Dana 60 with spool question #2310066
05/23/17 11:29 PM
05/23/17 11:29 PM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
Recently purchased a rotisserie restored 67 Dart street car. Has never been driven. Until today that is. Went about 2 blocks and really felt like I was fighting this car to get it rolling. Car has a 526 Stroker so should be no problem. Dana 60 with Strange spool and 4:56 gear set. Brought it home, jacked up the rear. Rear wheels are VERY hard to turn by hand. Should have done this before but.... Checked rear for the obvious...fluid level. Can see that things look like they have a coating of lube but can't feel any with my pinky. My understanding is the Dana 60 takes 3 quarts. I just put 2 in it til it just started to ooze out of the hole. Checked tranny next. 833 4 speed. Also low. Took about 40 oz and again my research shows about 64oz capacity? Pulled wheels and drums. drums adjusted correctly and emergency brake is not hung up. So my question is (and forgive my ignorance, still learning) is a brand new rear with a spool going to be difficult to turn by hand just in general? Will this eventually loosen up after a break in period? Or should I never drive this again until i have this rear checked for proper shimming and bearing clearances before I break something expensive? If I grab the driveshaft by hand and rotate it it seems to spin more free in reverse than forward direction. A friend of mine drove it down the street after I did and said its fine, that's how a spool is. I ain't buying it.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310082
05/23/17 11:51 PM
05/23/17 11:51 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
They are tight when hand turning especially when all new. Don't think you hurt anything driving it low on fluids, but drive it around now that it's topped off. The spool is gonna cause a fair amount of resistance on turns and curves.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310089
05/23/17 11:58 PM
05/23/17 11:58 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
How far did you drive? How fast did you go?
New rear end set up turns harder than a used one, and they will loosen up with some driving.
You are to drive a little bit and let it cool down, and do it several times before continuous driving. A spool will want to stop the car when turning the steering while
pushing in the staging lanes.
What trans? Torque flights are harder to turn one direction and easier the other direction.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310093
05/24/17 12:01 AM
05/24/17 12:01 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
A spool directly connects both axles solidly so you are having to turn everything in the rear end as well as the drive shaft and some trans internals. It will be stiff. It also isn't very street friendly because it makes both tires turn the same speed in corners which will cause wheel hopping. Running a spool on the street is asking for rear end failure. Snapped wheel studs and other untoward results.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310096
05/24/17 12:05 AM
05/24/17 12:05 AM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
Not far. Couple blocks. Not fast. 20mph down my street.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310101
05/24/17 12:10 AM
05/24/17 12:10 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen this before when the housing was bent. Pull one axle out and then try it until you figure out which side it is. When I had 4.56 gears in mine it was hard to turn the wheel. I have seen some slight rust build-up cause the gears to bind.
Pull the cover and look at it shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310112
05/24/17 12:21 AM
05/24/17 12:21 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Just put a brand new strange dana 60 in my Demon with 4.56 gears with spool...and yes it was hard to turn by hand.
Tony
70 AARCuda Vitamin C
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310175
05/24/17 03:37 AM
05/24/17 03:37 AM
Cab_Burge Online work
Cab_Burge  Online Work
a properly set up Dana 60 with any gear ratio and a spool should not turn hard under any street, straight line movement. Jack the car up and put it on jack stands and then try turning one wheel or the other to see how hard it turns forwards and backwards, if it is hard (you need to strain to turn the tire with both hands)then disconnect the driveshaft and try again. If it is easier with it disconnected look at the transmission scope
If it is still hard you need to find out why before you go any further twocents
Good luck, let us know what you find thumbs
BTW, Mopar engineers use to recommend using one quart only of gear grease in both the Dana 60 and one in NP833 for drag racing only shruggyIn fact we use to run one quart of ATF only in the NP833 for drag racing, that work real well thumbs
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310179
05/24/17 03:45 AM
05/24/17 03:45 AM
renton , washington
P
perfmachst Offline
perfmachst  Offline
P
renton , washington
I just set up a dana 60, 5.38 gears, doesn't turn hard at all!!!I'd pull back cover and measure back lash. also, I was told total shims should measure .103 total on spool. while you are there, check pattern on gears. I assume you have the green axle bearings?
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310202
05/24/17 09:04 AM
05/24/17 09:04 AM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
I am going to drop the driveshaft tonight and see if there is any difference. As far as transmission is concerned I know for sure I am going to be spending some time adjusting the linkage. Gears were hard to find during test drive and won't stay in gear unless shifter is held in place. Again, since the car was never driven since built, I figured there would be a few bugs to work out. Just trying not to break something expensive right off the bat. When up on jack stands I must restate that I had to use both hands and quite a bit of force to get the wheels to budge even an inch.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310247
05/24/17 10:33 AM
05/24/17 10:33 AM
an8sec70cuda Offline
I only run 2 quarts of fluid in Dana 60 rearends. That's all it needs...street or strip.
Running a spool on the street is not asking for failure of any kind...been doing it for years and never had one problem.
It will turn a little harder w/ the spool, but may just be tight b/c of the new bearings.
Unless they set it up way too tight or the housing is bent like Cab said.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310415
05/24/17 03:43 PM
05/24/17 03:43 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Does everyone run their new setup on jack stands for 10 or 15 mins. before running it with a load? That is what my rear end guy always told me to do. You should be able to wiggle the driveshaft or tire back and forth a tiny bit before it starts turning the whole shabang. If it has no backlash I would be a little suspect. I don't see a problem with the spool on the street either. I would imagine you would run some sort of ET tire with it which will slip good enough in parking situations where turning might be tight. Redline shock proof gear oil is your friend, 2 quarts is all it takes.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2310531
05/24/17 07:19 PM
05/24/17 07:19 PM
Pennsylvania
67DeLuxe Offline OP
67DeLuxe  Offline OP
Pennsylvania
On jackstands I can rotate the driveshaft a bit back n forth before it catches, Yes.
Re: Dana 60 with spool question [Re: 67DeLuxe] #2311614
05/26/17 04:21 PM
05/26/17 04:21 PM
dogdays Offline
dogdays  Offline
Car on jackstands
drop driveshaft
Attempt to turn rear tire.
With the car trying to go forward, any small variation in tire diameter will bind up the rear and you'll be having to partially slide one tire while the other rolls. It's just a thought.
R.
