Left Front Tire Squeal #2309125
05/22/17 03:16 PM
05/22/17 03:16 PM
Kentucky, USA
RoadrunnerCN Offline OP
Kentucky, USA
I upgraded the front drum brakes on my 1970 Satellite to disk brakes. After that, I had the car aligned. Everything was out. I drove it about 7 miles and at low speeds (like 25 - 30 mph) when turning I'm getting tires squeal like you'd hear if the tire was very low or as if someone was doing a burn out. The wheel bearings are new so that can't be it. I thought maybe it was the alignment, but I had it aligned. Any suggestions on what it could be? The place that did the alignment said no parts needed to be replaced (I asked them to check the tie-rods because they looked a bit worn.) and they said they didn't need replacing. I jacked up the car and with hands on the wheel at 3 and 9 there is a slight bit of movement. No movement with my hands at 12 and 6 (which confirms new wheel bearings). After only 7 miles, to me, it looks like I have some positive camber. What the heck could be causing this? Thanks.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309164
05/22/17 04:13 PM
05/22/17 04:13 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Caster/camber Adjusters were not tight and moved when it was driven.
Please explain how this confirms new bearings.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309165
05/22/17 04:13 PM
05/22/17 04:13 PM
tennessee
P
pushbutton Offline
pushbutton  Offline
P
tennessee
Sounds like they didn't know what they were doing.Try to find a place with a older guy doing the alignment.It's not rocket science but some seem to have trouble with our stuff.
Re: Left Front Tire Squeal [Re: pushbutton] #2309181
05/22/17 04:40 PM
05/22/17 04:40 PM
I took mine to a well respected guy who was very experienced with our stuff. When I picked it up it looked good and drove good. By the time I got home the tires were squeeling and the camber was obviously way off. Dropped it back off the next day and he redid it and also found paint caked in the threads from a previous owners paint job. He had torqued them but the paint had jammed the threads affecting the actual tightness. He fixed it for no charge and I would have no qualms about going back to him.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309228
05/22/17 06:20 PM
05/22/17 06:20 PM
call em up & tell them how it is acting & make an appt to bring it back in for them to check it out.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309238
05/22/17 06:30 PM
05/22/17 06:30 PM
Kentucky, USA
Kentucky, USA
Thanks all! I did some searching in the archived posts and found one that suggests the caster/camber adjuster was fully tightened or may have worked loose even with such few miles due to paint or grime on threads. Makes sense. I ready your posts and called them back. They do have a guy who is their lead who owns a 1970 Challenger (that's why I go there for tires/alignment) and although I didn't talk to that guy, the person with whom I spoke sounds like he understood and said to bring it back and and they'd take another look at it and make it right. I appreciate the feedback. My comment about no movement when I tried to wiggle the tire with my hands at 12 and 6 and finding no movement, was just to say that made sense because I replaced the wheel bearings when I did the disk brake upgrade. As usual, you guys are spot on. Sorry for not searching the archives first. Many thanks.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309239
05/22/17 06:31 PM
05/22/17 06:31 PM
Kentucky, USA
Kentucky, USA
That's is...the caster/camber adjuster was "not" fully tightened. I should proof read my posts. Thanks again.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2309247
05/22/17 06:40 PM
05/22/17 06:40 PM
post what they end up finding.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2310526
05/24/17 07:08 PM
05/24/17 07:08 PM
Kentucky, USA
Kentucky, USA
Just reporting back. Took it to the place after calling the Mgr (who also owns a 1957 Chevy and understands old cars). Talked to the Mopar guy there too who owns a 1970 Challenger. Long story, short: The manager said they'd have no credibility if he didn't admit...it was done incorrectly on a lift that they youngun' who did it shouldn't have been using. I'm not sure what that has to do with it, but my caster/camber cam adjusters are fine. They just think it was done incorrectly. So, they redid it, "with his best man on the job this time," and corrected the problem. Hopefully, it is fine. I'm glad it wasn't a problem where my car wouldn't hold the changes. Thanks!
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2310787
05/25/17 08:49 AM
05/25/17 08:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks for the feedback and nice that they admitted to the problem.
Check your tire for wear.
One time I put a new front end under my challenger and drove with a squealing tire for 3 miles to my Moms house on the way to the alignment shop. The tire was so hot it melted into her blacktop driveway when I parked it. By the time I drove it another 2 miles to the shop the left front tire was shot.
Re: Left Front Tire Squeal [Re: RoadrunnerCN] #2310866
05/25/17 12:20 PM
05/25/17 12:20 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Well, if its was done on a lift and the were tires hanging, that would really screw up the results. If a youngin did it, he may only be familiar with strut suspensions. glad they admitted it and got their "best man this time" to correct it.
