Re: paint job on a budget!?
[Re: The Avg. Valiant]
#23090
05/21/06 04:01 PM
05/21/06 04:01 PM
You can buy it from Autobodystore.com: http://makeashorterlink.com/?M19A3142DQuote:
I was watching trucks or musclecar or one of those, and they said something about that roller primer. Anyone know anything about that? What its called, where to get it? Jacob
#23091
05/21/06 04:41 PM
05/21/06 04:41 PM
Did you do a final sand with 2000gt? If your surface is looking grey it is probably because of scratches in the surface. I think 800gt is too coarse. Using an electric polisher works great. However, even with the Turtle Wax POLISHING COMPOUND it takes time. Once you finish with the polishing compound you should come to a nice smooth surface.. then you could follow up with a wax. I am not sure if the paint is the problem because others have been successful.
Cheers, -Serp
thanks for the tips, I dont know how much more work i'm going to put into this car, its just my beater :-). I'm already satified with the results since my expectations where low to start with.
#23092
05/21/06 05:46 PM
05/21/06 05:46 PM
how soon can it be waxed after being painted? I recall someone saying that it will be over 2 weeks before the paint drys.
Nick
#23093
05/21/06 05:54 PM
05/21/06 05:54 PM
Posts: 1,220 toronto canada
69chargeryeehaa
toronto canada
Nick
wax right after buffing, that's what i did, usually on the last day after the last wetsand i let it sit in the sun for a few hours, on my orange bug i painted it in the dead of a canadian winter, no issues. unlike automotive paints that use hardners and reducers, the rust paint just has the mineral spirits and all the solvent gasses escape in 4 hours or so, from there on it just dries harder, automotive paints release gasses for weeks after painting, that's why u can't wax for at least 2 weeks.
[Re: 69chargeryeehaa]
#23094
05/21/06 07:04 PM
05/21/06 07:04 PM
I gave up on painting my hood red as I didn't like how the color turned out. I decided to use semi-gloss black instead. I am not getting the results I'm looking for. Can anyone give me some advice on this? Here is a pic:
#23095
05/21/06 07:09 PM
05/21/06 07:09 PM
69chargeryeehaa
toronto canada
if u want semigloss don't wetsand and polish it, unless u go with gloss.
#23096
05/21/06 07:15 PM
05/21/06 07:15 PM
Are you saying that I should dry sand instead? I like the way the color/flatness is, but I am having trouble figuring out how to avoid those dang runs. I've read all pages in this thread and applied every "good" method, but I still get those. Blah.
#23098
05/21/06 07:32 PM
05/21/06 07:32 PM
my integra hood is kicking my butt also. the rest of the car is ok and the paint went over super nice on the polyurthen(ms) bumpers.
if you figure it out tell me. that picture looks just like my hood.
Nivk
#23099
05/21/06 09:14 PM
05/21/06 09:14 PM
Exit, how many coats have you done so far, and do you have any spots where the original paint can be seen still?
I'm on effectively coat #6 and there are a couple areas where you can kind of see a little dark below... but I'm doing THIN coats.
#23100
05/21/06 09:16 PM
05/21/06 09:16 PM
i think if you place the good on a slant it will not have those problems. I'm going to try that tomorrow.
Nick
#23101
05/21/06 09:29 PM
05/21/06 09:29 PM
Posts: 3,377 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
I've still only done the 6 coats and it's see through in spots where there was dark.
The weather has been weird here and I'm waiting for the temps to go back up and the humidity down.. should be ready to roll again Wednesday if the weather man is right.
#23102
05/21/06 09:33 PM
05/21/06 09:33 PM
Exit1965
Rancho Cordova, CA
Nick
I think that would result in more runs. Perhaps your application method is different on the horizontal areas, even slightly, to where you're putting too much paint there since that is what causes the runs.
Press all the paint you can out of that roller (or as much as you can do within about 10-15 seconds) then firmly apply it to the surface. If done right it will leave enough paint to cover the surface but wont show any signs of running at any angle the surface happens to be on.
[Re: Exit1965]
#23103
05/21/06 09:53 PM
05/21/06 09:53 PM
Thanks Exit, I'll try that next coat. I get alot of bubbles when I press on the roller like that, but I'll do it anyway and see what type of results I can get.
#23104
05/21/06 11:06 PM
05/21/06 11:06 PM
Exit1965
Rancho Cordova, CA
Ive only gotten bubbles if there's too much paint on the roller.. squeeze more of it out, pushing the roller hard into the bumps in the tray to get it out, then there shouldn't be any bubbles at all.
#23105
05/22/06 07:41 AM
05/22/06 07:41 AM
Jacob, It was a PPG product which means it's probably pretty pricey. Personally I plan on experimenting with Rustoleum's rusty metal primer and a roller. Jax2A
[Re: BigTerry]
#23107
05/22/06 03:04 PM
05/22/06 03:04 PM
69chargeryeehaa
toronto canada
have anyone try mixing the paint and stuff and take a hood or trunk lid hanging it over a tub and pour the paint over it and letting it drain and pour it on for another coat??
haha, and then do the roof how??????????
[Re: BigTerry]
#23108
05/22/06 03:13 PM
05/22/06 03:13 PM
Exit1965
Rancho Cordova, CA
Why on earth would anyone try that?
[Re: Exit1965]
#23109
05/22/06 03:59 PM
05/22/06 03:59 PM
Yeah, really.
I had better luck putting the car and paint in a huge plastic bag and shaking it vigorously.
Just make sure you tape off the windows and stuff first.
