam and lifters. Trend stock length 5/16 pushrods
stock rockers
6.1 intake with 90mm t/body
MS3x inj. with ford motorsports 160 lb/hr injectors
76mm turbo a/a intercooler
9.47@144 so far
3000lb Dart 3.23 gears in 8 3/4. powerglide
has gone 8.93 now
dont know how to attach a link but for those interested check out post:please share your gen 3 hemi builds
lots of good info
