Page 1 of 3 1 2 3
Rock,hard place front main bearing #2308593
05/21/17 04:51 PM
05/21/17 04:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have cross bolt mains 1,2,3,4,5 and I need to check #1 but the oil pump is in the way of the side bolt and factory steering box limits oil pump removal.I think I can drop the pump 1/2" to loosen the side bolt and then the main stud to check if the bearing is still tight after that.
Re: Rock,hard place front main bearing [Re: Clanton] #2308638
05/21/17 07:01 PM
05/21/17 07:01 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have removed the oil pump before with the engine in the car. I can't remember the exact proscess, but I think I had to jack up the drivers side of the motor, and then back out the bolts but leave them in the pump.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Rock,hard place front main bearing [Re: Clanton] #2308846
05/21/17 11:51 PM
05/21/17 11:51 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Sounds about right!I need to grind the steering bracket a little for the oil line fitting so I will put some cardboard next to the engine to keep grindings away so after the pump is out I can use a tq wrench when finished through the k member side even.I hope to just slide a new bearing in.
Re: Rock,hard place front main bearing [Re: Clanton] #2308994
05/22/17 12:21 PM
05/22/17 12:21 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
If I remember right, when I removed the pump to install a high volume kit ,
I removed the pump cover first, then the body and rotor and installed in the reverse order, didn't have to jack the engine.
Joe
Re: Rock,hard place front main bearing [Re: jlatessa] #2309082
05/22/17 02:18 PM
05/22/17 02:18 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Joe
BINGO! I just did that,Thank you.Now I have a clear shot at it all.
Re: Rock,hard place front main bearing [Re: Clanton] #2309085
05/22/17 02:22 PM
05/22/17 02:22 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Now to do the main cap and turn the engine by the crank bolt to see if that helped.The sound[squeaking tight]came from the front.
Re: Rock,hard place front main bearing [Re: Clanton] #2309086
05/22/17 02:25 PM
05/22/17 02:25 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The fun part was on the Koleno block the top rear bolt is in the water passage and water came gushing out.I was still happy.
Re: Rock,hard place front main bearing [Re: Clanton] #2309146
05/22/17 03:39 PM
05/22/17 03:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Well it is looking like I rolled an oil ring putting it together,The main,rod bearings look perfect[almost,lol] on #1main,rod.The squeak is coming from #1 it sounds like and I could pull that head but if you have an idea to test let me know.
Re: Rock,hard place front main bearing [Re: Clanton] #2309147
05/22/17 03:40 PM
05/22/17 03:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Come to think of it I had #1 rod cap off an it was still tight.
Re: Rock,hard place front main bearing [Re: Clanton] #2309151
05/22/17 03:46 PM
05/22/17 03:46 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I know some of you will say just pull the darn engine but I take this as a learning exercise,opportunity
Re: Rock,hard place front main bearing [Re: Clanton] #2309156
05/22/17 03:57 PM
05/22/17 03:57 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I do see on the main bearing on the tab side the 1st 1/4" is shiny so maybe the sides are tight on all the mains.I will check the other shell half on that main.I may end up pulling more main caps huh?
Re: Rock,hard place front main bearing [Re: Clanton] #2309161
05/22/17 04:08 PM
05/22/17 04:08 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Yep a lesson in why you did not pull the engine! but I am guessing you already figured it would have been easier to do that. Doing an in line re-build should only be reserved for a big diesel engine or something that runs on NITRO
Re: Rock,hard place front main bearing [Re: Clanton] #2309162
05/22/17 04:09 PM
05/22/17 04:09 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The top shell is hard to get out so I am using an old bearing to move it around the crank to get it out,I hope,it is 1/4 around now.
Re: Rock,hard place front main bearing [Re: DoubleD] #2309163
05/22/17 04:10 PM
05/22/17 04:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
My choice and I can live with it.
Re: Rock,hard place front main bearing [Re: Clanton] #2309175
05/22/17 04:32 PM
05/22/17 04:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Well I need a line hone,the top half of the bearing is black on 2/3 of it on a 3/4 groove bearing and by the tab is ok.So now we know and thanks for listening.
Re: Rock,hard place front main bearing [Re: Clanton] #2309179
05/22/17 04:38 PM
05/22/17 04:38 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
NEVER GIVE UP! good job.now the work starts.
Re: Rock,hard place front main bearing [Re: Clanton] #2309203
05/22/17 05:31 PM
05/22/17 05:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
There is a high spot at the oil hole and a mark on the back of the bearing from the raised spot so I am sure the others are like that.I had the same issue with the cam bearings!!!!!
Re: Rock,hard place front main bearing [Re: Clanton] #2309206
05/22/17 05:37 PM
05/22/17 05:37 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
This is all I can think reading this thread
Re: Rock,hard place front main bearing [Re: The Shadow] #2309209
05/22/17 05:44 PM
05/22/17 05:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Well if you would take any value from my work it is that if you have a Koleno block you should check all the oil holes for high spots before you have trouble.I think that is important or should be to someone with that block.
Re: Rock,hard place front main bearing [Re: Clanton] #2309295
05/22/17 08:04 PM
05/22/17 08:04 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Didn't this block run before, or is thus a new build on this block.
I am wondering how that raised oil hole never showed up before...at least in the bearing clearance checks?
Page 1 of 3 1 2 3
